Police center console....
Discussion in '1st Gen. Tacomas (1995-2004)' started by csxrailfan, May 9, 2009.
  1. May 29, 2009 at 7:58 PM
    csxrailfan
    csxrailfan [OP] Active Member
    North Cackalacky
    2021 Toyota Tacoma DBL CAB TRD / GONE: 2002 Toyota Tacoma Access Cab TRD, 2011 Tundra TRD
    Ok here are my first impressions. Keep in mind that I only sat the console into position for the pictures. It is not mounted in any way. The console does fit. It is a very snug fit at that. I did have to remove the plastic molding on the inside of the seats towards the transmission hump. The length is ok and allows for many radios and other console options. It could actually be a little longer but for the price it is just right. The cobra 29 LTD in the picture gives you an idea of just how much room you have to play with. This particular console is adjustable for height. That is a good thing seeing as it appears that for that CB to fit it needs to be pretty deep. The face plates that screw to the top of the console and hold the radios in or cover the holes are easy to come by on ebay or easily fabricated. Troy industries, havis shields, and stewart industries accessories will all work on this unit. I intend on getting cupholders and an armrest for mine. This unit does not interfear with the shifters and does not get in your way as far as confort. As I said, it is very snug. If you are someone that adjusts your seat all the time then over time I could see it maybe wearing into the side of the seats a little. This console didn't come with any of the faceplates or the long flat mounting plate used in most applications. It doesn't have the mounting plate but I will probably try to find one. If you guys have any more questions let me know.
  2. Feb 21, 2012 at 6:14 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I realize I'm only 2-1/2 years late, but I will be fabricating one! Second gen tho.
