Pneumatic Brake Fluid Bleeder with Auto-Refill Kit
Discussion in 'Technical Chat' started by NmapFE, Jul 26, 2023.
  1. Jul 26, 2023 at 11:43 AM
    NmapFE
    NmapFE [OP] Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    Just curious if anyone has used one of these and how much psi is required? I’ve a pancake compressor that goes to about 110 psi? Or does this type of tool require the larger tanks?
  2. Jul 26, 2023 at 11:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    More dependant on your compressor duty cycle.
    I've got a 30 gallon tank and if it says anything, I run it for my CNC plasma table.
    I use that same tank when I use my pneumatic bleeder and it still sets my compressor off; was bleeding rears, fronts, and lspv on my Land Cruiser if that matters.
    Biggest pain was getting a good seal on your bleeder screw but some grease and messing with the boots a bit helped.
    NmapFE[QUOTED][OP] likes this.
  3. Jul 27, 2023 at 2:15 AM
    TacoTuesday1
    FL
    Motive power bleeder
    DOT4
    Adapter
    NmapFE[OP] likes this.
