PO430 CODE AFTER INSTALLING OIL CATCH CAN
Discussion in 'New Members' started by jakey& 4, May 29, 2024.
  1. May 29, 2024 at 9:47 PM
    jakey& 4
    jakey& 4 [OP] New Member
    Jake
    2021Tayota Tacoma SR
    2.5" LIFT, VIVID COIL PACK, & EXHAUST
    I have a PO430 Code that will not completely clear. It comes on every few days. I reset it but it will not clear. A friend of mine was telling me it might not clear, due to it might be a Hard Code that can only be cleared by Dealer or High Tech. Decoder. Help
    buckhuntin-tacoma likes this.
  2. May 30, 2024 at 2:49 AM
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    FYI - You'll likely get a much faster response if you post in the 3rd Generation Tacomas Forum. Click 'Forums' on the main page and select from the drop down menu :thumbsup:
  3. May 30, 2024 at 4:58 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  4. May 30, 2024 at 5:11 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Make sure you have no vacuum or exhaust leaks, or inadvertently fiddled the sensor wiring/connector. otherwise look at the live data for the downstream O2 sensor on that bank. It should be pretty flat, if it looks like a sine wave then you may have coincidentally encountered a failed catalytic converter.
    It wouldn't hurt to remove the can and recheck. At the least it's a good idea before going in for warranty.
  5. May 30, 2024 at 5:22 AM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    I fought that on my Tacoma when the cats needed replaced.
    It's not a "hard code". But, your ecu will attempt to run a cat system efficiency test every time you drive it. It first verifies other sensors (O2) are working properly, the engine is hot, and other parameters are met. Then it runs through the system efficiency test. If it fails it sets a code.
    If you only take short trips, it won't be able to run the test so your reset CEL will stay off. Once you take a longer trip it will get the test in and if there is a problem it will set the code again.
    I found it helpful to buy a scanner that allows you to see actual values instead of just what the code is. The BlueDriver Pro is what I bought. $99 on Amazon. It gives you a lot more information than a standard reader.
    Basically that allowed me to see that my cat efficiency was no where close to being good enough to pass. Then I checked toyota's site that lists outstanding recalls, entered my VIN and found out there was a recall for poor cat efficiency that my Taco had never been back for....so a local dealer replaced all 4 of them for free on a 10 year old truck I had owned for about a month. I got lucky. I got VERY lucky.
    joba27n likes this.
