Plummeting gas mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by klk222, Feb 20, 2019.
  1. Feb 20, 2019 at 8:38 AM
    klk222
    klk222 [OP] Member
    kris
    2016 TRD sport
    I had my oil changed, and replaced my front breaks over the weekend. since then, my gas mileage has dropped significantly. My driving habits, and commute haven’t changed at all. This week I was averaging around 15 MPG with a low of 11 MPG. In the past after I was averaging from 18- 21 MPG. Any ideas?
  2. Feb 20, 2019 at 8:39 AM
    RocketTaco
    RocketTaco Well-Known Member
    2019 SR Access Cab V6
    Brakes dragging?
    na8rboy likes this.
  3. Feb 20, 2019 at 8:43 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    What oil did you use, and do you notice brakes dragging?
  4. Feb 20, 2019 at 8:48 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    winter gas... check brakes for dragging. Might be the calipers not releasing.
  5. Feb 20, 2019 at 8:57 AM
    klk222
    klk222 [OP] Member
    kris
    2016 TRD sport
    i used the same full synthetic Ive used in the past. would i hear or feel anything if they were dragging? It feels pretty normal, aside from the 11- 15 mpg.
    wilcam47 likes this.
  6. Feb 20, 2019 at 9:00 AM
    wilcam47
    Will
    Bourbon state
    not necessarily. You will get a burned brake pad smell if you are dragging and if your rims are excessively warm especially in the winter you might have an issue. Easy to check is jack one wheel up at a time and see how freely it moves.
    na8rboy likes this.
  7. Feb 20, 2019 at 9:01 AM
    klk222
    klk222 [OP] Member
    kris
    2016 TRD sport
    thanks for the info. ill give it a try tomorrow if it stops snowing!
    wilcam47[QUOTED] likes this.
  8. Feb 20, 2019 at 9:04 AM
    na8rboy
    WI
    Question...Did you pull master cylinder reservoir cover when you pushed caliper pistons back?
  9. Feb 20, 2019 at 9:07 AM
    klk222
    klk222 [OP] Member
    kris
    2016 TRD sport
    not sure, i had then done at a local garage.
  10. Feb 20, 2019 at 9:19 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Not enough information to provide informative feedback about your MPG issue. Too many things can affect MPGs ie.. driving habits, tires, mods, weather/temperature, vehicle setup etc.... If brakes aren't dragging, then something else has changed.
  11. Feb 20, 2019 at 9:26 AM
    klk222
    klk222 [OP] Member
    kris
    2016 TRD sport
    I went with a larger wheel and tire about a year ago, and saw a small drop. since then, I havent changed much. I use the same gas, and more or less drive to the same mix of highway and city driving every day. its been cold, but it was worse weather before the oil/ break change.
  12. Feb 20, 2019 at 9:33 AM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    If the brakes are dragging your wheels towards the center should be damn hot when you get where you are going. Especially if it is enough to drop you 5MPGs. That would be my guess. Jack it up and see if you can spin the wheels freely as well.
    klk222[OP] likes this.
  13. Feb 20, 2019 at 12:01 PM
    HacksawMark
    Mark
    OREGON
    If you MPG dropped that much, you should notice or are doing something different. A 25-40% drop in MPG just doesn't simply happen for no reason.
  14. Feb 22, 2019 at 3:16 AM
    Cjcape
    Cjcape Well-Known Member
    2016 trd dcsb sport manual(For Sale), '98 4runner SR5 sport
    Did you fill up at a different station?
