PMAG 10 first look
Discussion in 'Guns & Hunting' started by Yoshio, Apr 20, 2013.
  1. Apr 21, 2013 at 5:55 AM
    Yoshio
    Yoshio [OP] Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    Truth, but the military is only a passing thing, no matter how long you want it to last, they kick you out at some point. :D
    I'd rather have my 30 round PMAGs in storage for when I return to a less restrictive state, especially if a national ban on regular capacity magazines ever gains traction.
  2. Apr 21, 2013 at 1:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    For the time being at least, you can keep them broken down.
    It is still legal to buy and import "rebuild kits" that are intended to be used to repair existing mags that you possessed prior to the ban.
  3. Apr 21, 2013 at 1:35 PM
    Yoshio
    Scott
    Central Coast, CA
    Thanks Rich, I didn't know that!
  4. Apr 21, 2013 at 1:53 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The penal code was renumbered a couple of years ago. Here's the new statute.
    There were a total of around 32 exemptions under the old statute, but none of those would apply in your case.
    Possession is not illegal. Importation, manufacture (assembly of a rebuild kit), and transferring TO another person are prohibited.
    Purchase is not specifically banned, but if the seller is booked under a felony (it's a wobbler), then the buyer would likely be charged with conspiracy.
    There is a 36 month statute of limitations, but if you leave the state, the clock restarts each time they are imported.
  5. Apr 21, 2013 at 3:20 PM
    Yoshio
    Scott
    Central Coast, CA
    I'll just have to keep them disassembled then. At least I don't have to store them :D
  6. Apr 21, 2013 at 3:27 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I think the magazine must originate as 10 rounds, magpul makes a 10 round minus block and warns it wont make a 20 round legal as a 10 round in Cali.
  7. Apr 21, 2013 at 4:55 PM
    Yoshio
    Scott
    Central Coast, CA
    Pretty sure it's because you can 'readily convert' a blocked magazine to its regular capacity unless you pin or epoxy the block in place. As magpul doesn't include the pin/glue, the block is not a full 'CA-legal' solution.
  8. Apr 21, 2013 at 5:19 PM
    Tacoyota
    08 4wd
    ah, makes sense.
  9. Apr 21, 2013 at 5:28 PM
    dtmccray
    dtmccray Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    Wait it's illegal to own a 30 round mag in Ca? I thought it was one of those where you could have one but couldn't have it in your gun.
  10. Apr 21, 2013 at 5:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It is illegal to import, manufacture/assemble, or to offer for sale or sell/give/lend (to a non-exempt person).
    Mere possesion OR USE is not illegal, unless it is a fixed-magazine semiautomatic centerfire rifle (that makes it an assault weapon).
    My wife has a 92FS and a few 15rd magazines that we have had since before the ban. Perfectly legal.
    It IS currently legal to block/limit a 30rd body to hold only 10 rounds.
    The law defines a large capacity magazine as an "ammunition feeding device capable of feeding more than 10 rounds"
    You can legally take a parts kit (or for that matter, a legally-possessed high-cap) and limit it's capacity to 10rds. It is then exempt from the sale/gift/lend restrictions, and may be used in a fixed-magazine rifle. There is nothing in the law that prohibits this. A lot of people throw around a lot of made-up "laws" about not only California, but about guns in general... they heard it at a gun shop, or from a cop, or from a friend. In general, cops and gun shops are the worst place to learn about gun laws.
    On simply "blocking", the law does require "permanence".
    This is a matter of personal comfort... what do YOU believe the arresting officer and DA are going to consider "permanent"? What do you believe the jury will consider "permanent"? How much money do you have to defend yourself?
    There are companies that make blocks that can be inserted into the spring to limit 20 and 30rd bodies to 10rds, but simply inserting one and snapping on the floorplate would certainly not be considered "permanent".
    Personally, I am comfortable with rivets, because their removal required the use of a drill. Technically, with the application of power tools, virtually nothing is truly "permanent"... but my bodies can not readily be converted back to 30rd bodies.
    Some are not comfortable with just the rivets, and instead prefer to use a block (a paint stirrer works fine) coupled with epoxying the floorplate on.
    The same methods are being used to get the Springfield XDm into the state. It is not on the roster, so we have to import it with an extended barrel (10.5" OAL) and in a single-shot form. The magazines are a secondary problem, as they are not made in 10rd, so we import the parts disassembled, epoxy spacers to the inside of the body that prevents the follower from going below halfway, and voila... we have 10rd magazines for the XDm.
  11. May 31, 2013 at 6:52 PM
    Yoshio
    Scott
    Central Coast, CA
    So I got a chance to shoot the mags @ the range, and I love them! It makes bench shooting so much better that I didn't even use my 30 round mags...
