Poll: Diesel like noise clutch determinative?
Discussion in '4 Cylinder' started by Terrier, Sep 1, 2009.
  1. Sep 7, 2009 at 7:01 PM
    #41
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    09 w/ 13K and mine does it. I feel the noise while perhaps normal on 08 & 09's is certainly not acceptable for a Toyota Product.:( I also feel the noise is associated with the gear whine in 1st gear and difficulty in downshifting from 2nd to 1st.
    Motoretro
  2. Sep 7, 2009 at 9:04 PM
    #42
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    If it makes you guys feel any better, I noticed today that mine does it as well. I noticed it in a drive thru. Clutch to floor goes away clutch up comes back. Did it with AC on. Don't recall hearing it with the AC off.
    My 350Z makes the same noise AC on or off (not always and sometimes louder than others) and it is totally normal as all the 6 speeds do it. The Z if you rev it a little it goes away. If you press the clutch it goes away.
    I wouldn't worry too much about the noise. If it breaks warranty it. You can hear all kinds of potentially scary noises parked close to a wall. That's why I turn the music up sometimes. If I can only hear it next to a wall I don't worry about them too much.
    I took the truck wheeling for the first time today and heard all kinds of niffty noises LOL. Revtek offroad = fail. Talk about a harsh ride OMG.
  3. Sep 7, 2009 at 9:29 PM
    #43
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    it does sound like the throw out bearing.
  4. Sep 7, 2009 at 10:14 PM
    #44
    markustyson
    markustyson Member
    Victoria, BC
    2008 Tacoma 4x2
    same with mine :(
    2008 with 25,000 km
    4cyl. 5 spd
  5. Sep 8, 2009 at 4:30 AM
    #45
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine is 05 4 cyl 5 speed with about 65k on it. It does the diesel noise too especially with the AC on idling. I'm gonna go with underengineered shaft & wear from throwout bearing sliding on it causing this. New throwout bearing will not fix it. Only new shaft will. IIRC, the shaft is part of the bell housing on these trucks & is expensive piece. May be why they just said fuck it & replaced the whole tranny. I have had rear main replaced according to dealership when I took it in for leak from bell housing but who knows, they could've replaced the front seal on the gearbox & just not said anything. The leak did appear to be engine oil, not gear oil tho. Luckily I have 7yr/100k drivetrain warranty so they will have to deal with the rattling at some point.
  6. Sep 8, 2009 at 5:14 PM
    #46
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Mine does this, sound like ordinary gear rattle, not worth worrying about. As Toyota makes the truck quieter, mechanical noises stand out a little more....
  7. Sep 8, 2009 at 5:16 PM
    #47
    Terrier
    Terrier [OP] Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Not sure, but I think the shaft is not part of the bell housing on the 5 speed but is on the 6 speed. In any event, if "underengineered", as you put it, then replacing whatever with the same part won't cure the issue, unless the part has been redesigned or upgraded. Again, I'm still not sure that it is a defect as opposed to just a noise issue.
  8. Sep 9, 2009 at 6:34 PM
    #48
    Terrier
    Idaho
    Poll Synopsis: I am attempting a synopsis of this poll, including my other thread referenced in the original post. I counted 26- 2nd Generation 4 cyl. 5 speeds, all of which, except 1 (CometKat 08 4x4), say they have the noise that goes away with clutch pedal depressed and comes back with it up. Here's the summary:
    1. Terrier: 2008 , 13k mi. 4x4
    2. 08pretaco: 2008, Prerunner
    3. hedlesbrmstkbass:2008, 12k mi. 4x2
    4. jrsmokestacks:2008, 4x4 noise gone at 53k mi.
    5. 06dak: 2005 , 29,000, prerunner
    6. Raven65: 2009, 4x2
    7. PSJ: 2009 , prerunner, noticed since new
    8. jfr02: 2008 4x4
    9. Fast1: 2006 4x4
    10. UA34: 2008, prerunner
    11. Knot Guilty: 2009 4x4, noticed within 3 months of purchase; transmission replaced at 5k miles and now has 10k and no noise since replacement.
    12. motoretro: 2009, 4x2, 13k mi.
    13. Chad68: 2009, 4x4
    14. markustyson: 2008, 4x2
    15. Taco ptr3runn3r: 2005, 65k mi.
    16. jiles111: 2009 4x4
    17. uood8: 2009 , 4x4, noticed when new; now 3k mi.
    18. ttylerr: 2009, 4x4
    19. InfidelTaco: 2005, prerunner
    20. GoBlueFan: 2008, prerunner
    21. jasper07: 2009, 4x4; replaced input shaft bearing (total disassembly of trans) and nothing changed.
    22. 08beachtoy: 2008, 4x4
    23. ninja taco: 2008, 4x4; throw out bearing replaced and noise came back; then bearings in transmssion were replaced and noise went away
    24. hans2: 2009, 3k mi.; replaced throw out bearing and noise came back next day. Rattle has now advanced to where it is noticable out of gear while coasting to a stop.
