polish and wax
Discussion in 'Detailing' started by alexander323bc, May 9, 2011.
  1. May 9, 2011 at 9:04 AM
    alexander323bc
    alexander323bc [OP] Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Ok I know this seems silly but I have never really fully polished and waxed a vehicle. I just Polished and waxed and my moms 4 runner for mothersday and while its super shiny and nice I see some swirls and smudges at certain angles. When I do my tacoma ( metallic gray) I would like to avoid this. Did I just used too much polish or wax and it wasn't buffed it correctly?
  2. May 9, 2011 at 9:23 AM
    JeanClaude
    JeanClaude Well-Known Member
    East Atlanta
    2009 Tacoma Prerunner
    You probably didn't use a true polish that levels clear coat. Also, removing scratches and swirls by hand is practically impossible.
    Here is some good information on paint restoration. http://detaileddesignsautospa.wordpress.com/
  3. May 9, 2011 at 10:24 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thanks for the info excellent article. I just got my truck in november its 2011 I have only washed it a few times, but never used a clay bar or waxed it yet. Going to do this in a few days when I get some time. Just trying to avoid any swirls or smudge marks that I can. Thanks for all the help.
  4. May 9, 2011 at 10:33 AM
    SPORT
    SPORT Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    I ONLY use McGuires.
    Try using Swirl-X to remove those swirls.
  5. May 9, 2011 at 1:00 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I guess I wont know if I have swirls in the paint until I polish it and wax it first. I would like to use a machine but I don't really want to pay the 200 dollars for a good DA right now. I will just polish and wax and If I get swirls I will try the Swirl X and if the problem persists I will have a professional detailer look at it. The paint shouldn't need to be fixed proffessionally if the truck is only 4 months old. I would hope anyway!
  6. May 10, 2011 at 3:18 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Sears sells a good Craftsman product for under $90. Worth looking into; especially if you charge several friends to polish their vehicle. :D
  7. May 10, 2011 at 3:35 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
  8. May 10, 2011 at 3:40 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
  9. May 10, 2011 at 4:26 AM
    morrison14
    morrison14 Active Member
    Charleston, SC
    11 DC PreRunner SR5
    starting soon......
    Hopefully you haven't used towels or other junk to clean your car previously. Get some terry cloth or microfiber to use on the car. Regular bath towels can scratch the sh*t out of your clearcoat, giving you swirls and scratches. Meguiars and Mothers both make great products. I have even heard the new Turtlewax Ice is nice. My truck is a month old, and I just hand waxed it last night; no polish. It took me about 2 hours and turned out awesome. As long as you use the right tools for the job, you should be alright.:D
  10. May 10, 2011 at 4:41 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    No towels used on this truck. When it was washed it was washed twice on the 2 days it was above 35 this winter in a touch less car wash. I did use a 100% Egyptian cotton towel to dry my moms 4 runner other day before I used a clay bar. I hope I didn't scratch it :( Thanks for all the info on the polishers I will look into it more when I get my bonus next month!!!
  11. May 10, 2011 at 5:15 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Agreed about the porter cable. Please trust me here. Do NOT waste your money on the "orbital buffers" from sears, home depot, pep boys, etc. They will do absolutely nothing for you if you plan to properly maintain your finish. Aside from a lack of power, the availability of proper pad selection is practically non existant.
    The porter cable has the ability to swap backing plate sizes, and the amount of pads available for it are endless, allowing you to fine tune the polish, compound, glaze and wax applications.
    That being said, if you polished your mom's ride by hand, the swirls can be a few things. For one, it may be some surface marring that you induced by using poor applicators/towels. Another may just be that the product wasnt fully broken down, resulting in the holograms that you're seeing. Either way, it'll be easy to remove if you wanted to re-do it.
    You can get really carried away w/ the available products and application of them, so I recommend doing a little research on the detailing websites first. Assess what you truly need and go from there.
  12. May 10, 2011 at 5:26 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Chris thanks for all the info! I am really looking at the porter or maybe I might go all out and get a flex if there is a lot of difference? I used duragloss 901 wash, meguires clay kit, meguires color x polish and used the the new ultimate liquid wax. I tried to use the best over the counter products. I have a lot left over and plan to use these on my tacoma as well. I think I may have just used to much polish and wax I dont think I applied it very thin in some spots and that may be part of the issue.
  13. May 10, 2011 at 5:44 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    I've had every machine on the market, and imo, the easiest to use is the porter cable. Although the extra power on the flex is nice, I dont personally believe its worth the added $$. Once you use up your current products, you may want to look at detailed image. They're in upstate NY so you'll get products the next business day.
  14. May 10, 2011 at 6:06 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thanks for all the info Chris! Porter and cable it is. I actually live in upstate new york so I will definitely check them out.
  15. May 10, 2011 at 6:53 AM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    I picked up a porter cable a couple weeks ago and i love this thing.I have never really polished a car/truck with a machine before always by hand but the porter cable 7424 did a great job,very easy to use and i didn't have to worry about burn through the clear-coat
    I got it from
    They also have package deals for pretty much anything you need to do ..
  16. May 10, 2011 at 7:49 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thanks Johnny I am going to get one just want to wait until my bonus gets here. between all my summer trips and all other expenses. I am just going to do the first polish and wax by hand but I will get one! Thanks for all the info guys. What polish and wax did you use? what color is your truck?
  17. May 11, 2011 at 5:46 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
  18. May 11, 2011 at 6:27 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Amazon has them for $119 shipped also. Make sure you get a velcro adapter though, as most of the "good" pads are hook and loop type. This usually brings the price back into the price range of the other vendors listed above. After you add pads and other stuff you are then back into the package price ranges.
  19. May 11, 2011 at 6:54 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Lurkin thanks for the all info! I will most likely get one of the packages from autogeek and just make sure i get the velcro adapter.
  20. May 12, 2011 at 4:37 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Yea, sorry, I should've mentioned that. You want the flexible backing plate. 4.7/8 if you want to run a 5.5" pad (which I'd recommend). You can use a 6" pad, but I personally find it too large for the pc. If you need to fit in to tight areas, a 3.5" backing plate w/ 4" pads is the setup.
    Remember, with a PC, the smaller the pad, the more heat it will generate, which is opposite of rotary polishers, which have increased heat as you increase pad diameter.
