Poll: How many of you are having vibration issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alexderaven, Nov 13, 2015.
Are you seeing any vibration issues?
  1. Yes: 4X4 Limited, Sport, SR5, SR
    41 vote(s)
    27.3%
  2. Yes: 4x2 Limited, Sport, SR5, SR
    3 vote(s)
    2.0%
  3. Yes: 4x4 Offroad
    22 vote(s)
    14.7%
  4. Yes: 4x2 Offroad
    3 vote(s)
    2.0%
  5. No Issues
    81 vote(s)
    54.0%
  1. Nov 15, 2015 at 10:30 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
  2. Nov 15, 2015 at 10:33 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    why is the offroad listed separately?
  3. Nov 16, 2015 at 5:43 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I also I have a delay when taking it out of park in the morning, maybe a 5 second delay for it to start rolling
  4. Nov 16, 2015 at 5:50 AM
    alexderaven
    alexderaven [OP] Well-Known Member
    Alex
    Albuquerque, NM
    2016 MGM Tacoma Limited 4x4 (sold)
    Based on the other forums, it seemed the off-roads additional features may have mitigated the vibration issue. I put them separate to see if this was the case.
    If I were to redo it I would have put every trim on its own (maybe a little to excessive).
  5. Nov 16, 2015 at 6:11 AM
    GuitarGuy91
    GuitarGuy91 Well-Known Member
    Stephen
    Glenville, NY
    16 TRD OffRoad Acc Cab (ordered)
    Maybe it's the Hill Assist Control?
  6. Nov 16, 2015 at 6:31 AM
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    That seems highly unlikely. I don't think I've seen anyone else complain about that.
  7. Nov 16, 2015 at 6:51 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I park On Complete Flat ground
    Rich2putt likes this.
  8. Nov 16, 2015 at 12:50 PM
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Yeah, I never said I believe them haha. I think most of the techs and even service advisors know less about these trucks than the majority of us do
  9. Nov 16, 2015 at 11:28 PM
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Have you talked to a different dealership to see what they say? Are you sure it's not the tires? A quick way to test would be multiple gears at the same speed to see if the vines are there. Ive never seen an AT tire vibe at 25mph but I've seen some really aggressive MTs or flat spotted non DOT tires do it.
  10. Nov 17, 2015 at 6:15 AM
    BAMA-256
    Rex
    Huntsville Alabama
    I haven't checked with another dealer, only have 1 local but may end up trying another. I've never heard of tires vibrating at low speeds unless it's a mt like you said. They're glass smooth at highway speeds so I thought that ruled out tire balance issues? Are you saying use the sport shift and say leave it in 2nd coming to a stop? If so, I may try that. Thanks for the suggestions!
  11. Nov 17, 2015 at 10:11 AM
    LuvTacos
    LuvTacos Well-Known Member
    Sounds like a design issue they can't fix. They reached for higher mileage with early up shifts for better mileage, this sounds like a poor trade off. Probably can't re program the trans through a TSB, that would reduce the MPG rating.
  12. Nov 17, 2015 at 4:29 PM
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    I doubt it's a balance issue as well. I was agreeing that ATs are unlikely to to cause the issue but if the tread is aggressive enough, it's possible. Shifting the transmission to a different gear to see if it's still vibrating could eliminate a few possible options as to the vibration.
    If you change gears and it's no longer there, then it's probably from the transmission or engine. If it is still there it's likely the rear end or tires. You could try it one of 2 ways. One is going into second like you said, the other is putting it in neutral.
  13. Nov 17, 2015 at 4:51 PM
    Cornhuskers79
    Cornhuskers79 Well-Known Member
    Under acceleration (particularly between 2-3k rpms) I feel significant vibration/buzzing in the pedal. The louder the engine the greater the vibration. I assumed this was normal.
    Is this what people are taking issue with?
  14. Nov 17, 2015 at 5:11 PM
    G-52
    G-52 Well-Known Member
    Colorado
    2022 Tacoma TRDORDC, lunar rock, 6 MT
    I took possession yesterday, TRDORAC. I am getting vibes between 20-27 mph. All other speeds are smooth as glass. Feels like tires to me. It occurs in that range regardless of whether I am on the accelerator.
  15. Nov 19, 2015 at 11:18 AM
    #35
    Trump16
    Trump16 Active Member
    Wallace
    You'll likely get used to it, just turn up the radio a little louder.
  16. Nov 19, 2015 at 11:42 AM
    #36
    G-52
    Colorado
    I'll get on that Wally...
  17. Nov 19, 2015 at 2:33 PM
    #37
    crzycav86
    crzycav86 Well-Known Member
    Houston
    I test drove a 4x4 auto double cab sport. it had some vibration in the steering wheel as if the tires were not properly balanced.
    The 4x4 limited that i bought does not have any vibrations in the steering/pedal, or have the 35mph howl... however yesterday i noticed the passenger seat vibrating pretty good at idle (appears to go away at higher speed). I didn't sit in it so maybe it's not something you feel but it looked like something wrong.
  18. Nov 19, 2015 at 3:58 PM
    #38
    DamonX
    DamonX Member
    DamonG
    16 DCSB 4X4 Sport
    I finally got a new 4x4 DCSB Sport automatic this weekend and picked up on the significant buzzing vibration in the pedal and steering wheel that others have mentioned when I'm in the 2,000-3,00 rpm range. I called the dealer service center and they said it's a known issue they've reported on some models. They said they'd call me when they learn more. Otherwise, truck is great.
  19. Nov 19, 2015 at 4:23 PM
    #39
    06trdtaco
    06trdtaco shouldn't be trusted
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
  20. Nov 19, 2015 at 4:28 PM
    #40
    Z50king
    Eric
    Southern California
    Stock and loving it
    If you're having driveline vibes I feel bad for you, son....
