po303
Discussion in '1st Gen. Tacomas (1995-2004)' started by LIRR, Feb 18, 2015.
  1. Feb 18, 2015 at 5:25 PM
    LIRR
    LIRR [OP] Member
    Brian
    Pa
    02 SR5 Taco w/alts
    Anyone know the ohm reading on a 2002 taco coil pack over spark plug?
    :cool: :D:D:D:D:D:D:D:D:D:D:D:D:D:rockband:
  2. Feb 18, 2015 at 6:30 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Check all the other ones and see.
  3. Feb 19, 2015 at 11:52 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Most likely a bad fuel injector. I kept getting a P0301 "Misfire Cylinder 1" replaced all 6 injectors and no code since. Hope this helps.:)
  4. Feb 19, 2015 at 12:11 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Cold - (14-122 F) 0.67 - 1.05 Ohms - Primary
    9.3 - 16.0 Ohms - Secondary
    Hot - (122-212 F) 0.85 - 1.23 Ohm - Primary
    11.7 - 18.8 Ohms - Secondary
    Sourced from 2002 Tacoma FSM, Ignition System - On-Vehicle Inspection
    Good luck
