PO420 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gen1tacotime, Sep 17, 2016.
  1. Oct 2, 2016 at 8:43 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Oh that sux.
    I got 6 foot leads for my fluke, and a variety of probes...
    Thanks for this heads up... I'm gonna have a look see after the motor cools
  2. Oct 2, 2016 at 10:30 AM
    Larzzzz
    Larry
    MA
    So, nothing out of the ordinary with the connectors. They were locked, pins clean and secure, seals intact. Thought the upstream AF sensor wasn't locked, but it was. Went ocd and checked others too. Lol
    Meter is at work so can't check continuity.
    And, I can't find the port to purge the fuel rail, connect a tester... Did they bury it under all that plastic plenum, air filter box?
  3. Oct 2, 2016 at 12:58 PM
    gdctaco
    gdctaco Well-Known Member
    georgetown, ont
    06 access cab 4x4 O/R
    rr diff mod in-cab 110
  4. Oct 2, 2016 at 1:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here is a question that maybe has been asked but maybe I missed, what kind of aftermarket cats are those?
    USUALLY aftermarket cats are so small, that the amount of material in their oxidation beds available are not enough to keep up with the amount of emissions put out by the engine. This is also why I have never liked installing aftermarket cats in vehicles when it comes to making sure that they have the longevity there to last the engine another 150K.
    Now. Why cats fail other than excess mileage put into them is usually due to a poor AFR and that usually fals directly into either poor performing oxygen sensors or an engine misfire due to either worn out secondary emissions or poor engine maintenance. Assuming you kept up with proper maintenance and your engine is in good working condition I would almost always recommend a cat converter AS WELL AS both upstream and downstream oxygen sensors. Afr sensors are known to have degraded performance under mileage in excess of 80K. We are equipped with them, so. Take this advice for what it is worth.
