POLL: Differential drop effectiveness with vibes caused by lift
Discussion in 'Suspension' started by BenWA, Jan 27, 2011.
Did a diff drop help eliminate your vibes?
  1. Yes, it totally cured all vibes
    1 vote(s)
    3.1%
  2. Reduced vibes noticably, but did not completely rid them
    8 vote(s)
    25.0%
  3. I can't tell whether it helped or not
    16 vote(s)
    50.0%
  4. No, it definitely did not help, but did not make vibes any worse
    4 vote(s)
    12.5%
  5. It made vibes WORSE, or created new different vibes
    3 vote(s)
    9.4%
  1. Jan 27, 2011 at 11:23 PM
    BenWA
    BenWA [OP] Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    This poll is for 2nd gen owners who lifted their truck, developed vibes after lifting, and tried installing a differential drop to cure the vibes.
  2. Jan 28, 2011 at 7:50 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I installed mine at the same time I did my lift so I don't have "before" comparison. I don't have any front end vibes, they are all coming from the rear.
  3. Jan 28, 2011 at 1:29 PM
    fastguy95
    fastguy95 A man knows nothing
    SF Bay Area
    02 DC 4wd
    All Pro front/rear bumpers, OME 883's with Bilstein 5100 all around, Deaver J59 springs, TRD E locker, E locker Guard, Red Line hood struts, Weathertech floor mats, SS brake lines, EBC Rotors and green pads, Debadged, Line X, BAMF brake relocator bracket, Beefed Taco cb drop, Magnaflow muffler, Scuba Mod, live power outlet mod, disable door buzzer mod, tinted windows, light blinker conversion, Alpine HU, Infinity Kappa 600w amp, JL Audio 1000w amp for sub, JL Audio W3V4 12" sub, JL Audio 6x9's, Retrofit projectors bixenon 55w, Dynamat on all doors, and light bar.
    The vibrations you're referring to after lifting your taco is probably due to the driveshaft rotating at a bad angle. The differential drop kit lowers the angles of your cv boots in the front, hence, why you would still have vibrations coming from the rear.
    What a lot of the Tundra guys do is purchase and install a carrier drop bracket, which lowers the angle of the driveshaft. Many swear by this cure. You should PM BeefedTaco about this common issue and he'll be able to assist you.
  4. Jan 28, 2011 at 1:46 PM
    BenWA
    Seattle @ 0.9 Mach
    The vibes I'm personally experiencing are from my front diff, as I haven't lifted my rear yet. I'm just trying to get a big picture sense of whether a diff drop has helped anyones vibes at all. I do realize that some people who have lifted both front and back can experience vibes that originate from both front and rear though.
  5. Jan 28, 2011 at 6:43 PM
    BenWA
    Seattle @ 0.9 Mach
    c'mon, I know more than 5 people on TW have tried a diff drop to cure vibes... lets see some votes over here!
  6. Jan 28, 2011 at 6:49 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    did it all right the first time. only vibes coming from truck is the bits of little scraps of metal stuck in tires from running over hondas. it is necessary to correct all drive line angles when doing a lift, it will pay off in the long run. less wear on them. axles/cv joints/boots. drive shaft ujoints, center support bearing, pinons, etc.
  7. Jan 28, 2011 at 6:49 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Hope it works for you, the diff bearing is a pain in the ass. Not that i fixed it myself but my wallet hurt. Maybe the drop will solve your issue.
    Good luck!
  8. Jan 31, 2011 at 8:12 PM
    BenWA
    Seattle @ 0.9 Mach
    thanks Redgrom. I'm probably gonna give a DD a try and see what happens.
  9. Feb 1, 2011 at 6:36 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Yes, and more than 5 people used the search feature to find the hundreds of other threads on this topic.
    Search.
  10. Feb 1, 2011 at 9:05 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    sorry for the dumb question but are these needed for the 2wheel drive prerunners or only the 4x4's?
  11. Feb 1, 2011 at 9:12 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    4x4s only.
    I have not tried a diff drop yet... so still have vibes.
    Got a beefed CB drop and Diff drop at home waiting to try.
    Im gonna try Beefed's CB drop first.
  12. Feb 1, 2011 at 1:53 PM
    BenWA
    Seattle @ 0.9 Mach
    Oh my god, I'm sorry for cluttering up your forum :rolleyes:
  13. Feb 1, 2011 at 1:58 PM
    BenWA
    Seattle @ 0.9 Mach
    Only 4x4's have a front differential, so they are the only ones that front diff drops apply to. Any vibes that one may get in a prerunner are probably coming from the rear driveline, or possibly front wheel bearings or tire/wheel balance issues.
  14. Feb 1, 2011 at 2:14 PM
    mjp2
    NJ
    Simply explaining why people aren't jumping all over your thread with responses. The topic has been covered to death.
  15. Feb 1, 2011 at 2:22 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    I noticed when I lifted my 2003 Tacoma with the OME lift and installed the diff drop I suddenly developed a rhythmic vibration. I removed the diff drop and it has gone away. I do have a slight vibration but not nearly as pronounced as I did before.
    I do not have a stock height before I lifted it slightly with 5100's but with the full OME lift I got about 2 1/4" lift over the 5100's.
  16. Feb 1, 2011 at 2:27 PM
    BenWA
    Seattle @ 0.9 Mach
    Fair enough, but I did a search and didn't see any polls like this one. I wanted an at-a-glance view of peoples' experiences in a poll histogram
  17. Feb 1, 2011 at 2:30 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The poll is going to be meaningless because of the mix of 1st gens and 2nd gens that answer.
    Diff drops made a lot of different on the cv angles for first gens. They do almost nothing for the 2nd gen angles.
  18. Feb 1, 2011 at 3:01 PM
    BenWA
    Seattle @ 0.9 Mach
    My OP specifies 2nd gens. :)
  19. Feb 1, 2011 at 3:05 PM
    KPT
    09 Prerunner
    Haven't you figured out that everyone just reads the title, not the post or any responses, before replying to threads on here?:D
  20. Apr 11, 2011 at 8:18 PM
    BenWA
    Seattle @ 0.9 Mach
    Finally got around to installing a toytec DD.
    In terms of curing vibes it did.....absolutely.......nothing.
    Can't decide whether to keep it on or take it off.
