Polishing OEM Flat Aluminum Wheels?
Discussion in 'Detailing' started by stewartx, Jan 29, 2012.
  1. Jan 29, 2012 at 6:14 PM
    stewartx
    stewartx [OP] Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    The stock aluminum wheels on my 2012 Tacoma OR are flat and dull (by design). Is there any way to polish these to a high gloss?
    1. Have anyone actually done this?
    2. What method would you recommend, assuming tires will remain on wheels (no way to remove) and I want enough control to only polish very outside surfaces?
    3. Are there any risks to this idea?
    Thanks for any feedback, guidence, or suggestions.
  2. Jan 29, 2012 at 7:43 PM
    lowstature
    lowstature FNG
    Karl
    Colorado Springs, CO
    2012 DBL Cab
    3" lift Add on back-up Camera 18" off road wheels N-Fab bars
    The stock wheels have a clear coating over a slightly ribbed machine cut wheel. This causes two problems... 1st, for shine, you want a smooth surface, 2nd, since they are clear coated, you have to strip the coating off to polish them.
    If you have nothing but time on your hand, I would recommend buying a used rim from someone on the site. You can strip it, sand it, and polish it and then have it switched out with the next one you do.
    That is a lot of work, I would consider having them painted a different color vs stripping and polishing them. If shine is your thing, you might find someone willing to trade you for something else chrome instead, that would be much easier and there are a lot of options out there.
  3. Jan 30, 2012 at 8:55 PM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island--->Oahu, Hawaii
    10 AC TRD OR 4x4 BSP; 08 Reg Cab 5 spd 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Smoked Eagle Eyes Ebay LED Tails | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    I detailed my stock TRD Off Road rims during last summer. I used polish, wax, and sealant. It worked pretty well, it looks a bit more shiny than it was before and the rims bead water now.
  4. Jan 30, 2012 at 11:47 PM
    stewartx
    Huntsville AL
    Thanks for the replies, guys. It's not a big deal, so I may just leave it as it is. Just had an impression the wheels were shinier, so was a bit surprised when the vehicle arrived.
    On the other hand, might just go at it with fine sandpaper and emery cloth attached to a drill, followed by polish and sealant. Not today though. :rofl:
  5. Jan 30, 2012 at 11:53 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
    Do you mean shiny like the TRD Sport wheels?
  6. Jan 31, 2012 at 12:18 AM
    stewartx
    Huntsville AL
    Yea, something like that - high-gloss aluminum wheels. Toyota had one or two such wheel options for my truck, but, again, I was under the impression the included wheels were already a bit shinier.
