PO171 OBD2 Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by NLamb1978, Apr 11, 2010.
  1. Apr 11, 2010 at 3:40 PM
    NLamb1978
    NLamb1978 [OP] Member
    Nicholas
    NC
    96 4x4 2.7L Ext Cab
    Was having some recent trouble with a bad plug wire that threw me a PO301 Code and before that it was a PO420 code. Replaced the cat converter and the plug wires. Took about a 40 or so mile trip today and on the way home of course the CEL came on again. Just been one of those months. Got home with no problems, truck ran like normal. Hooked my scanner up and looked up the trouble code. PO171 System Too Lean (Bank 1). Not really sure what to do about this. I cleared the fault. Then took about a 6 mile trip to the gas station with no problems. Any thoughts would be welcomed.:confused:
  2. Apr 11, 2010 at 3:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    Clean your MAF sensor.
  3. Apr 16, 2010 at 3:38 PM
    NLamb1978
    Nicholas
    NC
    96 4x4 2.7L Ext Cab
    Seems that the CEL only comes on when I go for wide open throttle.
  4. Apr 16, 2010 at 3:41 PM
    98tacoma27
    Ben
    Not Beech Creek
    The sensor can't read either the air flow or temperature. It's probably dirty
  5. Apr 16, 2010 at 3:55 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    x2....had this on my old 2000 V6, it fixed "my" P0171 issue.
