Pliny's super secret build and BS thread
Discussion in '1st Gen. Builds' started by Pliny, Jul 29, 2013.
  1. Dec 14, 2013 at 12:01 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Missouri
    2003 Tacoma TRD/SR5 4x4
    Suspension: Front - Bilstein 5100's/Eibach coils Rear - All Pro Expo Leafs/Rear Icon Remote Reservoir Shocks Wheels & Tires: 33x12.50x15 KM2's/Summit Racing 85 Black 8 Series Wheels/15x8/3.75" Backspacing [U]Armor:[/U] - [URL="http://www.tacomaworld.com/forum/relentless-fabrication/152694-just-released-re
    Saw that he was changing out his rear brake line for an extended one I think. I need to do that.
  2. Dec 14, 2013 at 12:13 AM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    :cheers:
    :cheers:
    :wave:
    3rd beer. Lol. I passed that point a long time ago.
    Patience my friend. Takes a while to get things uploaded and organized.
    This is true.
    Also got the 7100s on. That was "fun." Got plent o' down travel now! The icons were short by 1.5-2." Can't wait to take these things offroad! Need longer bumps first though. Finished as it was getting dark, so no pictures today.
    Also, thanks to local TW member Chris / deadhed61 for the help today!
  3. Dec 14, 2013 at 12:14 AM
    PcBuilder14
    Brent
    Missouri
    How hard was it?
    What bumps you looking into?
  4. Dec 14, 2013 at 12:20 AM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Well, the first one took a hell of a longer than the second - but isn't that how it always is?
    It's just kind of difficult to get the hourglass bushings on the shock mounts as they buldge in a little bit. After you get 'em half way on it's not that bad - just grab a longer bolt and it'll push 'em on. The other thing is - compressing them up to fit on both mounting locations required a bit of finesse.
    Also should add - there was corroded rubber and shit on the pegs - giving 'em a quick handsand down made the bushings slide on a LOT easier. Wasn't that apparent initially, but it made a difference.
    As for bumps, I haven't quite decided. Either something cheap like the ES / Daystar or weld some square stock on the stock bump with a plate at the end. Got the idea from a ttora thread a long time ago. I'll see if I can find it...
  5. Dec 14, 2013 at 12:22 AM
    PcBuilder14
    Brent
    Missouri
    Yeah, I've been looking into either AllPro or Wheeler's bumps, but I'd have to relocate the shock mounts to do a u-bolt flip first.
  6. Dec 14, 2013 at 12:27 AM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    This is the general idea on how I'll probably do the bumps.
    I've heard the wheelers one's are kind of worthless and compress into nothing. At least that's what folks were saying the LT thread recently. No first hand experience though :notsure:
    Does all pro sell something besides the timbrens? Those are fancy - but $$$. Honestly I don't huck my truck so I don't really care if it hits hard. I just want to make sure I don't over-compress on the trail.
  7. Dec 14, 2013 at 12:29 AM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Have any of you heard about a no-weld lower shock mount for 1st gens? I heard today that there was one (in association with a u-bolt flip kit).
    I don't understand how it could work but I am very interested!
  8. Dec 14, 2013 at 12:31 AM
    PcBuilder14
    Brent
    Missouri
    Interesting...
    Yeah, Timbrens are the only ones from AllPro. But I figured I might as well go all out haha
    Now that you've said that about the Wheeler's bumps I'll probably get the Timbrens down the road.
  9. Dec 14, 2013 at 12:32 AM
    PcBuilder14
    Brent
    Missouri
    I've seen ones that utilize the u-bolts I think, not sure where though...
  10. Dec 14, 2013 at 12:33 AM
    PcBuilder14
    Brent
    Missouri
  11. Dec 14, 2013 at 12:36 AM
    jbmccul
    jbmccul Well-Known Member
    07 4Runner Sport
    He needs the superbumps for all the beer he puts in the bed
  12. Dec 14, 2013 at 12:48 AM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Whoops it was the MT thread.
    http://www.tacomaworld.com/forum/suspension/200644-mid-travel-bs-thread-362.html#post7764717
    Very interesting. Thanks :cheers:
    Why do you think I got expo's :D
  13. Dec 14, 2013 at 1:22 AM
    m3bassman
    m3bassman Professional Web Wheeler
    Captain Jack Sparrow
    On the seven seas!
    this build is
  14. Dec 14, 2013 at 1:41 AM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    I had to the urban dictionary this :anonymous:
    Thanks :cheers:
  15. Dec 14, 2013 at 1:46 PM
    #35
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Moved from first page to load faster -->
    It turns out Icon 2.0RR are too short for expos regardless of input provided from people on this forum, including an "esteemed" and prolific vendor on here. Lesson learned the hard way: cycle your suspension before buying shocks.
    I wanted something rebuildable / revalvable. After talking to a couple helpful folks on here (Namely Monte and Lumpskie), it was brought to my attention that the 12" SB 7100s could be perfect, as the compressed length is 16.1 and the extended is 27.68.
    These shocks however, come with 1/2" heims, which do not fit on stock mounting location (18mm). This leads to the following how to. If you break your face / and or shocks and or tools / it's not my fault. My methods are off the redneck / jerry rig variety. SO:
    How to put bushings in 7100s to fit stock mounting locations
    When I first ordered the shocks, one was leaking from the factory:
    So then I ordered a replacement, which oddly enough had some different numbers on the shock than the other one from the first order:
    First order:
    Replacement:
    Talked to Bilstein and they confirmed these are still the same shocks with the same valving.
