PO441 and 455 Codes in my 06..Anyone ever had these codes before?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeffallen29, Nov 29, 2012.
  1. Nov 29, 2012 at 11:02 PM
    jeffallen29
    jeffallen29 [OP] Well-Known Member
    jeff
    northeast Tennessee
    I just got these codes on my 06 Tacoma V6 and it runs the same as usual but I can tell the fuel mileage is suffering.I believe these codes are dealing with the Evaporative canisteris bad or has a leak somewhere.Was just wondering if any of you all have had this code / problem before and what fixed it.Thanks everyone!
  2. Nov 29, 2012 at 11:49 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
  3. Nov 30, 2012 at 2:09 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Here is the OBDII code list. And some Evap system info. 9 times out of ten, you got the code because your fuel cap wasn't tightened all the way. Also be careful of trying to get the "perfect pump" and over filling. Although the baffle isn't supposed to allow fuel into the evap system, it can happen. When the pump shuts off, you're done.
    OBDII Error Code List.pdf
    P0450 P0451 P0452 P0453.pdf
    P0455 P0456 P0500.pdf
    Frank
    milehitaco likes this.
  4. Nov 30, 2012 at 6:13 AM
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    When I had my 06 I had those codes it was a bad gas cap. Bought another Gas cap from dealer happened again. I bought one from Autozone and it never happened again.
  5. Nov 30, 2012 at 9:01 AM
    Smoke2
    Smoke2 Well-Known Member
    Tacoma
    07 DC 4X4 LB
    Rear TSB, Firestone Air bags
    Put some grease on the gas cap gasket and retighten and then disconnect battery for a couple of minutes. The check engine light should go away. If not replace gas cap.
    I have done this with mine, another friends tacoma, and another fj.
