Please tell me what i have for suspension thanks
Discussion in 'Suspension' started by mxxdude, Jan 21, 2013.
  1. Jan 21, 2013 at 4:55 PM
    mxxdude
    mxxdude [OP] Well-Known Member
    Brandon
    Tucson AZ
    06 4x4 TRD
    New to trucks
    It appears to be stock trd sport height... i basically want something i can just race around the desert with and not really worry about it...
    I took some pictures and maybe you can help me about its all donhoe racing suspension but im not sure if its adjustable etc how reliable , if i can lift it up higher etc... Id love another 2 inches
    so far i like the ride but i dont want to go race around on my truck or put it through hell if thats not what the suspension is capable off or made for
  2. Jan 21, 2013 at 5:03 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    First, you have coilovers that are maxed out on the preload. So you are not getting more lift from them. The uca is good with the uniball. The rear leafs look like a deaver or alcan pack which is good for mid travel. The rear shocks have resi's on them. I wouldn't be scared to beat on it some. I wouldn't take take 3ft whoops at 60mph though either. All in all its a solid setup for some intermediate off roading.
  3. Jan 21, 2013 at 6:24 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    thanks if i wanted more travel and make it a little more aggresive would the rear handle it if i upgraded the front a little more?
  4. Jan 21, 2013 at 8:04 PM
    ntilehman
    Seth
    Charlotte, NC
    Yea the rear is pretty stout man. Unless you get a bed cage and make it long travel that is about as good as you are going to get. You could run some nice kings or fox's with resi's in the front for a nice ride. Unless you spend some serious money and go LT in the front you are about as good as you can get. Maybe gusset the spindles and shock mounts. TC makes stock length control arms but they are pricey, very pricey. LT in the front you would have to extend your drive axles.
  5. Jan 21, 2013 at 8:16 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    - Looks like DR coilovers in the front (basically same as Icon 2.5 COs) and they appear to be maxed out on the lift (around 3 inches).
    - Looks like Total Chaos UCAs.
    - Looks like Deaver J66, 10 pack rear leaf springs. They give a great ride, but only 1.5 inches of lift.
  6. Jan 21, 2013 at 10:22 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    thanks alot man, and yeah thats kinda what i figured but since im new to trucks just wanted to make sure, so far it feels pretty good, i think the next upgrade will be slowly converting it to LT but im not sure seems like my setup is exactly what i wanted
  7. Jan 21, 2013 at 10:28 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    front and rear shocks area at least 4 years old if they say DR (donahoe racing turned into icon)
    and yeah, looks like total chaos Uca's. Pretty solid build there, I doubt you'll have issue. You can always get them rebuilt for waaaay cheaper than buying brand new, which you should consider anyway with its age depending on mileage. I believe they can rebuild and add extended travel to them to get you more lift.
  8. Jan 21, 2013 at 10:42 PM
    ntilehman
    Seth
    Charlotte, NC
    The extended version from ICON doesn't give you more lift. It will give you about 3/4" more droop.
  9. Jan 21, 2013 at 10:44 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    well the truck only has 53xxx miles on it so i think there good all the suspension components look good as far as bushings and bolt torque and leaks or anything good
    but i will definitely look into the extension because i would love a little more lift and possibly travel
  10. Jan 21, 2013 at 10:46 PM
    ntilehman
    Seth
    Charlotte, NC
    You won't get more lift. The threads are almost maxed out. The length of the shaft has nothing to do with how high it will make the truck sit. You get lift from the spring rate and length.
  11. Jan 21, 2013 at 10:50 PM
    benbacher
    Anchorage, AK
    ^True. You will get more travel, and perhaps they could load a heavier spring under it as well in which case you would see an increase in ride height I'll wager. I believe Icon will go up to a 700#
  12. Jan 21, 2013 at 10:54 PM
    ntilehman
    Seth
    Charlotte, NC
    Yea but you don't want to jack up the rate of the spring if you are not adding extra weight to the front. It will ride like a pogo stick ha. I would just stick to running a 650 spring without a sway bar on some rebuilds valved for what driving you plan on. If you are set on more front lift they make a 6" kit as well. Most guys will flame you for thinking about that on here though. These trucks just don't need to be that high. 3" is plenty high. 4" spindles on the 2wd truck is popular so you don't have to preload the coilovers.
  13. Jan 21, 2013 at 10:59 PM
    benbacher
    Anchorage, AK
    I wish we could do spindle lifts in 4WD. But then I remember that I have 4WD and spindle lifters dont :D
