[POLL] Are you having Transmission / Vibration Issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by decal211, Feb 10, 2016.
Are you having transmission/vibration issue?
  1. No - with less than 500 miles
    5 vote(s)
    3.1%
  2. No - with less than 1000 miles
    11 vote(s)
    6.9%
  3. No - with less than 2000 miles
    16 vote(s)
    10.0%
  4. No - with more than 2000 miles
    62 vote(s)
    38.8%
  5. Yes - with less than 500 miles
    18 vote(s)
    11.3%
  6. Yes - with less than 1000 miles
    7 vote(s)
    4.4%
  7. Yes - with less than 2000 miles
    9 vote(s)
    5.6%
  8. Yes - with more than 2000 miles
    32 vote(s)
    20.0%
  1. Feb 17, 2016 at 10:35 AM
    #41
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    As I was Installing nerf bars last night I started looking around and I really think it might be exhaust resonance... The left exhaust and catylitic converter pass very close to the steering shaft and also the firewall/floorboard right at the accelerator..
    So if that's the case then no cat-back exhaust would improve it...but if I had some type heat shield/ noise isolation material, I would lay up and insulator the floorboard more and see what happens..there is some aluminum heat shield there so maybe it's vibrating and exaggerating the problem!.. It's very hard to diagnose without say a dyno to run it on..frustrating.
    I am 50/50. It is not unbearable and can be overlooked but just disappointing.
    hopefully something will come of all of this.!
    2016 trd sport v6 AT dclb
  2. Feb 17, 2016 at 2:40 PM
    #42
    914time
    914time Member
    2011 Camry
    ^^^ This.
    Same here. Not buying until this is resolved. Patiently waiting. Growing tired and looking elsewhere.
  3. Feb 17, 2016 at 4:22 PM
    #43
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    Same here as well.
  4. Feb 17, 2016 at 4:24 PM
    #44
    unclemat
    2012 TX Baja
    Is there a room to weld a flex section or even a small resonator? It should change the resonant characteristic of the exhaust and hopefully fix the issue (or make it worse).
    Rather invasive thing to try, so I doubt there will be any takers for the idea.
  5. Feb 17, 2016 at 4:45 PM
    #45
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    70,000 miles no vibrations except when some one other than my self balances the tires don't know why they can't balance them I don't think they can deal with the wide centers.
  6. Feb 17, 2016 at 4:56 PM
    #46
    snefo
    snefo Well-Known Member
    The results of this poll are not valid. Your poll question was far too vague. Some platforms are not prone to these vibration issues, therefore the results are statistically meaningless. I am assuming you are asking the percentage of 3.5l v6 Tacomas that have vibrations. If this was the intent, the occurrence of vibrations will be under reported as a percentage.
  7. Feb 17, 2016 at 5:18 PM
    #47
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Saw this today. Lots of rage.
    ZachMX likes this.
  8. Feb 18, 2016 at 11:02 AM
    #48
    Danielnc06
    NC
    2016 TRD DCLB
    This may be obvious and I don't see it but why the rage ?
    There's no real information in that post...how did it fail him in the snow season?.. Too many unknwons and too many different types of drivers..am I over looking something?
  9. Feb 18, 2016 at 2:26 PM
    #49
    Sep1911
    2016 Taco
    No clue and I honestly don't care. I was looking for Tacoma parts at CL and this came up. I found it entertaining and thought I'd share. The recent snow storm he's taking about was a 30 inch snow storm. Probably a rookie.
    Danielnc06[QUOTED] likes this.
  10. Feb 19, 2016 at 11:58 AM
    #50
    Danielnc06
    NC
    2016 TRD DCLB
    So it hadnt crossed my mind to check in with other engineers I went to school with until I saw a Facebook post from another engineer that works at Toyota Power train Division. Waiting for a response from him.
    COskimtb likes this.
  11. Feb 21, 2016 at 4:18 PM
    #51
    Tacoski
    Tacoski Member
    Bloomington, Illinois
    2016 Tacoma TRD Sport
    none
    Thanks for sharing, and it makes sense, I just wonder why it didn't pop up right from the get go? I wonder if it also needed to be broken in for the vibration to start showing its ugly head? Do you have a pic of the pump and exactly where is it located on the motor? If it was accessible, I'd like to see if I could get a hold of it and see if in fact the buzziness quasi matches what I feel in the steering wheel and gas pedal.
  12. Feb 21, 2016 at 4:57 PM
    #52
    Danielnc06
    NC
    2016 TRD DCLB
    I insulated it with no luck.. Unfortunately..he has gone back to the drawing board and will let me know.
    It is located top of motor, rear-right. Denso part number. Looks like any other high pressure fuel pump (Google).
  13. Feb 21, 2016 at 5:22 PM
    #53
    Tacoski
    Tacoski Member
    none
    Thank you, and I patiently await to hear what your buddy has to say.
  14. Feb 21, 2016 at 7:00 PM
    #54
    2010gl1800
    2010gl1800 Active Member
    Barry
    Heber AZ
    2016 Tacoma TRD Off Road Access Cab
    Have had transmission issues since day one. Have 6500 miles on it to date. Truck lurches which makes me take extreme care when pulling into the garage or when pulling up close to something. Shift schedule really sucks. It's funny how when in cruise, I can't slightly accelerate and instead of downshifting to a higher rpm, it shifts to a higher gear, lower rpm. I don't have the vibration issue. I'm gonna try the dealer again to see if they will check the transmission fluid. In previous attempts they wouldn't unless I paid.
  15. Feb 22, 2016 at 12:31 AM
    #55
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    5000 miles in and not a single vibration issue.
  16. Feb 23, 2016 at 4:38 PM
    #56
    ScTuna
    ScTuna Well-Known Member
    Texas
    2016 Tacoma
    10,500 miles. Vibrating from day one. Stock 17". Trd bead 16" MTR and now 16" trd off road oem tires. Buzz buzz. Guess it's normal. But if someone figures it out please quote me thanks. Die die hard Toyota Guy
