PNW MOAB 2012 SUPPLY THREAD
Discussion in 'North West' started by Twistedfreedom, Apr 10, 2012.
  1. Apr 19, 2012 at 11:30 PM
    #61
    Twistedfreedom
    Twistedfreedom [OP] welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Dude just go, Someone will have an open seat and there will be more than enough straps and winches to get you trough a tough spot. If you have a TRD preener and have a locker you will be alight on some of the 4-5 rated trails.
    There are guys bringing bone stock 4x4s who will need to winched at strapped at some point so you won't be slowing any one down.
  2. Apr 20, 2012 at 12:41 AM
    #62
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Fly into SLC and have JasoTaco or one of the other SLC guys pick you up! :D
  3. Apr 27, 2012 at 8:23 PM
    #63
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    OK guys we're 2 weeks out do i need to update anything?
  4. Apr 27, 2012 at 9:19 PM
    #64
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you add that 1/2" impact wrench to my list?
  5. Apr 27, 2012 at 9:30 PM
    #65
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i will now I had forgotten about that.
  6. Apr 28, 2012 at 8:36 PM
    #66
    Digiratus
    Roaming the PNW
    The RedHead
    Adam, are you still planning to bring an LP tank and adapter for a stove?
  7. Apr 28, 2012 at 11:21 PM
    #67
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    no but I'll bring a few bottles of propane
  8. Apr 29, 2012 at 12:29 AM
    #68
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    IM BRINGING.....A HALF DRY ROTTED SPARE POWER STEERING BELT AND 1/4 BOTTLE OF AUTO TRANNY FLUID; AGE UNKNOWN! You laugh now, but when one of you guys need it, OH! Ill get the last laugh
  9. Apr 29, 2012 at 9:22 PM
    #69
    Digiratus
    Roaming the PNW
    The RedHead
    We are surely counting on you for that. :cool:
  10. Apr 29, 2012 at 9:27 PM
    #70
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    bring it.
  11. Apr 29, 2012 at 9:48 PM
    #71
    Digiratus
    Roaming the PNW
    The RedHead
    Finished getting my tool kit all packed up today.
    Here is the list of what is in the container:
    Folding Shovel
    Jack stands (2)
    Spare CV Axle (1st gen)
    Spare lower ball joints (1st gen)
    Spare U-joint (1st gen)
    Spare stock lug nuts
    Diff Oil 3 quarts
    Brake kleen
    Jumper cables
    Gear puller
    Spare u-bolts
    Oil pan
    Oil funnel
    Oil filter (3.4L)
    Filter clamp/remover
    Duct tape
    Windex
    Zip ties
    Work gloves
    ½” cordless impact wrench
    Grease gun
    Spare headlights
    Box cutter
    It ended up being too heavy to pick up by myself. :eek: Had to get help from my neighbor to lift it into the truck.
  12. Apr 29, 2012 at 9:50 PM
    #72
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wow mike..thats a good OSK! Wish mine was that extensive right now.
  13. Apr 29, 2012 at 9:52 PM
    #73
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I will be bringing stacks of hand tools, basic first aid kit, sawzall, hi-lift jack, cordless 1/4" impact drill, duct tape, zip ties, at least one of my old cvds (2nd gen), slide hammer, Sledge hammer, tow straps, tow chains, possibly a tow anchor. And much more
  14. Apr 29, 2012 at 9:55 PM
    #74
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Glad someones bringing jack stands, I was just thinking about that, and the grease gun, guess I won't bring mine.
  15. Apr 29, 2012 at 10:34 PM
    #75
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Already loaded and ready to go. Hi-Lift, Winch Controller, 100' of strap, snatch blocks, chain, 5 shackles, receiver shackle. 3T Jack-stands, 2 4x4 blocks, jumper cables, 8-19mm sockets in 1/4 and 3/8" shallow and deep, TQ wrench 75-250#. 8-22mm box end wrenches long and stubby, 5 ratchets: 1 1/4" 2, 3/8" and 1, 1/2" 1, 3/4" ratchets. 22-46mm I'm coming prepared for anything. 2 CV axles (2gen) 2 U joints, S. Belt (4banger w/AC) 5 spare wheels and tires.
  16. Apr 29, 2012 at 10:53 PM
    #76
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :drool:thats the kind of 4x4 box i want! Ill see what tools and thinks Im bringing when I actually start packing and get all the gear laid out. Im too busy to worry about that now.
  17. May 8, 2012 at 6:53 PM
    #77
    Btnewman
    Benjamin
    Grand Junction co
    I will also be stuffing every nook and cranny in my hotrod with fire wood
  18. May 8, 2012 at 7:40 PM
    #78
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I have fresh firewood coming in on wednesday. special delivery!
    I'll bring what I can but i'm already running out of space.
  19. May 8, 2012 at 8:33 PM
    #79
    Digiratus
    Roaming the PNW
    The RedHead
    We got you covered for firewood for tusday eve man. And we wont need any for monday eve. :cool:
  20. May 8, 2012 at 8:35 PM
    #80
    Blackdawg
    Monte
    Wyoming/St. Louis
    should i grab some then too?
