Poll: Diesel like noise clutch determinative?
Discussion in '4 Cylinder' started by Terrier, Sep 1, 2009.
  1. Aug 23, 2010 at 4:36 PM
    #81
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
  2. Aug 23, 2010 at 5:31 PM
    #82
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I've never driven a manual trans Colorado or Canyon although wonder if the transmissions are completely interchangeable with the Tacoma. Do you have a chart of the gear ratios for the GM version? I'm wondering if the cases are different.......My guess is a good trans shop should be able to disassemble the Tacoma trans and re-shim to tighter tolerances to produce a quieter unit.
    Motoretro
    [/quoteThe Colorado does use the same 5 speed as the Tacoma, but the gear ratios are different. I work at a Chevy dealer and I've never sold a single part to one of these transmissions other than gear oil. I don't know why the Tacomas have the noise issue and the Colorados don't.[/quote]
  3. Aug 24, 2010 at 7:13 AM
    #83
    2010sr5
    2010sr5 Member
    I also have the same noise, but I have an actual scientific theory of what is causing this unruly commotion in the rear of my truck.
    I believe that Glen Beck has been depositing gold bullion shavings into my transfer case when my truck is parked at home and I'm sound asleep.
  4. Aug 24, 2010 at 8:11 AM
    #84
    Neb
    Neb Well-Known Member
    Ben
    Tennessee
    06 PreRunner TRD Sport
    TRD S/C, URD ShortShifter, URD Y-pipe, URD Mk2 Catback, URD 2.8Pulley, URD U-spec headers, Innovate AFR/Boost, AFE Intake
    I dropped my truck off last night at the dealership so they can take a look at it. The sevice guy said that he's had multiple similar trucks in the past few weeks with the exact issue, and that 'Toyota doesn't know how to fix it'.
  5. Aug 24, 2010 at 8:32 AM
    #85
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i cant believe i didnt come across this thread sooner. i assumed it was a rattle coming from a heat shield or something. my 05 4x4 just started doing this this summer, started becoming more noticeable id say may or june. right now i got 61750 miles on mine. im gonna hope its just normal gear noise as i am now out of warranty. figures it starts making the noise just as i am out of the 60K mile powertrain warranty. dammit...
  6. Aug 24, 2010 at 1:17 PM
    #86
    Carp
    Carp Member
    Pawling, NY
    2007 2.7 Tacoma
    Leaf Spring TSB, Super Springs
    DCH Toyota in Wappingers Falls NY now has my truck. They dropped the entire transmission and are ordering a new fork and some "bearings." That is all I know for now. It might be ready on Thursday. We'll see.
    Carp
  7. Aug 24, 2010 at 2:28 PM
    #87
    danteisme
    South Western PA
    im thinking of gettin mine looked at, but now im worried to hear what they'll say now that i'm out of warranty by 1800 miles
  8. Aug 24, 2010 at 2:39 PM
    #88
    Carp
    Carp Member
    Pawling, NY
    2007 2.7 Tacoma
    I also came across a bunch of information about "neutral turnover rattle." Google the term. VERY interesting. It makes me think that this may be "normal" (but annoying) and my Toyota guy is doing nothing but guessing.
    Carp
    Neutral rollover rattle has the same
    characteristics as gear rattle except rollover
    occurs with the engine idling, transaxle in
    NEUTRAL and the clutch engaged. The rollover
    noise intensity increases with transaxle operating
    temperature and engine torque load resulting
    from engine driven accessories (air conditioning
    and alternator). Gear rollover noise is inherent in
    manual transaxles and is not detrimental to the
    engine or transaxle. However, in vehicles where
    the engine idling speed is below specification or
    rough, the rollover noise can deteriorate to a level
    where a harsh clattering noise similar to loose
    parts in the transaxle will become audible.
    Replacement of transaxle components will NOT
    correct this condition.
    3. Gear rollover noise, caused by engine torsional
    vibrations, and clutch release bearing noise are
    sometimes mistaken for bearing noise. Gear
    rollover noise will disappear when the transaxle is
    engaged in gear. Due to a constant running
    release bearing noise caused by a worn or
    damaged release bearing will be noticeable only
    when the clutch is disengaged. When complaints
    of this nature are encountered, it will be
    necessary to check the vehicle to determine if
    bearing noise exists. Transaxle servicing will not
    eliminate gear rollover noise or clutch release
    bearing noise.
  9. Aug 24, 2010 at 7:11 PM
    #89
    CEaton
    CEaton Member
    Frederick, MD.
    01 Tacoma TRD OR Xrtacab
    Even though I have extracare, and paid for one tear down where they blamed it on the throw out bearing and I paid out of pocket for a full clutch and bearing replacement. The noise never went away and now I have to pay for another tear down out of pocket for them to check again.
    I'm not happy one bit, I called and opened a case to toyota corporate, they say there isn't anything they can do.
