Plowing a gravel road - possible?
Discussion in 'Technical Chat' started by Fenrisulfr, May 13, 2011.
  1. May 13, 2011 at 10:35 PM
    Fenrisulfr
    Fenrisulfr [OP] Well-Known Member
    SW-VA
    Tundra w/ TRD 5,7L V8 4x4
    I am looking at a piece of property that is connected to a state-maintained road via 0,5km of gravel road. I would like to set up the Tacoma to plough this, but I am concerned about a few factors:
    • The Tacoma's ploughing capabilities - what would be the relevant rating to consider when determining whether it can fit a given plough? Would a Tundra be preferable in lieu, and would it be worth the trouble to swap?
      (mine is a 4x4 V6, no TRD...I have no clue what TRD does)
    • Gravel - this can turn to dirt or mud, which would reduce traction. It may also interfere with the ploughing; I am not sure about this. This could be mitigated with the right tyres if I recall.
    • Lift + larger tyres - from what I understand, that may help with the gravel+crap, but it may sap the truck's power because it is rotating heavier wheels at a lower RPM. What is the smallest tyre offering flotation on snow? 38"s seem a bit excessive; I am hoping to get away with something a bit smaller.
    Finally, if you had to outfit a Tacoma to do well in these circumstances, what would be your ideal build? Keep in mind that NC does not have a height limit per se; I would just have to adjust the headlights if they are north of 42".
    Thank you for your trouble in helping with this.
    (My apologies if these specific matters were covered in another thread; I found other threads but none addressing gravel, and most offered conflicting opinions but little data)
  2. May 13, 2011 at 10:40 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Well a lift wouldn't help with traction..
    some aired down mud terrains, or in snow chains or studs would work well I would Imagine..
    and If you had TRD offroad you would have a rear locker,
    another large increase in traction
    :thumbsup:
  3. May 13, 2011 at 11:50 PM
    Fenrisulfr
    SW-VA
    Just to be sure...a rear locker is a locking differential on the rear tyres, and can that be installed separately?
  4. May 14, 2011 at 12:20 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Is this just to maintain the road and keep it smooth? In that scenario I think your best bet would be a box style scraper attached to the back. Some MT's would be your best bet for a tire that you would also use on the road. If you're willing to switch the tires out some chevron style tires would be better for this, but are NOT for onroad at all.
    For the price of doing the mods you want to your taco to do this you'd probably be able to find a small tractor that would do the job even better.
  5. May 14, 2011 at 12:59 AM
    Fenrisulfr
    SW-VA
    It's just to remove enough of the snow so that the road is navigable. Could you tell me more about box style scrapers?
  6. May 14, 2011 at 1:09 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Not all Mt or mud terrain are not recommended for snow or ice. Find some tires with "m+s" on the side wall or the mountain and snowflake on there or both. Those tires are made for snow.
    The Trd sport package came with a limited slip differential and the Trd Offroad package came with a locking differential.
  7. May 14, 2011 at 7:28 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    If you mean to smooth the gravel, you want to use a grader or a dozer, or DRAG a road level device... a harrow , pre leveling holes .
    Tacoma with a plow would work for snow provided the road isn't too uneven. In any case plow the road while its not built up with snow too high, and keep the plow 1/4-1/2" off the road, yes , dont plow all the snow off , just get as close as is safe. Start out high until you know its safe to lower it a bit. Use a light plow and go slow, chain up for some extra traction, snow can get heavy fast.
  8. May 14, 2011 at 7:36 PM
    blue97taco
    blue97taco Well-Known Member
    alex
    Raleigh, Nc
    where are you at in nc
  9. May 14, 2011 at 8:35 PM
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    just chain up your truck at all 4 wheels and you should be fine. just stay on top of it and don't let the snow get too deep before you get out there. 4-6" at a time. unless it real cold an the snow is light.
    but a tractor would be the ticket. if you have a few acres and a road/driveway to maintain they are indespencible. you can get older ones with a few implements for less then $4000.
  10. May 15, 2011 at 7:20 AM
    Fenrisulfr
    SW-VA
    I am currently in SW Virginia; the property is in Boone / Banner Elk which is also mountainous. I got the V6 4x4 with this in mind, but I am concerned about snow since I would have to plough 0,5km to get to a maintained road.
    The reason I am asking about modifications is because I was hoping to modify the truck anyway for off-roading.
  11. May 15, 2011 at 8:13 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Fenrisulfr,
    There are numerous plow set-ups for Tacomas....Fisher, Boss,Myers,Blizzard and Western.... try this for a start to your new education www.GoPlow.com
    My suggestion...find a dealer you can trust for both the sales and parts end of this process...a good price will not mean $hit when a storm comes in and you can not get your plow serviced or fixed....
    Maintaining your road maybe quite simple IF you set things up that way....During good weather dragging a "Drop fence" behind your TACO will bring surprising results....
    Good luck and PLEASE do all of your fact finding before you make BIG decisions.....The results might make your purchase that much more enjoyable..
  12. May 16, 2011 at 7:52 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you have an aftermarket warranty, a plow will void it. My warranty specifically states this.
    Mushroom feet for the plow will help the plow float over gravel without digging in. You can adjust by adding or subtracting washers/spacers.
    Box graders are shit for snow removal, unless you run in reverse. Then, it will only push snow in a straight line.
    AT or all season tires will work, AT are better though. Keep some weight in the rear end to keep it planted. Sand bags or water bladders work well.
    Make sure you have a supplemental trans cooler installed, if you have an auto. Plowing is rough on trans and driveline. Expect to shorten the lifespan of your truck from plowing.
    Keep it slow. Hitting things sucks!
  13. May 16, 2011 at 8:07 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Tacoma will work for plowing snow off your drive way. Leave it stock with MT tires, put some weight in the back for traction, keep your plow blade at least 1/2 inch off the ground. To level the gravel on your drive way, try dragging an old train rail or something simiular. A tractor would work better, but the Tacoma can get the job done.
