Pls delete
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by JoeyWales, May 31, 2021.
Thread Status:
Not open for further replies.
  1. May 31, 2021 at 5:34 PM
    JoeyWales
    JoeyWales [OP] Well-Known Member
    SC
    Looking for a 3.91 front diff to match my rear.
    I have a 4.10 front and rear on hand and would prefer to find the matching instead of swapping everything.
    Located in SC. Willing to drive to pickup if in the SE
  2. May 31, 2021 at 5:39 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    manual or add.
    Ive been looking for a front diff close to 4:56.
    My luck hasnt been good.
  3. May 31, 2021 at 5:52 PM
    JoeyWales
    SC
    Manual preferred but ADD will work.
  4. May 31, 2021 at 6:09 PM
    Matic
    Tricky Dick
    Easley, SC
    I'm asking what do you have.
  5. May 31, 2021 at 6:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Front diff is the same regardless if manual hub or ADD. I explained this in two threads to you.
    JoeyWales[OP] likes this.
  6. May 31, 2021 at 6:22 PM
    JoeyWales
    SC
    My truck is setup with ADD.
  7. May 31, 2021 at 6:34 PM
    Matic
    Tricky Dick
    Easley, SC
    ok, let me simplify this. Do you want to sell your front 4:10 add diff?
  8. May 31, 2021 at 6:39 PM
    JoeyWales
    SC
    I’d be glad to. But I have to find a 3.91 first. In which case, I’d like to get rid of the rear end w/e-lock as well.
    Matic[QUOTED] likes this.
  9. May 31, 2021 at 6:58 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I just ripped a manual tube off a B06A front diff. Pretty sure that is 3.91. I can check if it still around, but it may already be gone. You should've sent me a note. I will keep my eye out if it is gone.
    JoeyWales[QUOTED][OP] likes this.
  10. May 31, 2021 at 7:28 PM
    JoeyWales
    SC
    I was going to swap my 4.10 stuff over but finally decided that I actually the like 3.91 better.
    I also wasn’t sure if there was an actual 3.91 front diff. Figured it was specifically for PreRunners.
    Let me know what you find.
  11. May 31, 2021 at 8:51 PM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    You might want to check out the company that floats around here for front elockers (someone chime in with the name, cant remember) Matches the rear locker well and doesnt have the problems with airlines that arb does. Though they are not as tough.
    Though if you dont have any lockers at all, you might want to just go full arb. simpler to only have one kind of system.
  12. May 31, 2021 at 9:14 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    @Sperrunner. Has a 3.91 rear axle sitting in his parts pile.
  13. May 31, 2021 at 10:33 PM
    JoeyWales
    SC
    Appreciate the heads but the PreRunner I just bought has a 3.91 e locker in it already. Looking for the front diff to match.
  14. May 31, 2021 at 10:37 PM
    Tour991
    James
    South Reno/Tahoe
    Are you sure about that the trd locker was only available in 4.10 and 4.30 gearing. I am 99% sure of this.
  15. May 31, 2021 at 11:51 PM
    JoeyWales
    SC
    Ill double check the door tomorrow. I’ll feel really stupid if I’m wrong.
    Tour991[QUOTED] likes this.
  16. May 31, 2021 at 11:59 PM
    Tour991
    James
    South Reno/Tahoe
    @Empty_Lord do you know if I am correct?
  17. Jun 1, 2021 at 1:44 AM
    JoeyWales
    SC
    It is indeed a B03A so 4.10 gearing. Idk why I thought it’s was a 3.91. Perhaps I misread and thought I saw “B06A”.
    Anyway, I feel stupid but thanks for all of your guys input.
    @Tour991 @zippsub9 @TacoBike
    Zipp I’ll hit you up when I’m ready for those hubs and such.
    Thanks again
    Tour991 and TacoBike like this.
Thread Status:
