PO430 Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbarone1994, Apr 16, 2016.
  1. Apr 16, 2016 at 5:25 PM
    danbarone1994
    danbarone1994 [OP] Well-Known Member
    Daniel
    2019 Toyota Tacoma Gray TRD OR V6 double cab
    LED headlights, TRD PRO grill, Spacer kit 2 in lift front
    I parked my truck today as the check engine light turned on. Scanned it and thats the code that came up... PO430 Cat Below Threshold Bank 2
    Any advice on what is most common fix?
  2. Apr 16, 2016 at 10:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is an exhaust leak.
    An oxygen sensor is not reading (functioning) properly.
    The catalytic converter is no longer functioning properly.
    Check the above in order from most likely ( cheapest ) to least likely ( expensive ).
  3. Apr 17, 2016 at 7:56 AM
    danbarone1994
    Daniel
    I was thinking the O2 sensors but how can I check those just pull it out? I do not have a scanner to see O2 activity.
  4. Apr 17, 2016 at 7:57 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  5. Apr 17, 2016 at 3:14 PM
    Klaunch
    Klaunch Member
    Is there a way to check the o2 sensor with a meter to see if it's still within spec?
  6. Apr 17, 2016 at 8:41 PM
    danbarone1994
    Daniel
    I checked O2 sensors with a scan tool at work both S2's are bad so I am replacing all 4 as the truck is at 222,279 miles.
  7. Apr 18, 2016 at 1:11 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    In order to check the O2 Sensor correctly you need live data with a scanner tool or software.
  8. Apr 18, 2016 at 1:15 AM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    Sensors don't usually go bad unless you see physical damage. Do as others have instructed. Plus check vacuum leaks, fuel leaks, even low fuel.
    I'm pretty sure I finally pin pointed my code. I'm getting 5 gallons per hour.
  9. Apr 18, 2016 at 9:42 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    My 05 with a little less miles than you had a bad head gasket, which blew out the material in the cat, and threw the same error code as you. i would check your engine out to see if your cats are blown out, and go from there to see if your head gasket's are OK.
  10. Apr 18, 2016 at 9:52 AM
    danbarone1994
    Daniel
    The O2 sensors are bad I checked them at work yesterday and they don't read at all. The post cat ones but I think I'm going to replace all 4 O2's because my mileage
  11. Apr 18, 2016 at 3:05 PM
    danbarone1994
    Daniel
    O2 Sensors are working fine now! I sprayed them with water to clean off the dirt and no more code! Driven about 45 miles so far and code has not come back.
  12. Apr 19, 2016 at 12:42 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    You'll have to give it some time.
    O2 sensors don't fail hard; I went thru a huge icy puddle (07 highlander) and the code was thrown immediately; check engine on. Drove for a while and the post-cat O2 must have dried out and check engine off; 2 weeks later back on; next day, check engine off. Finally had dealer check it ( CE stayed lit). Replaced post-cat O2 and problem solved.
    Post-cat O2s get the most punishment with water, maybe stone strike if your unlucky, etc. Dealer will try to sell you a CAT which is likely BS. Also if you bust a head gasket the antifreeze will damage the sensors, but maybe not the cat.
    Good luck.
  13. Apr 19, 2016 at 3:48 PM
    danbarone1994
    Daniel
    Going on 70 miles now no light and all systems are ready and O2's are reading properly
  14. Apr 19, 2016 at 6:56 PM
    jedirye
    jedirye Wannabe
    Florida
    2013 Baja Supercharged
    I had a P0420 (the other o2 sensor). My catalytic converter was bad. It was under warranty, so meh.
  15. Apr 22, 2016 at 7:24 AM
    danbarone1994
    Daniel
    So far so good about 120 miles of driving now and no check engine.
    BlueT likes this.
  16. Apr 23, 2016 at 8:06 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Good job, that is nice, never would have think to clean them with water.
  17. Apr 23, 2016 at 1:54 PM
    danbarone1994
    Daniel
    Thanks! Yeah just clean off the dirt on outside of the O2 sensor. The sensor reads the exhaust and compares it to the ambient temp but if it is covered in dirt then it can not read ambient.
    desertjunkie760 likes this.
  18. Sep 2, 2016 at 2:26 PM
    Oaklandtaco
    Oaklandtaco Member
    Dan
    2006 v6 4.0 prerunner
    So you took the sensors off? Or just cleaned the outside of them? I have the same code and doubt it's the cat. 195k miles
  19. Sep 2, 2016 at 8:34 PM
    danbarone1994
    Daniel
    I just sprayed water on the outside of them without removing to remove dirt from the tops of them. Still running with no codes 1,500 miles later.
