PO402 and PO135
Discussion in 'Technical Chat' started by PacNWgen1, Oct 6, 2010.
  1. Oct 6, 2010 at 11:55 AM
    PacNWgen1
    PacNWgen1 [OP] NewHere
    Adam
    Oregon
    96' Tacoma Reg Cab 2.7l 4x4 5-speed 150,000+
    DynoMax ST, Deck Plate, Full Syn, Soon Header and Slotted Rotors
    1996 2.7l....Seems to run better when cold or let it rest. If I drive for 20 or 30 minutes straight it starts falling on its face and stubbling at partial throttle and will clear up at full throttle.
  2. Oct 6, 2010 at 6:05 PM
    PacNWgen1
    Adam
    Oregon
    Any ideas? Think I might try and replace the vac lines tomorrow.
  3. Oct 6, 2010 at 7:29 PM
    98tacoma27
    Ben
    Not Beech Creek
    Your AFR sensor is shot. That's the 135 code. The 402 is the EGR system. It is more than likely a result of the AFR malfunctioning.
  4. Oct 7, 2010 at 11:24 AM
    PacNWgen1
    Adam
    Oregon
    Thanks..... Is there any way to test it? Or just buy one and put it in?
  5. Oct 7, 2010 at 11:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can check the resistance of the heater, but that's about it unless you have access to an advanced scanner like the dealers have.
  6. Oct 10, 2010 at 9:32 AM
    PacNWgen1
    Adam
    Oregon
    I have just replaced the AFR sensor within the last year but I put in a new header recently and some one in town here told me if I put it in wrong it could burn it up quick. Is there any truth to that? I will check the resistance today. Thx
  7. Oct 10, 2010 at 9:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only way to "Put it in wrong" is to have leaks....Headers only can fit one way....
