Polaris Ranger 500 Gas In Oil Tank
Discussion in 'Off-Topic Discussion' started by Bleep100, May 25, 2019.
  1. May 25, 2019 at 2:28 PM
    Bleep100
    Bleep100 [OP] TOYOTA 4 LIFE
    17 Sport
    I have a 2009 polaris 500 efi utv and noticed a leak from the oil tank . Checked oil level and over full and smells like gas . Might be injector not sure just found it . Was checking to see if anyone had this problem and how they fixed it and how difficult . Thanks .
  2. Jun 1, 2019 at 6:31 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. Jun 1, 2019 at 6:51 AM
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    I’ve had that problem in my Honda rancher. I attributed it to running ethanol gas. So I didn’t drain the carburetor when I was done riding and it sat for a while. the rubber on the float shrunk and gas must have drained past the rings or something. Idk. My solution was to run non ethanol gas always and I haven’t had a problem since
    Bleep100[OP] and wilcam47 like this.
  4. Jun 26, 2019 at 8:01 PM
    Bleep100
    17 Sport
    Had the UTV fixed at the dealer . Mechanic said the only way gas got in the oil tank was through the injector . He took it out and cleaned it and pressure tested it and said its working fine now . He drained the gas tank and changed the oil and filter and reinstalled the injector . He said those injectors last 1000 --- 1500 hours and mine only has 128 hours and at a price of $220 we are just going to try the old one again . There it is for now , GL with yours .
    wilcam47 likes this.