  10. Aug 24, 2010 at 8:41 PM
    #90
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Well... You might be able to add mine to the list as the first 1 gen to be doing it. Can someone make a video of it for everyone else's comparison? Mine only does it with the A/C on and it was kinda funny even before I saw this thread i was like man this sounds like a diesel... I'll try to get a vid of mine tomorrow. It also stops if the AC is off or i push the clutch in.
  11. Aug 25, 2010 at 4:55 AM
    #91
    danteisme
    South Western PA
    i checked mine last night to see if the noise changes with the clutch. the noise stops as i depress the clutch, then it comes right back as i let the clutch back out. so its safe to say mine is doing exactly what is described in this thread.
  12. Aug 26, 2010 at 11:13 AM
    #92
    Carp
    Carp Member
    Pawling, NY
    2007 2.7 Tacoma
    I just picked up my truck from Toyota. To quote the report from Toyota. "DRIVEN ON AN EXTENSIVE ROADTEST, NO ABNORMAL NOISE HEARD AT THIS TIME." I drove home about 25 miles at highway speed with the a/c running. I got out of my truck, left it running and in neutral. When I got out and listened the noise was STILL there. ALL work was completed under warranty. I cost me nothing but time. I am left to conclude this noise is inherenent and likely "Neutral rollover rattle/Gear rollover noise." Nothing can be done. Unless somebody else gets another dealer to actually fix this, there is NO way I am going back!
    The report stated the following items were replaced:
    CUTCH COVER SUB ASSEMBLY R&R
    FORK SUB-ASSY.
    DISC ASSY.
    COVER. ASSY
    RAD B-BRG CLTCH REL.
    BEARING ASSY.
    SUPPORT RELEASE FOR.
    BEARING RADIAL BALL
    I like my new clutch. It feels better. But NOTHING else changed. Yeah Toyota quality!
    Carp
  13. Aug 26, 2010 at 11:19 AM
    #93
    danteisme
    South Western PA
    wow, so they replaced all that stuff and the noise is still exactly the same!?
    well at least it sounds like my tranny isnt going to clunk out on me after reading that
  14. Aug 26, 2010 at 11:19 AM
    #94
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i believe it is normal. I met a guy in an 05 prerunner with 340k on the odo (work truck) his does it, did it from day one. never had anything close to a failure.
    My father, a mechanical engineer and machinist instructor, mentioned this rollover but i thought he was full of shit... maybe more to it then i gave him credit for.
  15. Aug 27, 2010 at 5:08 AM
    #95
    danteisme
    South Western PA
    I noticed last night that if i'm under 2000 rpm and on the throttle, i can hear the diesel sound just like at idle. after that, the sound either disappears or i cant hear it over the truck. still shifts and runs just as good as ever, just new noises like this worry me sometimes. related problem? i know in this thread it was basically discussed how this noise is at idle but i noticed mine at lower rpms now.
  16. Aug 31, 2010 at 7:07 AM
    #96
    hockey7801
    hockey7801 Member
    Mine does it too...2010 2.7 4x4 Access Cab SR5 with 2k miles on it. I'm dropping mine off at the dealership on Thursday to have them test it out. They want to keep it for the day.
  17. Sep 1, 2010 at 6:57 PM
    #97
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    It's becoming apparent that this noise is just the nature of the beast and, though annoying, is not hurting anything at all and will not shorten the life of the tranny. I think there's a much higher probability that the "techs" <rolleyes> at my dealership will screw something up worse if I let them work on it than if I just live with it - so I think I'm just going to do that. It drives and shifts great - better than when new - so I'm just going to relax and forget about this thread.
  18. Sep 2, 2010 at 5:51 AM
    #98
    Carp
    Carp Member
    Pawling, NY
    2007 2.7 Tacoma
  19. Sep 10, 2010 at 11:38 PM
    #99
    MowTaco
    Kansas
    Ok just to clarify... Is this the stuff you guys are hearing?
    This is idling with A/C off.
    And this is idling with A/C on
    Is this the diesel noise you guys are all hearing?
  20. Sep 13, 2010 at 6:02 AM
    #100
    flattire
    flattire Spending my beer money...
    North East
    4x4 SR5
    K&N Cold Air Intake, Lund Genesis Tri-Fold Tonneau, WeatherTech DigitalFit Liners F&R, WeatherTech Window Deflectors, Pioneer AVH-P4200DVD, Pioneer GM-D9500F, Pioneer TS-D1720C, Pioneer TS-D1702R, Pioneer GM-D7400M, JL audio 8w3v3-4, RAAMmat BXT II
    My 09 4x4 2.7L makes the same exact noise (5000 miles). Not really noticeable on a cold engine but after a long drive the noise is very distinguishable. Sounds like a dry clutch on a Ducati.
    Haven't taken it to the dealer yet but I imagine they will just say its normal. If its not broken don't fix it etc...