    25. Isthatahemi: 2009, 4x4
    What to make of it so far, I'm not sure. If I made a mistake with regard to any of this synopsis, please correct me. Thanks everyone for participating so far.
  9. Sep 9, 2009 at 6:37 PM
    #49
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    ive had it happen at times with the AC off..but it is really soft and pretty much unnoticeable...i was outside the truck..
  10. Sep 12, 2009 at 7:24 PM
    #50
    Terrier
    Idaho
    Okay, today I was in the "big city" over 200 miles from me. I went to a dealership there. The tech and I listened to the noise that I described above come and go as I manipulated the clutch (a/c on), and he said it was a normal noise characteristic of this type of truck. He said he has had a number of people come in with a question on this. They basically all do it, he said.
    He said it is an inherent noise that has something to do with the clutch that goes away when you press on the clutch pedal. His opinion is that it is not any kind of mechanical problem.
    If you have any concerns, then have your Toyota Tech check it out. After all, we may not all be talking about the exact same noise or degree of noise.
  11. Aug 1, 2010 at 10:44 PM
    #51
    CEaton
    CEaton Member
    Frederick, MD.
    01 Tacoma TRD OR Xrtacab
    am having the same exact issues as everyone here, bought my 07 4x4 2.7 with 37k on the clock 7/4/09, completely silent, fast forward to this summer, when the AC came back into play I started hearing the noise, very pronounced, I now have 77k miles(I drive a lot).
    I had the truck into two dealers, the first wanted 1k just to rip it apart and look, even under extracare warranty, then I took it to another dealer(trusted friend service writer at this dealer) they agreed it didn't sound like a throw out bearing at first, once they took it apart they concluded it was the throw out, so I paid to have the complete clutch treatment, disk, bearing etc. This also included a full flush of the tranny........
    Noise came back IMMEDIATELY after a real drive(more than 30 miles) so it's going back to the dealer with a copy of this thread on the passenger seat. I will keep everyone posted.
    Luckily I have the Extra Care warranty.
  12. Aug 1, 2010 at 10:59 PM
    #52
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    Mine does the same thing. Has ever since I bought it new in Apr. 2005. I just make it a point to keep the clutch pressed in when stopped or the AC off.
  13. Aug 2, 2010 at 7:24 AM
    #53
    Neb
    Neb Well-Known Member
    Ben
    Tennessee
    06 PreRunner TRD Sport
    TRD S/C, URD ShortShifter, URD Y-pipe, URD Mk2 Catback, URD 2.8Pulley, URD U-spec headers, Innovate AFR/Boost, AFE Intake
    My 07 5sp 2.7 does it. 70k miles, and it's definitely more pronouced with the AC on. It goes away when the clutch is in, and only seems to occur at certain engine speeds.
  14. Aug 2, 2010 at 2:50 PM
    #54
    CEaton
    CEaton Member
    Frederick, MD.
    Looks like I might be getting a new trans, I brought the truck home, they are opening a case with Toyota and recommending replacement, so we'll see. I'll keep everyone updated.
  15. Aug 3, 2010 at 5:39 AM
    #55
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    My 08' at 80,000 miles still dosent do it, but my brothers 10' does with 12,000 on it.
  16. Aug 3, 2010 at 7:55 AM
    #56
    Tacovendor
    Tacovendor Well-Known Member
    SoCal
    4x4x4cyl
    Just wait!
    2010 4X4, dealer said it was "gear noise" and that they all make this noise. Mine does it w/ AC on and goes away once you turn AC off, or depress the clutch. I'm interested to see if anyone that had the problem that had repairs made, if the sound was gone after the service.
  17. Aug 3, 2010 at 4:07 PM
    #57
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Every manual transmission vehicle I have owned, motorcycles included, have rattled when idleing in neutral, with the clutch pedal or lever released. Have only noticed it on the Taco when it is fully warmed after a long trip and you sit at a drive-thru. My guess is the noise is a combination of the throwout bearing and maybe the flywheel doing a little dance. Have only heard the rattle about 5 times.
    My 20 year old BMW motorcycle which has a dry clutch like a 4 wheel vehicle, has rattled under these conditions since new, and still running fine on the original clutch and transmission.
  18. Aug 3, 2010 at 4:28 PM
    #58
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    o yeah i got it, kinda worse when my truck is very varm, like just after driving.
  19. Aug 5, 2010 at 5:15 AM
    #59
    Ghost Rider
    Ghost Rider Well-Known Member
    Quebec Canada
    Tacoma Sr5 4x4
    2010 4500 km 4x4 I4 manual dealer just change the transmission for the same thing. The noise is not there any more :D
  20. Aug 6, 2010 at 1:59 PM
    #60
    pinktacos
    pinktacos Active Member
    so-cal
    07 cheap taco
    mine makes the same noise, it sounds terrible its an 07 5 spd 4cyl
