Pod Lights with Back lighting
Discussion in 'Lighting' started by MtbRob80, Oct 21, 2021.
  1. Oct 21, 2021 at 2:54 PM
    MtbRob80
    MtbRob80 [OP] Member
    @Diode Dynamics makes a few different models with ON/Off and Back Light,
    I would like to pick some of these up and use a OEM style Tacoma Switch similar to what Cali-raised and CH4x4 put out.
    Any one make a 3 position switch that retains OEM look?
    If you have lights with back lighting how did you wire them up?
  2. Oct 21, 2021 at 7:52 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    you could wire it to the backlight with your running lights then switch the actual light
  3. Oct 29, 2021 at 2:26 PM
    patchesj
    patchesj Well-Known Member
    Check out the Baja designs website on the LPs. They have some diagrams for the same type of use case. I know there are issues if you power both the high and low sides at the same time, so they use some fancy relay trickery....
