PO installed Sway-A-Way Racerunners... do these look right?
Discussion in 'Suspension' started by 98SR5Red, Jun 24, 2010.
  1. Jun 24, 2010 at 12:23 PM
    98SR5Red
    98SR5Red [OP] Well-Known Member
    Justin
    Maine/New Jersey
    98 SR5
    Sway-Away racerunners up front, Downey leafsprings (5 pack) and Bilstein 5125's in back, 2" body lift, K&N/AEM air intake, Energy Bushings, Nology plug wires, Custom front/rear bumpers and sliders. Downey header and custom exhuast from there back.
    The guy I bought this truck off installed these racerunners and they seem to have a lot of threads showing below the coil seat... they are definitely very stiff and im just not sure if this how they're meant to be ran.
    Right
    Left
    I was also wondering when I go to have the nitrogen checked and recharged up to 180-200psi (if needed) should I have them off the truck with no compression at all or are they meant to be set to that level mounted and sitting at the intended ride hight?
    Thanks for any help! Build thread on the way...
  2. Jun 24, 2010 at 12:44 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Have you blown any CV boots yet?
  3. Jun 24, 2010 at 12:51 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    you should have the psi checked, they can do that with them on the truck.
    I cant see the pics so i cant comment on them but if your ride is too stiff then go ahead and jack the truck up and back off of them some
  4. Jun 24, 2010 at 1:00 PM
    98SR5Red
    Justin
    Maine/New Jersey
    98 SR5
    Thanks for the response guys.
    Nah, but I've also only had the truck for about 2500 miles. Does this look like too sharp of an angle for them??
    Doing this will lower the front a little bit correct? It already sets a little lower in the front and Im not sure if I want to offset it more...
  5. Jun 24, 2010 at 1:24 PM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    Your CV boot in that second pic looks really bad, but I'd let some of the other guys chime in before doing anything.
  6. Jun 24, 2010 at 1:27 PM
    NicP
    NicP Well-Known Member
    Nic
    colorado
    05 DC LB
    3" Icon CO Icon Rez and AAL ProComp 7089 BFG 285 AT KO
    CV boots do look bad ( do the piece of paper card check between the folds)and whats up with the color of those shocks? are they completly rusted? was this thing submerged in salt water?
  7. Jun 24, 2010 at 1:30 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    you'll definitely need to straighten out your cv angles pretty quick, that looks pretty gnarly. not sure about the setup, he may have them set like that for added lift which is why your ride is so stiff (coils are compressed)
  8. Jun 24, 2010 at 1:33 PM
    98SR5Red
    Justin
    Maine/New Jersey
    98 SR5
    The second picture is with the wheel turned hard left. Maybe thats why it looks way worse? And yea they are pretty rusted. Its kind of odd because this truck grew up in Georgia and the frame is SPOTLESS. Brought it to Toyota for the extended frame warranty check and they laughed at me, (still checked it of course just in case) thats how clean it is. I'm pretty much trying to decide if its worth it to buy the rebuild kit for these shocks or if there so far gone I should just go new instead. I was thinking if I rebuild them I'd just take a wire brush on a dremmel to the threads and then coat it with something to prevent it from getting so bad, as the truck will be in New England as long as I own it... Thanks again for the help!
    Oh by the way that piece of paper check on the boots is that with the wheels centered or turned hard?
  9. Jun 24, 2010 at 1:35 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    if you want it to sit level then take a leaf out of your pack. but from what others have said you will need to lower the front before you blow out one of your cv's
  10. Jun 24, 2010 at 4:17 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Doesn't the left shock have a leak?
