POLK Audio Upgrade Questions
Discussion in 'Audio & Video' started by tdswimin8, Apr 16, 2012.
  1. Apr 16, 2012 at 4:13 PM
    tdswimin8
    tdswimin8 [OP] Well-Known Member
    Tony
    Davis
    2008 4x4 Tacoma SR5
    Sway Away Coil-overs & Shocks, Cobra CB, Integrated VHF, BRUTEFORCEFAB front bumper on the way!
    Hi Guys, I have a decent amount of experience putting in stereo's and speakers but not enough to start this without some advice. I am upgrading my speakers in my 08' Double cab.
    I am putting Polk Audio db 6.5 components in the front and polk db 6.5 coaxial in the back.
    http://www.crutchfield.com/p_107DB6...lk+Audio+VENDORID107&searchdisplay=Polk+Audio
    I have upgraded the head unit to a Kenwood KDC-BT852
    http://www.crutchfield.com/p_113BT852HD/Kenwood-KDC-BT852HD.html?tp=5684
    1. So through some research I have noticed that people highly recommend the ********* speaker mounts, are those worth it? They are pretty expensive so I just want to see what you guys had to say. Are there any others out there that are good?
    2. Should I get an amplifier? I have no problem buying one if it will make the sound better or improve the life of the speakers, however if theres not much of a difference I would rather not go through the hassle. If you think i should, do you have any suggestions on brand how to wire it?
    3. I eventually want to get a double din head unit, but not for a while till the $$ appears, will that change the speaker quality if I do not have an amp? assuming that the output from the head unit will change..
    Thanks again for all your help in advance guys
  2. Apr 16, 2012 at 4:20 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Hi Tony, I've got pretty much the same speaker setup., but I've got an Alpine head unit and a 4 channel Alpine amp. The amp really made a big difference in the speakers. My amp is 50 X 4, mounted under the drivers seat. This is the only picture I have of it.
  3. Apr 16, 2012 at 10:56 PM
    tdswimin8
    Tony
    Davis
    2008 4x4 Tacoma SR5
    Thanks oldtacomaguy!! how did you mount your amp?
  4. Apr 17, 2012 at 9:03 AM
    81shark
    81shark Well-Known Member
    i have polk db6501 components in both the front and rear. i would recommend amping them. they can take 100 watts rms, while the hu is only going to give them 22 rms. let em breath ha
    i would recommend a sub with these speakers. they are ok for mid and highs but the base in them sucks.
    i've got an alpine pdx5 under the driver seat. for mounting, mine just sits there. no issues in the two years it's been there.
  5. Apr 17, 2012 at 9:29 AM
    oldtacomaguy
    Dave
    SE Conn.
    What he said!:)
  6. Apr 17, 2012 at 9:31 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I put two strips of MDF under the carpet to mount mine, just enough to make it not move around.
  7. Apr 17, 2012 at 9:33 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Another thing I noticed... The components you picked have about twice the wattage needed to run.... You should really find a set that matches...
  8. Apr 17, 2012 at 1:59 PM
    tdswimin8
    Tony
    Davis
    2008 4x4 Tacoma SR5
    Ok looks like I will be getting an amp, any ideas on type? Also how do you wire it to the speakers and everything? I know how to get it power from the battery but not really anything else.
    Chadderkdawg- are you saying I should have the components in both the front and rear? I can always return either if I need to but let me know what you guys think
  9. Apr 17, 2012 at 7:11 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    No, you just need to match wattages like such...
    http://www.crutchfield.com/p_107DB6501/Polk-Audio-db6501.html?tp=106
    http://www.crutchfield.com/p_107DB691/Polk-Audio-db691.html?tp=91#details-tab
    Notice that both sets are rated from 10-100....
    About the amp....those are some very very basic questions... I would HIGHLY recommend going through quite a few more amp wiring tutorials before you take on this project yourself. In a nutshell, you wire the amp directly to the battery (through a fuse of course) and you wire the speakers directly to the amp as well.... There is also a ground to connect, and a remote power on wire.... Plus RCA connections... again, go to youtube and watch 3-4 tutorials before you drop half a grand....
  10. Apr 17, 2012 at 8:05 PM
    tdswimin8
    Tony
    Davis
    2008 4x4 Tacoma SR5
    yes I was planning on watching some.... thanks a ton for the advice. if the speakers have crossovers do i bypass those if they are going to an amp? any ideas on amp brand?? i cant get those 6x9s because they wont fit so I will just prob stay with the 6.5's if theyll work. also if i get a sub, thats another amp huh...?
  11. Apr 17, 2012 at 8:10 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    You will want to use the crossovers as well as the amp. I really enjoy Alpine products, that's what I'll be using for mine. As far as rear speakers, get what fits, just check the wattages, a component system will be overkill for the rear. And yes generally a second amp is recommended for adding a sub as well. To power that, you would typically run a 4 gauge wire from the battery to a distribution block, then, depending on the size of the amps run either an 8 or 4 gauge wire from the distribution block to the amps. You'll want separate grounds for each.
  12. Apr 17, 2012 at 8:12 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  13. Apr 17, 2012 at 9:32 PM
    tdswimin8
    Tony
    Davis
    2008 4x4 Tacoma SR5
    if i get an amp that powers 50 watsx4 will the back sound different because its RMS is only rated to 55 compared to the front at 100? as in will the front be too under powered and not sound right?
  14. Apr 17, 2012 at 10:07 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Correct.
  15. Apr 18, 2012 at 12:53 PM
    tdswimin8
    Tony
    Davis
    2008 4x4 Tacoma SR5
    looks like I should start over and get different speakers.... I cannot find any 6.5 polk coaxial's that would go well with the components..
  16. Apr 19, 2012 at 11:06 AM
    81shark
    if you can wire in a head unit, you can wire up a amp.
    you'll need to run some rca wires from the stereo to the amp, and then speaker wire from the amp to the speakers. if you have components, you'll run the speaker wire to the crossover, adn then to the woofer and tweeter.
    for the amp, get an amp kit and you'll need to run the power wire from the batter thru the firewall (their are plugs in teh firewall that you can pull out to pass the wire thru. just make sure you put a grommet on the power wire so that the fire wall doesn't rub thru the wire insulation. if you mount under a seat, you can ground the amp to a seat bolt.
    the only other wire is the amp remote on wire.
    it really is easy.....a caveman could do it.
  17. Apr 19, 2012 at 11:10 AM
    Aw9d
    Aw9d That one guy
    I have the ********* mount for front and rear in my 2011 and they front's didn't fit right. They have one area that will hit part of the cup holders in the truck. I have to pull them out and grind them down.
    if you have a router and jig saw, make them out of MDF. It wouldn't be hard at all to do.
  18. Apr 19, 2012 at 11:12 AM
    81shark
    50 watts isn't going to be enough. ha. my first amp put out 40 watts per channel. i sold that, and picked up the pdx5 which is rated at 75, but was birthed at 100. makes a huge difference.
  19. Apr 19, 2012 at 11:15 AM
    81shark
    i wouldn't be too worried about pairing the two you picked out.
    or you could always go with two sets of the db6501's. crutchfield has them at buy one get 50% off the second pair.
    i'm running them front and rear in my access cab. that said, i would recommend a sub if you went that route.
    Hamer95USA likes this.
