plumbers?
Discussion in 'Off-Topic Discussion' started by kbp68, Jan 1, 2010.
  1. Jan 1, 2010 at 5:06 PM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    ...so after several unsucessful attempts to clear a toilet with first a plunger, then a drain snake, my three year old informs me that she flushed an apple down the toilet. :facepalm: The snake only goes about 18" in then stops. Any ideas that don't involve removing the toilet?
  2. Jan 1, 2010 at 5:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hate to say it, but if you cant find a snake that is a lil stronger and will go alot farther in then that......gonna have to turn the water off/drain the tank..........and yep...pull the toilet and clear the pipe that way.
  3. Jan 1, 2010 at 5:17 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    What kind of plunger are you using?
  4. Jan 1, 2010 at 5:18 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    siphon the water out and then drop a hamster in there.
  5. Jan 1, 2010 at 5:21 PM
    Afwrestler1986
    Johnstown, NY
    On the bright side, toilets are not that bad, just make sure you buy a new wax seal. And remove the old one. Check out lowes for a different snake.
  6. Jan 1, 2010 at 5:38 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
  7. Jan 1, 2010 at 5:41 PM
    Plumber6304
    Plumber6304 New Member
    Mississauga, Ontario Canada
    09 Access Cab, 4x4,V6 Magnetic Grey Metallic
    Hard folding tonneau cover, Pop n Lock tailgate, Sirius Satellite, Scan Gauge II
    You will have to remove the toilet to get the apple out. It's probably wedged sideways up inside the toilet, turn the toilet on its side and look up from the bottom. You should be able to see it. Don't forget a new gasket. Good luck.:)
  8. Jan 1, 2010 at 5:44 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    If there is an apple in their, you probably should remove the toilet and try to fish it out. Not a pleasant job but sounds like it needs doing. Before you start, make sure you go to a hardware store and get 2 new bolts and a new beeswax ring. Turn off the supply valve and flush it to empty the tank, then bail out the bowl. Take off the 2 nuts and lift the toilet off. When you're ready to replace it, clean out the old wax seal and replace the toilet. Have fun!
  9. Jan 1, 2010 at 6:25 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    [​IMG]What about one of these?
  10. Jan 1, 2010 at 7:13 PM
    Afwrestler1986
    Johnstown, NY
    I think you are going to end up tearing out the crapper and bobbing for apples. Sorry man.
    The apple has swelled up a bit by now.
  11. Jan 1, 2010 at 7:21 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    She must have taken a lesson from my son :p. He did that when he was about that age. They didn't remove the toilet, he use a snake that grabbed it and brought it out. I'd try a longer snake, with a barb on the end. Unless you really jammed it in there with the plunger, then you're SOL....:eek:
  12. Jan 1, 2010 at 7:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Bet it'll beat the apple!!
  13. Jan 1, 2010 at 7:35 PM
    ImpulseRed008
    Susan
    SC
    and the commode and the plumbing and the bathroom :D
  14. Jan 2, 2010 at 7:31 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I suggest moving !!
    Marc M
  15. Jan 2, 2010 at 7:44 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    had that happen to me but with a corndog,tell your wife to only buy grapes.
  16. Jan 2, 2010 at 8:10 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If it was me I'd buy a new toilet. If an apple can't clear then what happens the next time you go to a mexican buffet? The toilets I installed in my house will flush a bucket of golf balls or so they advertise. I haven't tried it yet.
    In all seriousness yes you will have to pull the toilet. Getting the apple out shouldn't be too bad unless somebody sent a chocolate chaser not knowing the apple was in there.
  17. Jan 2, 2010 at 8:18 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    yeah,or a baby ruth:cool:
  18. Jan 2, 2010 at 8:48 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    looks like something chris 4x4 would do. wait.... he would set the toilet on fire.... :rolleyes: if it were me.... id tell my kid to stick their hand in there and pull it out.:devil: i have little experience in this but it sounds like you will need to pull the toilet..... in case nobody else has said that. :p
    good luck!
  19. Jan 2, 2010 at 9:28 AM
    sooner07
    A A Ron
    DFW, Texas
    You could demo the floor out beneath the toilet, belt down the pipe and extract the apple from below.
    Explosive demolition could be used.
  20. Jan 2, 2010 at 9:35 AM
    mntbiker2008
    Aaron
    Cincinnati, OH
    i wonder if insurance would be willing to cover that? come to think of it... that might be pretty funny telling the story of how you blew up the whole side of your house cuz an apple was stuck in the toilet. :laugh:
