Poll, 30-10 MPH Vibration, Automatic Trucks, Stock Height
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sfr4dr, Dec 21, 2021.
Do you have decel or coasting vibration at 30-10 MPH? (auto trans only)
  1. Yes
    38.0%
  2. No
    62.0%
  1. Sep 21, 2022 at 9:07 PM
    #121
    sfr4dr
    sfr4dr [OP] Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    That's pretty wild. You'd think these trucks would all have close to the same driveline tolerances as each other. Off by 2 degrees is nuts. I need to get out and measure mine.
  2. May 17, 2023 at 8:37 PM
    #122
    Riokid
    Riokid Member
    2022 SR 4x4 v6
    Had my 2022 for a year now. 6,000 miles. Dealer did the tsb today. New leaf springs. Seems to have eliminated 90% of the vibration. It was clearly noticeable from 30 to 10. Now it's very faint 25-20. So faint I'd probably not notice if I hadn't driven it w the vibration.
    BTW the tsb includes 2022 now.
    pdxTacoSR5 and nighthawk custom like this.
  3. May 28, 2023 at 10:03 PM
    #123
    sfr4dr
    Truckee/Tahoe CA
    Well I suppose that's good news that they extended it. Not sure why the newer models wouldn't just get the fix in the first place but who knows what the deal is.
    I didn't know the TSB was extended. Last time I was at the dealer, it didn't apply to 2022s. Since then, I've decided the stock ride is horrible and I was planning on installing Fox 2.0s (snap ring style) at 1" lift front and 0.5" blocks with a 1 degree shim in the rear. Now not sure what to do. I could get the TSB done but that still leaves the crappy ride. Could still go with Fox 2.0s at stock height I guess....
    zoo truck likes this.
  4. Jun 1, 2023 at 9:53 AM
    #124
    fightercat
    fightercat Well-Known Member
    REED
    2022 TRD sport DCSB 4X4
    NONE YET
    after the TSB installed EIBACH stage 2 shock package way better
    reed
    WilliamJames likes this.
  5. Jun 30, 2023 at 8:25 AM
    #125
    No-Hyperbole
    No-Hyperbole Well-Known Member
    2022 TRD Off Road_LB
    I have a 2022 OR long bed, and have been having this issue since new. Im at 10,000 now and it has not improved or worsened. Sometimes I get it from 40mph to 10, but it's mostly evident from 30-10. It's not a drastic vibration, and defiantly not warped rotors. The bulletin says it excludes the OR so im interest to know if anyone else has this issue on there OR, and or long bed. I'm suspicious of the driveshaft angle as much as I am the leaf springs.
  6. Jun 30, 2023 at 10:10 AM
    #126
    sfr4dr
    Truckee/Tahoe CA
    Have you tried putting 250 or so pounds in the bed and testing from 30-10 MPH?
  7. Jun 30, 2023 at 10:13 AM
    #127
    sfr4dr
    Truckee/Tahoe CA
    So you got the TSB done then installed an Eibach lift after? How much lift and what did you do with the rear suspension? Just leave the TSB axle shim or did you put a shim in with more angle?
    I recently bought some 5100's but haven't decided if I'm going to do the TSB first or just toss an axle shim in myself. I'm also probably going to do the ECGS bushing just as a preventative measure. I haven't decided on the height but it will probably just be 0.65" front and 0" rear or 1.1" front and 1/2" rear like the Trail Edition. If I got for the 1/2" rear then I'll probably do the OEM lift block and a 1 degree shim.
  8. Jun 30, 2023 at 12:06 PM
    #128
    No-Hyperbole
    That’s a clever idea to help flush out the driveshaft angle, but would you expect to see anything different if it were a leaf spring issue?
  9. Jun 30, 2023 at 1:24 PM
    #129
    sfr4dr
    Truckee/Tahoe CA
    I'm no expert on the issue but most of us on here discussing this feel it's an issue with the driveline angles. The 30-10 vibe in in my truck goes away when there's about 250-300 lbs in the bed. I've measured my pinion angle with and without that weight and it changes 0.5 degrees from the sag. I think the TSB mainly helps this issue because the new leaf pack comes with pinion shims. I'm not sure what angle they are though, probably 0.5 or 1 degree.
  10. Jun 30, 2023 at 2:56 PM
    #130
    North7
    North7 Well-Known Member
    2022 trdor
    2022 trdor never any vibs. Carried leer cap all but abt 6 weeks since new. Maybe I'm lucky. The truck has been flawless. Never to dealer for any BS other than first two checks.
  11. Jun 30, 2023 at 3:19 PM
    #131
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Great! Now you just jinxed yourself :D
  12. Jul 7, 2023 at 12:49 PM
    #132
    No-Hyperbole
    That solves it. Put 300# in the bed and it removes the vibration. Although now I can tell how poorly the brakes work. The stopping power is good (not even very good) but you need to have a heavy pedal pressure.
    now we need to see what the dealership says
  13. Jul 7, 2023 at 1:13 PM
    #133
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Thats strange that tsb was extended to these newer models, Toyota usually will automatically upgrade to new parts, if a known issue exists, to correct any problems. I have the sr5 which came with no vibrations of any sort back in 2020, so I don't what's up with that, unless this pertains only to certain trims.
  14. Jul 7, 2023 at 4:12 PM
    #134
    No-Hyperbole
    I read the TSB in this thread and it excludes the off road so I’m not sure if that’s been revised of if I’m going to have an extra issue.
  15. Jul 8, 2023 at 4:14 AM
    #135
    nighthawk custom
    nighthawk custom Well-Known Member
    Kentucky
    2022 dcsb SR5 4x4
    My SR5 has the vibration.
  16. Jul 8, 2023 at 5:21 AM
    #136
    zoo truck
    None
    Question is why? Did you do a lift?...whats it feel like? I've had my sr5 since new, and never once experienced a vibration of any sort. It's better than any past toyota pickup I've had.
  17. Jul 9, 2023 at 4:54 AM
    #137
    nighthawk custom
    Kentucky
    2022 dcsb SR5 4x4
    No lift, everything stock. Bought it brand new. Never had it checked out since it seems like it is a pretty common issue on a lot of Tacomas according to this thread.
  18. Jul 9, 2023 at 5:56 AM
    #138
    zoo truck
    None
    Maybe, but it drove one of my buddies crazy When his truck had some vibrations issues, and mine had none. Only difference, his was a trd double cab. Dealer told him all trd's have this ...it's normal. They didn't mention other trims. Could be that my sr5 is an access cab?
  19. Jul 11, 2023 at 11:58 AM
    #139
    No-Hyperbole
    Someone in this thread referenced the TSB now including 2022. I cannot locate that via VIN search and I’d like to find that if anyone has the file.
    thank you
    mike
  20. Jul 11, 2023 at 12:02 PM
    #140
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    +1. Have a 22 sport DCSB. Have a vibration bit chalked it up to new tires and shitty balance.
    is there a VIN lookup? Would be great
