Poll: Have you bent a spindle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steezemcqueen, Mar 2, 2017.
See thread title you damn fools
  1. Yes
    15.6%
  2. Nope. Gusseted
    11.9%
  3. Nope. Stock spindles
    68.8%
  4. Yes. With gussets
    3.7%
  1. Mar 2, 2017 at 7:04 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yes.
    Bent with TC no sway gussets, no gusset to steering arm. Gusset was cracked and couldn't get the alignment in.
  2. Mar 2, 2017 at 7:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Was it the toe that was messed up or something else
  3. Mar 2, 2017 at 7:06 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    No, toe you can always fix with the tie rods, couldn't get any amount of caster and keep camber in spec. New spindles and it lined right up.
  4. Mar 2, 2017 at 8:15 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    After you drove home with a ghetto toe adjustment.
    Firebird and teamhypoxia[QUOTED] like this.
  5. Mar 2, 2017 at 8:21 PM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Yes on the Wife's 4runner (uses the same spindle). Not sure when, just caught it at alignment time.
  6. Mar 3, 2017 at 6:55 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Yep, I was just asking around our CO BS Thread looking for a set to Gusset for quick(ish) replace.
  7. Mar 3, 2017 at 7:48 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    CO representing in this thread. Bend those spindles!
    thefatkid likes this.
  8. Mar 3, 2017 at 7:49 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    We wheel harder? Nut up sucka!
  9. Mar 3, 2017 at 7:51 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Luckily Cali has the lead in the broken spindles, would like to avoid that scenario if at all possible.
  10. Mar 3, 2017 at 12:59 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Of course there's a demand. People are already buying gussetted factory, or gussets to do their own spindles.
  11. Mar 6, 2017 at 9:44 AM
    steezemcqueen
    steezemcqueen [OP] 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Thanks to everyone that votes and gave the feedback!
    I'll be discussing some new products with my place of employment soon and hopefully we can bring some products like this to market where there is a void.
    :cheers:
    REDdawn6 and Wheelspinner like this.
  12. Mar 6, 2017 at 6:00 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I'll be your beta tester.
    And since you're my besty, I won't even charge you. :D
  13. Mar 6, 2017 at 6:40 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I gussetted my spindles pretty early on. Went with the tc sway bar gussets as they're beefier and I got a deal on them. Now if only my shocks were just as beefy
  14. Mar 6, 2017 at 7:44 PM
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    sub'd
  15. Mar 15, 2017 at 10:40 AM
    #35
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Pretty sure I just bent my passenger side spindle... Measured from tire to the UCA bolt, 2 5/8" on driver side, 2 1/8" on the passenger side. No visible cracks or damage. Hit a hole at speed and my wheel/steering wheel were not straight anymore... After getting off the trail I spend 3 hours in a shell parking lot doing the best ghetto alignment I could with a 3/4" wrench and a crescent wrench. Actually got it real close camber and toe wise anyways. Was able to drive from CA to NV home on it. Going in for an alignment tomorrow to see if they can get it close enough as I need to drive back to CA this weekend... New spindle on order... This is no fun and I am not sold on, nor do I have time to do spindle gussets right now.
  16. Mar 15, 2017 at 5:44 PM
    #36
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I got the non sway bar version because I felt like the gusset was placed perpendicular to the axis on which my spindle bent and I'd never heard of the tie rod connection bending. I think anything that would cause the tie rod connection to bend would destroy the tie rod first.
    I'm not an engineer so I feel like I have a pretty good handle on this sort of thing :D
    Logic reaffirmed my decision.
    If the sway bar version was better why would there even be a non sway bar version?
    The only reason to have two versions would be to compromise for those who felt they needed to keep their sway bar.
  17. Mar 15, 2017 at 7:37 PM
    #37
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    It's not the that tie rod arm is bending silly, it's that it provides a good spot to locate the gusset. The non sway has less material at that spot as well, where all of them are cracking. So while the flex is at the base of the tie arm, it probably is not induced (in any significant way) by forces on the steering/ties.
  18. Mar 15, 2017 at 7:38 PM
    #38
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    And as for two versions, simply to give us something to argue about.
    akkyle likes this.
  19. Mar 16, 2017 at 5:58 AM
    #39
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    See I think that extra material is there to compensate for the gusset being in the wrong place due to the constraint of having to keep the sway bar.
  20. Mar 16, 2017 at 9:33 AM
    #40
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    teamhypoxia[QUOTED] likes this.
