PO125 - Conflicting DTC
Discussion in '1st Gen. Tacomas (1995-2004)' started by loeborg, Sep 13, 2011.
  1. Sep 13, 2011 at 7:10 AM
    loeborg
    loeborg [OP] Active Member
    Greenwich, CT
    1998 Tacoma SR5
    Can anyone confirm if this is really the coolant temp sensor that goes to the ECU or is it the O2 Sensor? I searched on the forum and can't find a definitive answer. Tested Temp sensor and specs fall within specs of FSM. Also, if it is the O2 sensor is this the pre or post cat on a singe pipe 2.7? Tired of CEL staring at me.
  2. Sep 13, 2011 at 10:44 AM
    tacoman78
    tacoman78 Well-Known Member
    Bakersfield, CA
    02 Limited Dbl Cab Prerunner
    Deck Mod
    Most likely it's the pre sensor. Put your code into google and read teh first 3-5 pages that pop up. They have some good information about what's going on.
