Poll - AVG MILES traveled on full tank of gas.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Opihiman10, Dec 9, 2011.
  1. Dec 9, 2011 at 4:21 PM
    Sprink669
    Sprink669 Well-Known Member
    2010 DBL cab Off Road
    OME 886's Dakar leaf pack
    285-75-16 Duratrac
    ARB bumper and winch
    I get 15-17 MPG mixed driving
  2. Dec 9, 2011 at 4:31 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i average 200 miles per tanks
    LT315/75r16 with 4.56 gears
  3. Dec 9, 2011 at 4:33 PM
    MonkeyProof
    SoCal- SGV
    paging David K...
  4. Dec 9, 2011 at 4:33 PM
    TacoTitan11
    TacoTitan11 Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    4 cyl double cab auto 360 miles per tank. give or take:wave:
  5. Dec 9, 2011 at 4:51 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    His has a prerunner I see, that explains a large part of the difference.
    I inflate my tires to 44psi, pay close attention to traffic, what is called "Driving without brakes" or DWB. It's easier to understand what/when you are doing wrong if you think about what you did to need to brake hard, or at all.
    I have synthetic all the way around, but can't really attribute much to that, I stopped using mobil 1 and use motorcraft 5w-20.
    Lot's of coasting in neutral when it benefits.
  6. Dec 9, 2011 at 5:21 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I know mine flies to the E and then waits a while until it hits the light.
    My 'reserve' amount is definitely not 2.5 gallons. I don't know who calibrated my truck but I have about 6 gallons left when that light comes on. The first time I filled up when that light was on I could only get about 14 1/2 gallons in there.
    The gauge is nowhere near consistent. I have my UG readout estimated fuel used since fillup, it's darned accurate when I check it at fillup (within 0.2 gallons consistently), and I've seen 8 gal used at anywhere from 1/2 to 3/4 on the gauge. The only thing that really happens consistently is that at about 12 gal it reads 1/4 and at 13 gallons used the needle is pointing at E. 21 gallon tank? :confused:
  7. Dec 9, 2011 at 5:33 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    okay, cool. I definitely like the psi, DWB and coasting.
    So, silly question, what exactly does the PreRunner package have, and how is it effecting mileage? I thought the PreRunner automatically stated that we're 2x4, but just in case it doesn't, we are as well.
    edit: http://www.askmehelpdesk.com/cars-trucks/what-prerunner-tacoma-317262.html
    LORD, WHY, WHY WOULD YOU MAKE A VEHICLE PACKAGE LIKE THIS??? My world just shattered...I am...a....4x4....POSER.
    I didn't know.......I just thought they looked good.
    My friend just said 'well, we could upgrade you to a 4x4 really easy' (not. the. point.):facepalm:
  8. Dec 9, 2011 at 10:17 PM
    takao96753
    takao96753 Member
    mike
    KIHEI
    2010 Reg Cab 4wd
    4 cyl 4x4 reg cab 5 spd. I get 25 mpg, I never emptied the tank.
  9. Dec 10, 2011 at 9:44 AM
    worthywads
    :mad:
    So the prerunner is geared lower, 4.10 rear vs 3.31, so with the 245 vs 215 it's about 8% higher rpm and wider tires really put the hurt on mpg. Tires in general can have a large impact, I replaced my OEM Firestones with Michelin Hydro Edge that advertised low rolling resistancce and lost 3 mpg right there, with the same 215 size!!!!! :mad:
    Then there is the extra 4 inches in height, which significantly increases the wind resistance. I can't find the numbers right off but the coefficient of friction is way higher, something like .5 vs .3, so anything above 55 mph starts to drag with that 4x4 wannabe. :eek:
    You have debadged that thing so nobody knows right! ;)
  10. Dec 11, 2011 at 8:31 AM
    MrsPib
    Angie
    Texas
    So, ah, how does one go about debadging, now that we brought up the subject....
  11. Dec 11, 2011 at 9:49 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    fishin line, wd-40 & some gloves to not strangle the fingers. Wd-40 on a rag will also remove the leftover adhesive from the paint. Maybe a plastic window tint spreader thing to help get adhesive off.
  12. Jan 16, 2012 at 11:31 PM
    dmcnealy22
    dmcnealy22 Well-Known Member
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    07 4x4 access cab 18 gal tank.... i get 295-320...best 18.6 worst 17.2.... after the new tires I am getting about the same mpg after i factored in the 6.7% increase in tire size then adjusting the miles
  13. Jan 17, 2012 at 5:04 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    With mine, there is a significant difference between summer miles per tank and winter. Summer is typical 410 to 420 miles before the low fuel light comes on. Winter gas blends (or temperature) reduces this to typical 380 to 390 miles per tank before the low fuel light comes on.
