ploom of black smoke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Mar 1, 2012.
  1. Mar 1, 2012 at 8:37 AM
    jw1983
    jw1983 [OP] Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Yesterday i had left work. I was at a stop sign and gunned it as i pulled away. My co worker said thst there was a ploom of bkack smoke from the exhaust. What could have caused that? Is it normal?
  2. Mar 1, 2012 at 8:38 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Too much foot...too little engine
  3. Mar 1, 2012 at 8:39 AM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    that you filled up with diesel instead of unleaded
  4. Mar 1, 2012 at 8:41 AM
    jw1983
    Alberta
    Lol yeah to make myself think i owned a diesel. Hint hint toyota
  5. Mar 1, 2012 at 8:44 AM
    jw1983
    Alberta
    Warrenty for what that is?
  6. Mar 1, 2012 at 9:41 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    i think it's just an over fuel situation, I know mine does it from time to time, its too much fuel and not enough air temporarily and the unburnt goes out as black smoke. There is another thread about someone w/ a full catless truck that says his does it bad. for some reason or another these trucks like to run sloppy rich.
    I personally don't think it's anything to worry about, just don't have observant people follow you from now on
  7. Mar 1, 2012 at 10:56 AM
    jw1983
    Alberta
    Am i going to say theres black exhaust smoke, its under warrenty?
  8. Mar 1, 2012 at 10:57 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    /\/\ this
    wut?
  9. Mar 1, 2012 at 11:02 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Toyotas always run rich. Part of what helps the engine last forever. When you gun it, the system dumps fuel into the engine trying to make the most power it can. Emissions controls go out the window above 3/4 throttle. Unburnt fuel is black smoke. If you get on it hard shortly after you start the vehicle, there is a good chance that the Cat is not lit yet, and so does not burn up the left over fuel like it normally would.
  10. Mar 1, 2012 at 11:03 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  11. Mar 1, 2012 at 11:37 AM
    jw1983
    Alberta
    Thats what my co worker who saw it had said. Im just over 8000 kms
  12. Mar 1, 2012 at 11:40 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    that would be blue smoke. Rings are fine.
    it's fuel.
  13. Mar 1, 2012 at 11:41 AM
    jw1983
    Alberta
    K thx everyone. Im not going to worry about it
  14. Mar 1, 2012 at 11:45 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I still would do a full throttle run up an on ramp just to blow it out. Going to easy on engines all the time can be just as bad as hammering on them constantly since it builds up carbon on the pistons and valves.
  15. Mar 2, 2012 at 8:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I live near a 7% highway grade. I've seen every year, make, model vehicle blow black smoke momentarily when people get slowed down and have to accelerate back up to speed. Absolutely normal. Push the pedal to the floor, the PCM goes to full rich fuel mixture for power. A little bit of black smoke at wide open throttle just means everything is working the way it should.
    If you have a ring wear issue, you will be losing oil on the dipstick.
    Your coworker doesn't know what he's talking about.
  16. Mar 2, 2012 at 8:51 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yop
  17. Mar 2, 2012 at 11:34 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    The fuel/air mixture doesn't go to "full rich". That would cause performance to go down.
    The system goes into "open loop" which deactivates the EGR and other emissions related stuff and just runs the engine on a known good fuel/air mixture. This means that it ignores the signal from the O2 sensors which might cause some black smoke.
