PO303
Discussion in 'New Members' started by LIRR, Feb 18, 2015.
  1. Feb 18, 2015 at 11:23 AM
    LIRR
    LIRR [OP] Member
    Brian
    Pa
    02 SR5 Taco w/alts
    GREETINGS EVERYONE.....NEW MEMBER HOPING I CAN GET SOME HELP ON A 02 TACO I JUST PICKED UP (115,000 miles).
    1) On the way to work I filled the tank with gas (truck running normal).
    2) On the way home started running raggy.
    3) Stopped at the store and put some HEET in the tank (thinking water in the gas).
    4) Got home and read with a scanner. Read PO303,PO505 and a PO420. Also I lose my heat after 2 minutes???????
    P L E A S E H E L P !!!!!!
  2. Feb 18, 2015 at 11:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    The 505 code is for the IAC, the 303 is for #3 misfire, and the other is cat system below efficiency. Check the first 2, and see if the last one doesn't go away.
  3. Feb 18, 2015 at 2:57 PM
    LIRR
    LIRR [OP] Member
    Brian
    Pa
    02 SR5 Taco w/alts
    I swapped #1 & #3 coil packs, I need to get myself a scanner to see if I now have a #301.
