Plug torque etc.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emacpgh, May 3, 2011.
  1. May 3, 2011 at 2:45 PM
    emacpgh
    emacpgh [OP] Well-Known Member
    eric
    pittsburgh
    silver streak mica sr5 sport
    Aries stainless steel bull bar , afe pro dry s filter , secondary air filter removal, scangauge II
    Hi. Sorry, long post here. I switched out my front /rear differentials, transfer case, and manual tran. oil from the stock dino to synthetic oil about a year and a half a go. I tightened the plugs to what I thought was right. I am now at 30k miles and I'm going back to check my levels. Seeing the torque specs in my haynes manual I see that I tightened them way too much(no stripping, but much greater than spec) . Should I tighten them to the spec this second time or tighten them back to how I had them.
  2. May 3, 2011 at 2:49 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Torque to spec and use a new washer/gasket for each plug.
