PO125, worn out clutch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yellowdog5, Aug 7, 2025.
  1. Aug 7, 2025 at 1:10 PM
    yellowdog5
    yellowdog5 [OP] Well-Known Member
    2002 Tacoma SR5 4wd 2.7L
    Could a worn out fan clutch cause PO125? Temperature goes up to 200 at an idle, fan spins freely even when warm.
  2. Aug 7, 2025 at 6:43 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
  3. Aug 7, 2025 at 6:46 PM
    ControlCar
    Steven
    Sugar Land TX
    Cause #4 matches your description
    Let everyone know what happens
  4. Aug 7, 2025 at 7:35 PM
    yellowdog5
    For sure I will, I need to find a clutch and figure out if I can install it myself or have it done, so It may take a few days. Thanks for the info.
  5. Aug 7, 2025 at 7:57 PM
    ControlCar
    Steven
    Sugar Land TX
    Not too hard at all
    5 bolts for clutch
    4-5 for the fan blade
    IIRC
    U will have enough room without needing to take off any other components
  6. Aug 7, 2025 at 8:03 PM
    ControlCar
    Steven
    Sugar Land TX
    yellowdog5[OP] and Black97v6MT like this.
  7. Aug 7, 2025 at 8:14 PM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Finesse it off
    It may be righteously stuck upon there,... mine was :mad:
  8. Aug 7, 2025 at 8:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You'd think a worn out fan clutch would cause an overheating problem
    P0125 is a cooling system that isn't getting up to temp quickly enough and staying there..
  9. Aug 7, 2025 at 8:18 PM
    ControlCar
    Steven
    Sugar Land TX
    Mine==>
    (1st step in 4 day job to replace gushing Timing cover gaskets)
    4 out of 5 bolts were rounded off for FC
    Ugh
    Got it done with vise grips thou
    Black97v6MT likes this.
  10. Aug 7, 2025 at 8:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That code has nothing to do with the coolant temp contrary to it's generic description, It means the AFR sensor isn't responding properly.
  11. Aug 7, 2025 at 8:20 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Sounds like sum dumbasss was using an improper wrench on them nutties!
    ControlCar[QUOTED] likes this.
  12. Aug 7, 2025 at 8:22 PM
    ControlCar
    Steven
    Sugar Land TX
    Hmmm
    Interesting ^^^^^
  13. Aug 7, 2025 at 8:24 PM
    ControlCar
    Steven
    Sugar Land TX
    Not Me!!!
    Had to find new fasteners at ACE
    Black97v6MT[QUOTED] likes this.
  14. Aug 7, 2025 at 8:25 PM
    Black97v6MT
    iMA0
    tacoLand USA
    I bot my nutties from Toyota! ..
    Keep my Toyota a Toyota :)
  15. Aug 7, 2025 at 9:27 PM
    yellowdog5
    What brand of fan clutch should I get?
  16. Aug 8, 2025 at 12:22 PM
    Glamisman
    Glamisman Well-Known Member
    Interesting... only a .5v output difference between an open and shorted AF sensor, did not know that.
  17. Aug 8, 2025 at 12:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well your technically not seeing the actual output of the sensor in data, AFR sensors operate off current instead of voltage. The ECM interprets it and displays it as a voltage though.
    b_r_o likes this.
  18. Aug 8, 2025 at 12:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Weird how that code is more about 02 sensor functionality than coolant temp
    It was p0126 that I was thinking of, got confused.. That one is more common on lots of different vehicles and I believe it is more focused on actual coolant temp regulation
    Dm93 likes this.
  19. Aug 8, 2025 at 12:48 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea P0125 and P0128 on some Toyota vehicles has nothing to do with coolant temp despite it's generic description, that's why it's always a good idea to read service info instead of relying on the generic code description.
    wilcam47 likes this.
  20. Aug 18, 2025 at 6:32 PM
    yellowdog5
    I finally got the fan clutch and I installed it today, the 125 code appears to be gone, I still get po171 twice.
