Plus and zero signs on ome Dakar leaf pack ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattyP, Mar 3, 2017.
  1. Mar 3, 2017 at 5:48 PM
    MattyP
    MattyP [OP] Member
    2010 Tacoma Prerunner dblcab
    Im a newbie here. About to lift my second gen tacoma. Just got all my stuff today. And noticed on my cs047r leaf springs one has a + sign and one has a 0 sign. Shouldn't the set both have one or the other ? Aren't they different specs?
  2. Mar 3, 2017 at 6:19 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Plus goes on drivers side. Minus goes on passenger side.
    Bishop84 and KILLINTIME like this.
  3. Mar 3, 2017 at 6:21 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Sometimes you get two +'s. Sometimes you get both -. Sometimes you get one of each like you did.
    It just means that they're SLIGHTLY above or below spec. You put the + on the drivers side because there's more weight on the drivers side. Fuel tank, driver, etc...
  4. Mar 3, 2017 at 6:25 PM
    MattyP
    MattyP [OP] Member
    Oh ok. Thanks a lot HolyHandGrenade. Thought I was getting screwed over by a eBay seller. I was going to send them back and open dispute. Because I know a couple people who all had matching symbols. Appreciate you
    HolyHandGrenade likes this.
  5. Mar 3, 2017 at 6:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This of Antioch
  6. Mar 3, 2017 at 6:33 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Forgot about the "0's". Same as above applies. + goes on the drivers side. Good luck with it :thumbsup:
    MattyP[OP] likes this.
  7. Mar 3, 2017 at 6:34 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How much were they?
  8. Mar 3, 2017 at 7:06 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I got 1 plus and 1 minus today. Are you leaving the packs whole?
  9. Mar 3, 2017 at 7:12 PM
    MattyP
    MattyP [OP] Member
    Anthony250f
    $412 shipped
  10. Mar 3, 2017 at 7:13 PM
    MattyP
    MattyP [OP] Member
    Spiralout462
    Not sure what you mean by keeping them whole
  11. Mar 3, 2017 at 7:14 PM
    Bishop84
    Bishop84 Well-Known Member
    Share pics after install! You have new ubolts already?
  12. Mar 3, 2017 at 7:17 PM
    OZ-T
    Peter North
    British Columbia
    You can add or remove leafs from the pack to customize it
  13. Mar 3, 2017 at 7:22 PM
    MattyP
    MattyP [OP] Member
    Bishop84
    I will do.
    Prolly won't be for a couple weeks
    Yes I have the u bolts,extended brake lines,rear axle degree shims, tp14 plate spacer for taco lean,sway bar relocate kit,driveshaft carrier bearing drop kit, shock replacement bushings,
    Maxtrac 4"spindles
    Front bilstein 5100s
    Rear toytec boss shocks
    OME Dakar springs
    I have 16x8 rims
    And i am still waiting to buy tires hoping the toyos will fit in a 285/75/16 (33x11.50)
    Or the 305/70/16 (33x12.00)
    Not to sure what will fit and look best
    desertrunner24 likes this.
  14. Mar 3, 2017 at 7:25 PM
    MattyP
    MattyP [OP] Member
    I'm leaving them so I get the 2.75"
    And
    If I do end up setting the billies to 1.5
    I will be adding leafs to this pack to gain 15mm more
  15. Mar 3, 2017 at 8:04 PM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    Makes sense, since I see you're 2wd and going with Maxtracs. Nice setup you have chosen. It should serve you well!
  16. Mar 3, 2017 at 8:25 PM
    MattyP
    MattyP [OP] Member
    Unfortunately yes it's 2wd haha
