Pliny's super secret build and BS thread
Discussion in '1st Gen. Builds' started by Pliny, Jul 29, 2013.
  1. Pliny
    Pliny [OP] Offline
    Leonard Mead
    They are currently in stock hangers, so I'm going to with "yes"
    Speaking of shackles - I was going to ask you - what're your 6" custom shackles? What made you decide on that length? I like your truck quite a lot and it looks like you've got some more up travel than I do with the 7100s.
  2. Monster Coma
    Monster Coma Well-Known Member
    Corey
    Central PA
    2014 WRB WRX
    It's a wagon
  3. Pliny
    Pliny [OP] Offline
    Leonard Mead
    It takes a lot of flex to get over these:
    Don't blame ya :thumbsup:
    :cheers:
    vs
  4. Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    those pics do not show if he has more up travel then you at all..haha
  5. Pliny
    Pliny [OP] Offline
    Leonard Mead
    The shots looked more comparable until I actually put them side by side :anonymous:
  6. Blackdawg
    Monte
    Wyoming/St. Louis
    hahaha
    of course.
  7. Lumpskie
    Lumpskie Independent Thinker
    Colorado
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Dude... you asked for it, so prepare for picture OVERLOAD...
    So, first off, I had stock length shackles. The truck flexed well, but I wanted more droop. So, I went with the toytec 5.5" shackles. I got more droop but wanted more droop still. So, I went with the new, longer leafs and the 6" shackles I have now. My new ones are just cut 3/8" plate with holes drilled in them. I can do this since my orbit eyes are the same width as my hanger. I'm still breaking the system in, but the droop is improved. Now, the pictures.
    One thing that was nice about these shorter shackles was that I could get a little more compression out of the system. Here are pics of my shocks on my old shackles
    Shocks under compression
    Shocks extended
    Shocks at ride height
    Still that extra compression didn't make up for the extension I gained out of the longer shackles. So, the first picture is full compression on stock shackles, the second on the toytecs. You can see that I got a liiiitle more compression on the shorter shackles.
    Now for extension,
    Stock Shackles:
    Toytec 5.5" setup
    Not quite clearing the slider... this is partially because my suspension was binding
    Latest 6" setup. (after a redone geometry and going from 32" tires to 33s)
    Just barely clearing the slider... but this setup will break in a bit more...
    So, that's my evolving shackle solution...
  8. Blackdawg
    Monte
    Wyoming/St. Louis
    i still think it was weird how little droop you got with the toyotech shackles and all..
  9. Lumpskie
    Colorado
    Ok... I fixed my pictures...
    Yeah, I think it was a combination of my springs binding and my main leaf needing to be longer to use the longer shackle. My geometry was all messed up.
  10. Pliny
    Pliny [OP] Offline
    Leonard Mead
    Cool thanks for all the pictures! Although now I'm slightly worried that the geo and everything will get funky with the lift shackles, as the main leaf in my expos is designed for stock lengths...
  11. Lumpskie
    Colorado
    ^Since you are an 03, I don't think you'll have the same problem I had. My leafs were custom made for my short '96 leafs and stock shackles. I didn't think ahead. Also, I posted the lengths for you on my build thread.
  12. Pliny
    Pliny [OP] Offline
    Leonard Mead
    Oh! I totally forgot that you guys had the shorter leafs. That makes me feel better. I think I'm just going to get the AP 2.5" longer ones then, since I know they'll work and they're longer than the toytec ones... Might as well get as much droop as I can... And thanks for posting the lengths!
    I also think it's interesting your e brake isn't on the back of the axle like mine... speaking of that - did you lengthen your e brake cable to account for all the droop? We noticed that it's kinda tight at full droop now. Not sure if I just need to adjust it or whether a longer cable is needed....
  13. Lumpskie
    Colorado
    I didn't lengthen my e-brake cable. My thought was that, for the most part, my suspension will be twisting more than actually extending like the prerunner guys do. So far, it hasn't been an issue. Maybe get the shackles and see how it looks?
  14. Pliny
    Pliny [OP] Offline
    Leonard Mead
    Yeah that's a good point. I'm no trophy truck nor do I ever plan to huck it. The bigger concern was crawling and having the e-brake engage and lock up on me.
  15. Blackdawg
    Monte
    Wyoming/St. Louis
    never even heard of that happening..so..think your safe.
  16. Pliny
    Pliny [OP] Offline
    Leonard Mead
    Yeah I had never heard of it either. Only thing people ever talk about is the brake line (and mines retardedly long now :cool:). Might have to put it on jacks again and reassess. Never messed with the e-brake before - time to learn something new about the truck!
  17. Blackdawg
    Monte
    Wyoming/St. Louis
    ive never had it happen..
    and..even if it had..truck drives with the ebrake fully on anyways...:anonymous:
  18. Pliny
    Pliny [OP] Offline
    Leonard Mead
    Hah! I may have done that once or five times :anonymous:
  19. Blackdawg
    Monte
    Wyoming/St. Louis
    Me too :laugh:
    but..on a steep hill..might be more of an effect..
  20. Lumpskie
    Colorado
    LoL, you guys! (says the guy to consistently forgets to disengage his ebrake when wheeling)
