Plethora of questions
Discussion in 'Technical Chat' started by Greensystemsgo, Jun 13, 2011.
  1. Jun 13, 2011 at 2:29 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    So, this thread is a little to do list of what ive done, mixed in with some questions here in there, hopefully they get answered :D
    Bought a 1999 Tacoma 4x4 TRD SR5 V6 on June 11 2011. Paid to much, but its exactly what i want, and i suppose if id of paid more, i would still have to do repairs, regardless im kicking myself in the face :(
    how she sits new to me, cleaned, stock.
    Currently messing with:
    Timing belt/check bearings and waterpump
    July 16
    3rd member leaking
    front diff leaking :(
    clutch/pressureplate
    Carrier bearing
    Ujoints
    Still to go
    Horn - doesnt work
    Bumper/Grill loose - gonna go get clips from toyota
    Lack of center console (ac) lighting
    air bag light blinking - custom stereo?
    key fobs\spare keys [Alarm/transponder?]
    gas tank filler neck seal
    dash being held on with self tapping screws
    weld a hanger onto exhaust
    sway bar linkage, quick disconnect.
    Finished! For now...
    5100/5125 billys
    eibach 3" coils
    all pro expedition leafs
    new upper/lower ball joints
    new tie rod ends
    new cv's
    clutch
    pressure plate
    CEl - cyl 3 misfire and bank 1 lean
    Repair extended 4x4 shifter
    Replace BROKEN/extended gear shifter
    Passenger side turn signal plug assembly - BFA
    Windshield wipers
    Driver side marker - ordered off of fleabay
    got rear 4x4 mud flaps, thx BFA!!
    Passenger side turn signal wiring assembly needs to be replaced with proper
    New Battery, Optima RED 34R
    damaged center console
    flasher unit
    Accel peddle loose
    Misfire prompting check engine - replace all plugs and seems to be fixed for now
    Tires
    Belts (3)
    wash/wax/clay
    Flush radiator
    Oil
    Driver Door handle - fleabay
    Driver marker rewire - broken at base of plug
    Driver turn signal repair - bulb had mud between terminals breaking connection
    Passenger marker Investigate
    Extras
    Move turn signals into markers using dual filament bulbs
    custom metal bumper/s with winch hookup
    rhino spray liner
    camper shell
    dual roof rack with attachable flood lights
    bike rack in bed or on roof
    zombie response unit TRD decals - TW
    Owners manual fleabay
    shot front r/p teeth :(
    new suspension
  2. Jun 14, 2011 at 7:04 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Little update, pulled, cleaned, and filled 8 year old autozone battery, which reset check engine light.
    Turn signals I think are due to the driver side front turn signal being glued in, and the wires broke. Fuse is fine, but relay may not be. And theirs a mess under back for trailer hookup.
    Took a chance on that handle, we will see.
    Tires are 117 each out the door, falcons, stock size, the spare is an old ghetto chevy rim. Dunno about that yet. It is full size but id prefer a toyota rim, so ill hold onto the best tire.
    As far as keys and alarm, I've learned nothing more then I gotta run to the dealer :(
  3. Jun 14, 2011 at 11:20 AM
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
  4. Jun 14, 2011 at 11:49 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Ill need to hit up dealership for codes though even if i dont have them program them correct? im lookn at original toyota key fob's
  5. Jun 16, 2011 at 8:21 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    so clutch i think is toast, and 90% sure front drivers side hub doesnt engage, and passenger is iffy. Gonna talk to shop and might just flip it and cut my lemon losses :( :( :(
  6. Jun 17, 2011 at 6:42 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    hey if you need any donor parts i might be able to help out just let me know what you need
  7. Jun 17, 2011 at 12:09 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    are you parting out your rig, or just bought a donor for the cab?
  8. Jun 17, 2011 at 12:12 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    he bought a doner for the cab. and hes parting it out
    parting out the new truck he got not the rolled one
  9. Jun 17, 2011 at 1:02 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    sweeeeet cause i do actually have a list of some parts i could use. Im taking it to a toyota shop here ina bit to have the belts changed, imma get their professional opinion and we shall see.
    front bumper/grill/passenger front corner marker/center console/dash plastic all ring a bell though :D
  10. Jun 17, 2011 at 1:05 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    With all these problems, why the heck did you buy it?
  11. Jun 17, 2011 at 1:34 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    cause i work on bugs, and didnt know what i was looking for/at :(
  12. Jun 17, 2011 at 6:49 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    If by "aftermarket," you mean LED, that's the problem. The flasher is designed to flash too fast if it does not see a large enough load (if a bulb burns out). LEDs don't provide enough load. To fix, either put standard incandescent bulbs in it or add a load resistor.
    For 2010 and newer trucks, if you register at http://www.toyota.com/owners/ , they will give you free online access to the owner's manual. Maybe they will do it for your truck, too.
  13. Jun 17, 2011 at 7:43 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    imma hopefully get the entire plug from BFA, id like to keep it stock for now, then ill do special stuff. But thats exactly what i figured, load resistance. Toyota wont sell me just the plug assembly, so grrrr.
  14. Jun 18, 2011 at 8:48 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    got the door handle on this morning, its not even 9am and its already 90 :( and its black which doesnt help at all.
  15. Jun 27, 2011 at 10:47 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    mechanic friend is gonna do the more difficult work for cheap, i lack a tranny jack so im grateful, need to fix clutch, and fix engine lean so i can get it emissioned still. ugh.
  16. Jul 11, 2011 at 12:37 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    just read on how to engage elocker, its a little finicky engaging/disengaging but works none the less :D i just feel sorry for my street.
    suspension and clutch stuff ordered prob tomorrow.
  17. Jul 11, 2011 at 5:28 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Dude sweet on thagt elocker.. I wish I had one. If you want a hand with your suspension ill be down to help out
  18. Jul 11, 2011 at 6:40 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    thx bro. should have a little tw bbq or something when we do it.
  19. Jul 12, 2011 at 5:47 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    2 man team can knock that out in a few hours id say
  20. Jul 12, 2011 at 8:58 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    so it looks like suspension wont be here till early week after next, we should do it, then go exploring cause that'll be everything on my list as far as major.
