POLL - Bilstein 5100 Perch Setting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by andersen24, Sep 14, 2021.
What Perch Setting For Your Bilstein 5100's
  1. 5th Perch (2.00")
    6 vote(s)
    42.9%
  2. 4th Perch (1.55")
    5 vote(s)
    35.7%
  3. Other Perch
    3 vote(s)
    21.4%
  1. Sep 14, 2021 at 6:30 PM
    andersen24
    andersen24 [OP] Well-Known Member
    Andy
    Pismo Beach, CA
    2021 Tacoma SR DCSB V6 4X4
    OK so I got my Bilstein 5100's (F&R) and I keep going between doing my setting on the 4th or 5th perch. I ordered Falken Wildpeak A/T3 265/75/16 to go on my factory wheels with FACTORY coils (so as not to void the Bilstein warranty). Along with that I am doing the 1.50" rear AAL and the front differential drop kit. Looking at pics, I like the stance of the Taco's on the 4th perch (1.55"), but have seen a couple pics of them on the 5th perch (2.00"). So let me know whatcha' all think! Feel free to add pics of your truck WITH the perch setting you have!
  2. Sep 14, 2021 at 6:33 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Depends on coils. when I put 590lb coils on I ran it on the bottom perch. If running OEM coils I think I was on the second from the bottom?
  3. Sep 14, 2021 at 6:35 PM
    andersen24
    Andy
    Pismo Beach, CA
    Thanks @Slashaar - I updated my info to include I will be using the factory coils.
    Slashaar[QUOTED] likes this.
  4. Sep 14, 2021 at 6:38 PM
    Slashaar
    Josh
    Kansas City, MO
    It was 2nd or 3rd from the bottom on my tired 90k mile OEM coils. I can't remember. I changed over to OME 887s I picked up for $20 like 20k ago so I've slept many times since then lol.
    Just bought 6112s with 650lb coils so the 5100s will be coming off.
  5. Sep 14, 2021 at 6:43 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Go to 5th. Ditch the drop kit and replace the needle bearing.
  6. Sep 15, 2021 at 2:29 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My DCLB with 5100s set on the 4th perch, stock coils, 1/4 shim and a 1 inch rear block, did the ECGS bushing, front diff and rear carrier drop and it has a slight rake, run 265/70/17 Toyo AT2s on 4Runner Pro wheels. No issues what so ever, did my son's the same way, everything identical except he is on the 5th perch, again no issues and both ride and drive pretty much the same. I added the new Sumo bump stops.
    71tattooguy and andersen24[OP] like this.
  7. Sep 15, 2021 at 2:44 AM
    Rainman443
    Rainman443 Well-Known Member
    A Big Island
    2021 TRD OR
    Both will ride the same, and look pretty dang close. It's just how much of a rake you prefer. If you don't have a constant load/tow, I'd just go the full 2"
    71tattooguy, VaToy and andersen24[OP] like this.
  8. Sep 20, 2021 at 8:29 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Check your Taco Lean. I had some that I didn't notice until I measured. Reusing my Sport springs, I went to the 4th perch on the left and 3rd on the right. That put me up and even 1.5in in the front and gave me a 1.5in rake that pairs with the Icon RXT Option 1 packs.
