PNW MOAB 2012 SUPPLY THREAD
Discussion in 'North West' started by Twistedfreedom, Apr 10, 2012.
  1. Apr 10, 2012 at 11:57 PM
    Twistedfreedom
    Twistedfreedom [OP] welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    OK guys let's get a list of what supplies you are bringing please make a list for
    This list is being made so that we donut all have to carry 100lbs in fluids and parts for the truck more of a communal of things you are willing to share with the rest of the group if shit hits the fan.
    A) Parts and fluids for the truck
    B) Camping supplies (so we don't end up with 15 stoves and not pots or pans)
    I'll up date the list Daily!!!
    TwistedFreedom-
    Coolant x2
    CV joints x2
    Clutch x1
    U-Joints x2
    Motor oil x5
    Duct tape
    PB blaster
    Every tool I own
    Camping
    Folding table
    Ez up gazebo
    Tarp
    Cooler X2
    5 gallon water jug x2
    Tent
    Camp Stove
    Blackdog-
    a 5 gal water jug. and maybe more water.
    Some tools.
    5 gal gas tank for the trail
    Some recover gear
    IDtrucks
    some tools
    pots and pans and cooking utensils
    stove
    water jugs
    Folding table
    Digiratus
    Axe
    Shovel
    Spare fuel containers (2x 5 gal)
    Hilift jack
    Spare CV Axle (1st gen)
    Spare lower ball joints (1st gen)
    Spare U-joint (1st gen)
    Diff Oil 3 quarts
    Jumper cables
    Tool boxes
    Shop rags
    Roll paper towels
    Windex
    1/2" Cordless Impact
    Tent
    Tarps 2
    Cot
    Sleeping bag
    Air mattress and pump
    Pillow
    Blanket
    Firewood
    Fire starter
    Propane grill
    12 VDC Refrigerator (very small)
    Ice chests
    Camp chairs
    Porta Potty[/QUOTE]
    JLee-
    For the Trail
    1 spare tire
    #20 CO2 tank
    3/8" impact
    4.5" angle grinder
    Hi-Lift
    300 piece tool kit
    1 spare 1st Gen CV
    1st Gen U joints
    1st Gen lower ball joints
    800W power inverter on board
    The camp
    8' easy up
    60,000 btu camp stove with 18 " griddle
    2lb LP tank
    lanterns
    Propane grill
    10gal of water
    all the pots & pans needed
    Fire wood
    I know there is way more but it's all I can think of
    And the products for the raffle :spy:
    Max10000000s-
    I know I'm not in the correct region but FWIW IF I do show up I'll be bringing a 1/2 impact, cut off wheel, and die grinder, they'll run for short bursts on my OBA.
    I'll also have inner and outer tie rod ends for 2nd gen, spare u-joint, and a spare cv for a 2nd gen. Also have a spare idler, spare serpentine, RTV, epoxy, plugs, patches, valve stem cores, valve stem, tire iron (and a cross wrench), JB weld, random cotter pins, hose clamps, bolts and nuts, and then a bunch of hand tools. I'm sure theres other crap too.
  2. Apr 11, 2012 at 12:03 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ill have a 5 gal water jug. and maybe more water.
    Some tools.
    Some recover gear
    not sure what else at this point
  3. Apr 11, 2012 at 12:05 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Thanks Monte
  4. Apr 11, 2012 at 12:05 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    some tools
    stove
    water jugs
    (for now)
  5. Apr 11, 2012 at 12:06 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Thanks Mark
  6. Apr 11, 2012 at 12:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh yea, i can bring either a dual or a couple single camp stoves.
    gas lantern too.
    and some cooking stuff as well for a fire pit and a dutch oven or two.
  7. Apr 11, 2012 at 10:12 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    don't forget a can opener...really annoying trying to open up cans with a knife and hammer :D
  8. Apr 11, 2012 at 10:19 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    hahaha so true. or don't but canned food
  9. Apr 11, 2012 at 1:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Here is my working list: :anonymous:
    Axe
    Shovel
    Hilift jack
    Diff Oil 3 quarts
    Jumper cables
    Tool boxes
    Shop rags
    Roll paper towels
    Windex
    Tent
    Tarps 2
    Cot
    Sleeping bag
    Pillow
    Blanket
    Firewood
    Fire starter
    Propane grill
    Ice chests
    Camp chairs
    Porta Potty
  10. Apr 11, 2012 at 2:09 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Alright ya dam show off, way to make us look bad lol. I didn't bother putting personal stuff like sleeping bad and tent, just communal stuff so our camp has our bases covered
  11. Apr 11, 2012 at 2:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was just being lazy by copy/pasting from my doc. :D
  12. Apr 11, 2012 at 2:18 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    haha Yea i was trying to keep this at the communal level..
    I don't have much camping equipment out here in WA.
    But i will have a cooler and some 5 gallon water containers.
  13. Apr 12, 2012 at 10:57 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Hey, add a foldable table to my list.
  14. Apr 12, 2012 at 10:59 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  15. Apr 12, 2012 at 11:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Adam, i have a few of those pretty nice big air mattresses. Would you like me to pack one down for you and your back??
  16. Apr 12, 2012 at 11:38 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    No thanks Monte. I have a 4" memory foam pad that I'm bringing and a cot.
  17. Apr 12, 2012 at 11:42 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. Apr 12, 2012 at 12:52 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I guess Ben isn't brining anything
  19. Apr 12, 2012 at 10:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Maybe he doesn't own anything worth bringing. :notsure:
  20. Apr 12, 2012 at 10:30 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I don't have much either but i have a ton of knowledge about wiring on rigs and tools.
    I don't have a stove to cook anything on so if I could use somebody's it would be greatly appreciated I'll bring propane.
