Poll: Diesel like noise clutch determinative?
Discussion in '4 Cylinder' started by Terrier, Sep 1, 2009.
  1. Sep 13, 2010 at 6:16 AM
    #101
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    first post, welcome!
  2. Sep 13, 2010 at 9:27 PM
    #102
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    Yes. Get someone to push the clutch pedal in while you record with the A/C on - and you'll hear it go away.
  3. Sep 14, 2010 at 12:13 PM
    #103
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I just turn my hearing aid off... and poof, like magic....it's gone.
  4. Sep 14, 2010 at 9:09 PM
    #104
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Yeah I can hear it from inside on my own when I push the clutch. Well I am honored to be the only 1st gen to be having the noise :frusty:
  5. Oct 3, 2010 at 6:39 PM
    #105
    Ghost Rider
    Ghost Rider Well-Known Member
    Quebec Canada
    Tacoma Sr5 4x4
    whent to the dealer they changed the transmission the noise is still there :eek:
  6. Oct 21, 2010 at 8:17 PM
    #106
    kbish0210
    kbish0210 New Member
    Murrieta, CA
    '96 4x4 2.7L
    yeah i have the same problem in my '96 2.7L manual trans. my tech said its the timing chain hitting the timing cover. when the rpm increase the tension on the chain increases also, which pulls the chain tighter so it doesn't hit the cover. that's why it goes away when the rpm increase.
  7. Dec 17, 2010 at 1:44 AM
    #107
    Surfinpig
    Surfinpig Well-Known Member
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    Avid Offroad light bar, trd skid plate, are cap, billy 5100's
    hey i took mine in and got a new cat ,,,, noise gone
  8. Dec 17, 2010 at 11:37 PM
    #108
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Just because the purring is louder than the truck does not mean the problem is fixed:p
  9. Dec 27, 2010 at 6:20 PM
    #109
    OSOQWK
    OSOQWK Member
    Hawaii
    09 2.7 PreRunner
    K & N Air Charger Pioneer 920B Black Head lights Black Tail lights Color Matched Grille Hids
    Ive def got that sound going on... sounds like the pressure plate. More noticable with the A/C on for sure... also sound goes away when the clutch is pushed in, so its certainly the clutch.
  10. Dec 27, 2010 at 9:01 PM
    #110
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I will be putting this oil; http://www.redlineoil.com/product.aspx?pid=44&pcid=8 in my 5speed, yes it makes the noise described.
    I put this oil in my friend's 6speed in his 02 Sentra 2.5L and it improved shifting by 110%...
    This IS gear noise! This noise has NOTHING to do with clutch, flywheel or bell housing assembly. The noise (well on my truck) is there only at idle and when the truck is fully warmed up. When the truck is cold gear oil is thick dampening the sound better, when gear oil gets hot, it gets thinner and its sound dampening capabilities go away resulting in gear noise.
    Also remember that most transmissions are made out of aluminum which is like the holy grail for car manufacturers. Aluminum is complete shit in my opinion, it is weak and it transfers sound much more than steel or iron, resulting in all those little noises we hear from the modern gearboxes & engines.
  11. Dec 29, 2010 at 2:11 PM
    #111
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    You're right about the gear noise. I'm a bit old school and the old C.I. units were a lot quieter.
    This might sound unusual although I wonder if a product like Line-X applied to the trans case would quiet things down a bit.....??
    Let us know on the Redline....I think it might help w/ shifting although hesitant about it quieting things down on this trans. FWIW
    Motoretro
  12. Jan 31, 2011 at 4:55 PM
    #112
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    '06 2.7L 5speed and I've got the exact same thing. At idle in neutral with a warm transmission, the "loose gears" noise is prevalent, but goes away when the clutch is depressed. I'm planning to replace the trans fluid with Redline MT-90 within the next day or two because of this, plus the notchy shifting, and the slightly audible whining/buzzing when I let off the gas at higher speeds in 4th & 5th gear. I'm hoping that the fact that it's full synthetic might quiet things down a bit.
    I don't think that this is a problem more critical than an annoyance. My '07 VW GTI did the same thing only much louder and less deep, and it didn't have the bigger gears that this truck has.
  13. May 25, 2011 at 8:00 AM
    #113
    cheryllke
    cheryllke New Member
    2008 tacoma
    i have the same issue.....any ideas as to how to fix???
  14. May 25, 2011 at 8:21 AM
    #114
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    It is normal, no real fix. Every manual transmission vehicle I have owned in the last 40 years has done this to some extent, even my motorcycles.
  15. Jul 28, 2011 at 5:48 AM
    #115
    BCTaco14
    BCTaco14 Well-Known Member
    Sorry to bump this thread but I am trying to look into this problem as well. I just bought a 2006 double cab TRD with the 6 speed manual transmission. The only time it makes the rattle sound is when I am first starting up. And it is VERY faint. This same thing used to happen in my dads saturn.
    The only reason I care is because my truck is certified used and comes with the 12 month bumper to bumper warranty so I was wondering if they would do anything to fix it. It seems like this noise really doesnt matter much.
    Thoughts?
  16. Jul 28, 2011 at 5:53 AM
    #116
    danteisme
    South Western PA
    the 6 speed has a tsb for it i believe, but i think thats for a throw out bearing chrip/squeal or whatever
  17. Jul 28, 2011 at 6:00 AM
    #117
    BCTaco14
    So it is most likely worth at least taking to the stealership>?
  18. Jul 28, 2011 at 6:06 AM
    #118
    BCTaco14
    If there is a TSB on something does it mean they have to fix it for free?
  19. Jul 31, 2011 at 3:19 PM
    #119
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    if your still taking a poll for it my 2006 4x4 5sp 45000 miles. but i dont see that it has affected driving in anyway. and my buddy who is a tech a toyota said all of the ones he work on sound like that, and the is nothing the dealership can do to fix the noise.
  20. Aug 1, 2011 at 11:01 PM
    #120
    lowzone
    lowzone Well-Known Member
    Ron
    Earth aka NJ
    2010 MGM AC 2.7L 5 spd SR5
    future plan of 2" drop and any type of rim thats not a steelie. grille and BHLM mods, maybe....
    my 2010 does it too, its the TOB not the gears. when you press the clutch in, youre applying pressure to the TOB and any slack in the bearing is decreased and the noise magically goes away. 20 year of ASE mechanics, my Isuzus, wifes 03 Lancer did it....once the bearing lube wears out (lube from assembly) the tolerances diminish and you get free play in the bearing. the a/c on, the lancers also got louder. 72k miles, did it from new, just like my tacoma (yes the wife drives a manual). unless its chirping/grinding/squeaking the bearing is moving freely. its when you press in the clutch and it grinds or you feel it in the pedal, id start to be concerned. thats when you know the bearing is DRY and self destructing. there is also an issue with the TOB not fully releasing and the clutch slipping out there. from what i read the pressure plate is too weak and heats up and slips not the TOB. i wouldnt worry about it, just the noise from a new truck can be disheartening....
