Poll: Front lift Question - Added Weight Compensation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LoadedTaco, Apr 24, 2013.
What will compensate for the added weight without breaking the bank?
Poll closed May 24, 2013.
  1. Leave it as is. You only lost .25" save your pennies.
    0 vote(s)
    0.0%
  2. 10mm Front Strut Spacer (this is not a shock top spacer)
    40.0%
  3. Swap out OME 886
    60.0%
  4. Other - Please Specify
    0 vote(s)
    0.0%
  1. Apr 24, 2013 at 8:25 AM
    LoadedTaco
    LoadedTaco [OP] Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Okay so I have a 2012 Baja edition. As you know it comes with about a small lift from the factory. Since I purchased my truck I have added a considerable about of weight. Pelfreybilt bumper, winch, and Pelfreybilt skid plates are on the way. I went wheeling for the first time this past saturday and the truck did amazing. My only issue is I would like to compensate for the weight to get my stock ride height/clearance back.
    I don't want more lift just more support for the extra 130+lbs. Money is tight so I am trying to dodge UCAs for now. I figure if my truck came with the lift a lift so as long as I don't exceed the stock height I will not need to replace them? In theory....
    My question for all you all are the following.
    1) Should I leave the suspension as is.
    2) Add a 10mm Front Strut Trim Packer
    3) Swap out the Coil spring for an OME 886 (I am not sure if this is possible due to shock size)
    4) Other Suggestions
    I understand some of you don't like the baja edition, so if you don't have something constructive please move on the the next thread.
  2. Apr 24, 2013 at 6:25 PM
    BradyT88
    BradyT88 Well-Known Member
    So basically you have dropped below factory height and would like to get back to factory height?
    I would do the spacer then. Seems easiest. I don't think 886's would fit your shocks, plus that is a longer stronger shock so you would likely get more lift out of it. I have added a few hundred pounds to my front end and my 886's have barely moved at all.
  3. Apr 24, 2013 at 6:26 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Quick and dirty, 10mm trim packer. A little more cash and effort, 886's if they will fit. Truck looks good, do what the wallet can afford and what you want. Keep us updated.
  4. Apr 25, 2013 at 5:28 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    That is what I was thinking. I am pleased with the lift that came on the truck (1.5-2" I believe). It is enough for me to do everything else I want on the truck for now. I am just making sure I do something to compensate for the weight a little.
    Thanks for the help.
  5. Apr 25, 2013 at 5:29 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Yeah I think the trim packer is the way to go then.
  6. Apr 25, 2013 at 6:04 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    #2 is the clear choice and start saving up for 886 springs/shocks, because your current springs will just continue to sag more with time.
  7. Apr 25, 2013 at 6:09 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    10mm trim packer and save for mid travel :D
  8. Apr 25, 2013 at 7:17 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Just ordered the spacers.
  9. Apr 25, 2013 at 7:29 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So
    The Ironman trim packer fits your shocks ?
  10. Apr 25, 2013 at 8:07 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Honestly not sure. I am going to measure them once I get them and see if they will fit. If not I will just send them back or sell them on here. I can't find measurements for them. They fit 4 runners, FJ's, Land Cruisers, and tacomas.
    I cannot get any information about these damn shocks because they are "for toyota" so when I called billstein they were no help.
  11. Apr 25, 2013 at 8:19 AM
    OZ-T
    Peter North
    British Columbia
    The only reason I ask is because that looks exactly like the OME trim packer except the OME trim packer is 5mm thick
    The OME trim packer goes at the bottom of the coil and only works with OME shocks
    This doesn't look like a top plate spacer , they usually have notches to align the spacer with the top hat studs
    I may be mistaken but that what it looks like to me
  12. Apr 25, 2013 at 9:15 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I am starting to think that those spacers are not going to fit....Damn it!
    I canceled my order. I am going to leave the truck as is for now.
    I have a friend who knows his stuff, but mostly about FJ's. These were his suggestion. I know they fit on stock tacoma shock. The issue is if they will fit the baja shock. The springs around my shock are 3" inside diameter. The shock body seems to be 2.5" (rough guess using a ruler.) I don't need to bring it back up. I will save for a while and upgrade to a quality mid travel in a year or two.
    I would love to know if I could just swap out an OME spring.
