PO133 oxygen sensor
Discussion in '4 Cylinder' started by PeterNM, Jun 4, 2010.
  1. Jun 4, 2010 at 10:23 AM
    PeterNM
    PeterNM [OP] Active Member
    New Mexico
    97 Tacoma LX, 4X4, 248,000m
    AFE Drop-in
    my temp gauge has been bouncing around and the scan came up with ho2s11...so i change out the o2 sensor and the temp gauge is still up and down...(when i change the 02 sensor...the bolts broke, the sensor is now held on with hose clamps)....is it because its clamped on or do i have problem??
    also how do repair the broken bolts??
  2. Jun 4, 2010 at 12:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    To repair the broken bolts, You'll have to drill them out, and install a helicoil, or re tap the holes.
  3. Jun 4, 2010 at 1:48 PM
    PeterNM
    New Mexico
    AFE Drop-in
    thanks chris....any ideas on the fluctuating temp gauge???
  4. Jun 4, 2010 at 2:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bad sending unit maybe.
  5. Jun 4, 2010 at 3:24 PM
    PeterNM
    New Mexico
    AFE Drop-in
    by sending unit do you mean o2 sensor??
  6. Jun 4, 2010 at 3:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. THe temperature sending unit.
