Plug-in 12 volt power inverter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jul 23, 2011.
  1. Jul 23, 2011 at 1:22 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    I'm just looking for nothing special... something to literally plug into our cigarette lighter so we can power stuff - namely just blowing up an air mattress.
    Would something like this work?
    http://www.costco.com/Browse/Produc...=0&Ntx=mode+matchallpartial&Nty=1&topnav=&s=1
    Is there any disadvantage to having a plug-in versus something else? A guy we went camping with last weekend literally hooked his up directly to his battery when he wanted to use it. Seemed ridiculous and overkill
  2. Jul 23, 2011 at 1:39 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Yep. I like the fact it has a 12-ft cord that way if you are camping you can power everything and not have to run those cables into your cabin. Most of the newer ones include both a cigarette socket plug or and direct cable to the battery. I didn't read the details on the one you posted, but either way would work. If you have the cigarette lighter plug though you can charge things in your cabin while you're actually driving.
  3. Jul 23, 2011 at 1:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good for an inverter up to about 150 watts beyond that you should think about hooking it up direct, 150 watts at 12 volts is about max for the lighter circuit.
  4. Jul 23, 2011 at 4:18 PM
    Madjik_Man
    Thanks for the tip
    Any recommendations on a direct hook up inverter? The one I linked is strictly a plug in.
    I searched the forums and got 5 pages of threads that didn't give me much to go off of.
  5. Jul 24, 2011 at 6:03 PM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    You could probably find a heavy duty one that would hook directly to the battery from a truck stop or somewhere similar. Down here we have Flying J's. they have massive inverters for the truckers
  6. Jul 25, 2011 at 12:14 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    If it only comes with the 12volt cord, you can cut the cig lighter end off and strip the wires to connect to a relay, then run the relay accordingly with a toggle, etc. It says, it has battery terminals too, which sounds like it comes with direct power hookup. You can hard wire that way also. If you decide to use any type of switch to turn it on and off, you really have to run a relay.
    I bought a 750 watt inverter from Harbor Freight for a little less than the one you posted.