    The actual model number is the AK7112SBB. Quick bit about model number since it's not described that well anywhere. All of the 7100 shocks start with AK71. The next two digits are the travel in inches (12"). SB = short body. B is the valving (255/70 in my case). You may want different valving for your application. That was what Billstein suggested I run based on my truck (I typically carry 300-500lbs in the rear of my truck). They mentioned that they recommend 180/75 for folks who are entirely unloaded in the back for small/midsize pickups like hours. Regardless, I am not a valving expert and it's worth a call when / if you order these shocks.
    First things first... grab yourself your IPA of choice (This happens to be the Lagunitas):
    You're going to need a ball joint press. Or a vice or press of choice. I used a bj press. I rented it from O'reilly's
    These are the other primary tools you'll need:
    Flat heads of varying (small) size, 15mm socket, 17mm socket, 24mm socket
    You're also going to want a spare 2x4 or scrap piece of plywood. If you get caveman, a BFH and large C clamp are useful to. You'll see why....
    These are the bushings you want: Energy Suspension 3/4" ID Hourglass bushings (9.8108G [black] or 9.8108R [red]). When you order them, they come in a pack of two. So, you need two packs total to do both rear shocks top and bottom. Some folks use this opportunity to do a u bolt flip, at which point they'll keep the heims on the bottom and just use the bushings up top. Anyways, now you know.
    Getting started....
    OK so there are two snap rings that hold the heim in. One side looks like this:
    You could use a snap ring tool if you want. It's not really necessary for this, and just as easy to get out with a small flat head. How I did it - wedge a small flathead in the gap here:
    The give it a twist and or work the flathead around, prying the snap ring out. It should come out pretty easily.
    Now, you have two options: 1) Get the other snap ring out first and the heim second or 2) Push the heim out first and the PITA snap ring second
    I think it's worth trying to get the other snap ring off first. It's a serious PITA as there's no hole for the snap ring pliers and no gap to easily wedge a flat head into. I DID successfully get 2/4 of the PITA snaprings out before pressing the heims out, like so:
    Then, finish your beer:
    And grab a banquet beer because you're poor and can only afford so much of the fancy stuff:
    This is my method of getting 'em out:
    Press the 17mm against the heim, pushing it into the 24mm on the other side. The big ol' c clam is useful if you don't have a bench vise and need something to hold the bj press in place, as shown above. Caveman shit.
    Eventually you'll press the heim through (requires some elbow grease). You'll know when it's through (probably will hear a bang, or notice the shock eyelet is now free-sliding on the bj press
    And it's out!
    The bummer of my caveman approach is you've now lodged a heim into your 24mm socket:
    Getting it out's pretty easily though. Wedge a flat head from behind, like so:
    Give a solid tap with your BFH:
    And it's out:
    If you couldn't get that PITA snap ring out from the back, you can press the heim out first, using the 15mm socket, using the same technique as above (with the 24mm on the other side). I got lucky on the shock I was taking pictures of doing this method, and was able to just push the heim out with my thumb. There is no way I could do that with the other ones. Anyways, you've then got the easy snapring and heim pressed out:
    You can try to pry that PITA snapring out, but I couldn't find a good way to grab it. The geniuses at Bilstein did not make it easy since the snap ring gab is angled / /. Easiest way I found was to grab that 17mm socket and press it through, much like the method to press the hiem out:
    By doing this, you'll end up wedging that 17mm socket in the eyelet. It may damage your socket if it's cheap shit. I didn't have any issues. Anyways, now grab that 15mm and keep pressing:
    This method will mangle the shit out of that snapring. But, who cares? An 18mm socket may work better than the 17mm, but my sockets jump from 17mm to 19mm so i didn't have a way to test that. Might be worth trying if you have one though.
    Andddd it's out:
    OK so by either method you've got the snap rings and heims pressed out.
    Put some grease in that eyelet (is it necessary - probably not, but I learned my lesson with squeaky leaf bushings that were supposed to be self-greasing):
    Now's the fun part: pressing the hourglass bushing in. Much like the method of pressing the heim out, use the 24mm socket on one side and press the bushing in on the other. I found using a small piece of scrap wood (in this case 3/4" plywood) makes it a hell of a lot easier. If you don't push perfectly straight in with the press, the bushing will go flying. Ask me how i know :rolleyes:. By using the piece of wood, you can fine-toon the angle it goes in by grabbing the wood and angling it straight in:
    Keep pressing and wham-bam: you've got bushings in!
    And here they are on the truck (you need to adjust your stock bumps):
    Original Post->>
    7100s in stock location. Got the resi's oriented today so they're not hitting anything as well as did an oil/filter/air filter change + lube driveline.
    I'm thinking about adding longer shackles too to add some travel - the question is either 1.5" longer or 2.5" longer. The shackles will be All Pro to match to leafs, since it's all just bolt on.
  16. Dec 14, 2013 at 1:54 PM
    #36
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    1.5" longer is only .75" of lift.
    I'd get 2" shackles for 1" lift from toytech
  17. Dec 14, 2013 at 1:55 PM
    #37
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Will those work with the all-pro leafs? I thought there some issue - at least I know the AP shackles aren't supposed to work with other leafs without modification.
  18. Dec 14, 2013 at 1:57 PM
    #38
    Blackdawg
    Monte
    Wyoming/St. Louis
    No idea haha
    Maybe.
  19. Dec 14, 2013 at 2:00 PM
    #39
    Lumpskie
    Lumpskie Independent Thinker
    Colorado
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Those Toytec shackles worked for my Alcan leafs... I would think they'd work for allpro too. Are the Allpro springs the same width as stock? If they are then the Toytec setup should work.
  20. Dec 14, 2013 at 2:02 PM
    #40
    YotaOverAll
    YotaOverAll Run it
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I need to get some longer shackles so I can flex better at the mall.
