Pointless?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoLvR10, Jun 25, 2012.
  1. Jun 25, 2012 at 3:17 PM
    tacoLvR10
    tacoLvR10 [OP] Active Member
    I have a 2010 tacoma 4x4 sr5, the thing is it's a 4banger. is it pointless for me to put bigger wheels and tires and lift it a bit?:confused:
  2. Jun 25, 2012 at 3:22 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    SoCal - Fontana
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    No. If you can afford it why not... it is 4x4 right? Putsome new shoes on and take it to the mud and trails. If you never plan on ever using 4x4 and its your daily driver then yes IMO its pointless.
  3. Jun 25, 2012 at 3:24 PM
    Aw9d
    Aw9d That one guy
    Az
    Some of the guys here in AZ have 4bangers and you'd be shocked on what they can get up and over. If you wheel a lot, go for it. If you daily drive, don't waste the cash.
  4. Jun 25, 2012 at 3:26 PM
    tacoLvR10
    Appreciated!!
  5. Jun 25, 2012 at 5:50 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Lifting a Smart Car and putting big tires is pointless. On your truck it's not, do it up!
  6. Jun 25, 2012 at 6:38 PM
    red06toy
    red06toy Well-Known Member
    Worcester MA
    Impulse red OR, 2.5 lift
    2.5 toytec, bilstein 5100 black grille, black lights, partially shaved decals remaning ones black, , trd fj wheels, sirius, Ipod interface, pre-filter delete
    Dont forget, guys were putting 33s on trucks with the 22RE engines back in the 80s, those trucks hauled and off roaded just fine.
  7. Jun 25, 2012 at 6:39 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Why would engine size make it pointless to get a lift? The point of lifting is fitting larger tires and increased ground clearance.
  8. Jun 25, 2012 at 6:53 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Or 37's. Keep it mild, or re-gear accordingly, and you'll be OK. Better than OK actually.
  9. Jun 25, 2012 at 6:59 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    You're good...as long as you'll use it it isn't pointless...
  10. Jun 25, 2012 at 7:35 PM
    badger
    badger Well-Known Member
    07 SR5
    It's not pointless, but having a 4 banger means that such changes will have potentially greater consequences. Most any activity that requires power from your truck will demand a gearing change. Tires without gears can also wreak havoc with fuel economy. Bigger tires weigh more, whcih will also tax the engine. Generally a bigger tire will require slightly lower final gearing than stock to compensate the weight. Do you tow? Do you live at higher altitude? Do you care about performance at all? Some people don't as long as they look good. All things to consider.
    I would do some research and some thinking before jumping to do this. You could end up causing a problem that will demand yet another big lay out in cash that you did not budget.
    As far as the 22RE with bigger tires, the ones without gearing could be passed by a volkswagon bus on any discernable grade.:rolleyes:
  11. Jun 26, 2012 at 6:54 PM
    tacoLvR10
    any suggestions on what i should run as far as size of wheels and tires, and how much i should lift it?
  12. Jun 26, 2012 at 7:22 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2003 TRD
    Do it man!!
    Get gears and you'll have all your power back.
  13. Jun 26, 2012 at 7:24 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    +1
  14. Jun 26, 2012 at 7:26 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    my reg cab was a beast with a 3" lift and 285s, but got worse gas mileage than my current Dcab TRD OR, prob because it worked double overtime lol..
  15. Jun 26, 2012 at 7:26 PM
    Spoonman
    Jamie
    Calgary
    2003 TRD
    I had 35s with 4:10s in my 22r....fawking gutless but it did the job offroad. Only could hit 50 on the highway..downhill
  16. Jun 26, 2012 at 7:28 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    You should see what some of us retards have done to our 2.7L, 5 lug trucks. Do as you please.
  17. Jun 26, 2012 at 7:31 PM
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    daystar level kit, tsb rear spring, ghostflames, sport hood, tsb steering, trd cai, red map lights. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall
    22r was 80 horses from the factory
  18. Jun 26, 2012 at 7:32 PM
    Spoonman
    Jamie
    Calgary
    2003 TRD
    Oh god...only gear I DIDN'T bog down in, was 1st gear 4low
  19. Jun 26, 2012 at 7:36 PM
    Ridgerunner
    Frank
    San Francisco
    Back in the day I had a 1986 GMC Jimmy with 33s. It had the 305 v8 but it was only 155hp and around 244ft lbs torque, weighed almost 1000lbs more than your 4-banger truck, and did fine but was a slug. It's a tradeoff. But you will be badass.
  20. Jun 26, 2012 at 7:42 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I'm running 32" Hankook Dynapro ATM's with the truck leveled out using the Bilstein 5100's. Personally I love the look and the truck still has plenty of get up and go.
