PNW MOAB 2012 SUPPLY THREAD
Discussion in 'North West' started by Twistedfreedom, Apr 10, 2012.
  1. May 8, 2012 at 8:47 PM
    #81
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Good fire starter right there..
  2. May 8, 2012 at 9:31 PM
    #82
    Twistedfreedom
    Twistedfreedom [OP] welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm bringing my pistol. :fenforcer:
  3. May 8, 2012 at 9:33 PM
    #83
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    yes
  4. May 8, 2012 at 9:35 PM
    #84
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    there is a mattress factory around the corner I'll go steal their cut offs
  5. May 8, 2012 at 10:12 PM
    #85
    Blackdawg
    Monte
    Wyoming/St. Louis
    cool ill find some somewhere. don't bother spliting it fellas..id like to try out my new axe :D
  6. May 8, 2012 at 10:15 PM
    #86
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    no problem!
  7. May 8, 2012 at 10:16 PM
    #87
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet. would enjoy the work out as well since ill be away from crossfit for a while ha.
    we are still doing hikes yes?
  8. May 8, 2012 at 10:34 PM
    #88
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'll probably get up early and go for a run... or not.
  9. May 9, 2012 at 6:37 PM
    #89
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    im bringing a second easy up
  10. May 13, 2012 at 8:59 AM
    #90
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    What am I forgetting?...