    My truck is a 2007 DCSB 4X4 and is "leveled" (not lifted) with 265/70-17 Michelins, the rear spring TSB, and 5100 shocks on all four corners. I drive 80 miles total per day, 20 miles on a highway and the rest back roads. There is some use of my truck (to go help customers) once I get to work but the use and mileage various. I know were the go pedel is but I baby it unless I have to do otherwise. I also drive so as to minimize hard braking. I have 65K miles on my truck and I'm still using the original front and rear brakes although my front brakes are ready for replacement. When I feel the need for speed, I drive my "other car". I've used the ScanGuage to learn how to conserve fuel and still enjoy driving a great truck. My objective is to fill up only once per week. I have no trouble with this objective in the summer. In the winter, most often, I fall short.
  14. Jan 17, 2012 at 5:04 AM
    OxyGuy
    OxyGuy Well-Known Member
    Conway, SC
    2007 PreRunner
    My first full tank through my '07 V6, automatic, 385 miles. To work and back, driving very easy. Due to speed limits, speeds were mostly around 50 mph. It took 17.0 to fill it, 22.6 mpg. I'm pleased but I don't expect this every tank.
  15. Jan 17, 2012 at 5:40 AM
    #35
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    06, dcsb, 2x4. 330-340 light comes on.
  16. Jan 17, 2012 at 5:42 AM
    #36
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    330 roughly...then the light comes on
  17. Jan 18, 2012 at 5:01 PM
    #37
    Tunajoe13
    Tunajoe13 Well-Known Member
    Joe
    Parrish, FL
    05’ Base V6 4x4 extended cab
    20'' wheels, 34''x11" Toyo Open Country A/T II tires, 4.88 Gears, ARB Locking Rear Diff, ARB compressor, Fiberglass bed cover, Weathertech floor liners, Weathertech side window protectors, Allpro Apex front bumper, Allpro Apex rear bumper Allpro 3'' Expo rear leaf kit, Allpro hidden hitch receiver, 10'' aluminum drop hitch, Camburg 4'' spindles, Allpro uniball uca's, Ottonavi 6.5'' touch screen G.P.S, 09' Tailgate with factory reverse camera, Stampede hood protector, Raptor style grill and hood mesh (Homertaco), Piaa 5100 Fog lights, Volt HID's, Viper5704 Alarm with remote start, Limo tint, Scangauge II, TRD cai, URD 3'' Mk2 exhaust, Doug Thorley LT headers, URD Y-pipe, Unichip PnP Pcm, Unichip Flux2 display, Factory Sport hood....
    331 today and light came on. 265/50/20 general grabbers. Almost all highway miles. about 60 a day.
  18. Jan 18, 2012 at 5:24 PM
    #38
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    All second Gen. tacos have a 21.1 gallon tank... 80 liters if you're metric.
    Nobody drives until they run out of gas ('miles per tank'), right? So, another measuring point makes more sense.
    The figures below are +/- 0.5 gallon:
    At the 1/4 tank line, there are 8 gallons in the tank (down 13 from full).
    At the E light, there are 4 gallons in the tank (down 17 from full).
    At the E LINE, there are 3 gallons in the tank (down 18 from full).
    If you want to call it that, then yes, there is a 3 gallon 'reserve' between the gauge and the amount in the tank... at least in the lowest 1/4 area of the gauge.
    FYI. At the 1/2 Tank line, there are 12 gallons in the tank (down 9 from full). At the 3/4 Tank line, there are 16 gallons in the tank (down 5 from full).
    So, on the gauge between a topped tank and 3/4 Line is 5 gallons. 3/4 Line to 1/2 Line is 4 gallons. 1/2 Line to 1/4 Line is 4 gallons. 1/4 to Empty Line is 5 gallons.
    5 + 4 + 4 + 5 = 18... + the 3 gallons between E Line and empty tank = 21 gallons. As you can figure, a true 1/4 of 21 gallons is 5.25 gallons. So, the first 1/4 tank on the gauge and the final 1/4 tank on the gauge are the closest to accurate... the other two being only 4 gallons each, drop quicker.
    Is that enough details? ;)
  19. Jan 18, 2012 at 5:56 PM
    #39
    Bee22971
    Bee22971 Well-Known Member
    Garth
    Sacramento
    2011 DC TRD
    King 2.5 C/O, DSM UCAs, all pro leafs, and AllPro Sliders
    2011 TRD OR DC SB
    Auto
    Mainly freeway driving
    Average 18.9mpg
  20. Jan 18, 2012 at 7:04 PM
    #40
    RedOctober
    RedOctober Taco lova
    Albany, NY
    08 Speedway Blue TRD Off Road
    I have GOT to be doing something wrong.... 07 TRD OR auto, pretty much bone stock with K&N Air filter....I get like 16.
    Summer-330-350 a tank
    Winter- 300 a tank
    I'll admit I drive with a pretty heavy foot, but it seems like everyone is getting at least 2-3 mpg better than me. Even people who also admit to a heavy foot.
