Poll: Oil or Propane
Discussion in 'Off-Topic Discussion' started by Glocker23, Mar 28, 2014.
Is your house heated with Oil or Propane?
Poll closed May 27, 2014.
  1. Oil
    40.0%
  2. Propane
    60.0%
  1. Mar 28, 2014 at 10:40 AM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Hey Guys I am looking to see who has which of the following options. Do you heat your house with Oil or Propane. Other than propane being cleaner, post up reasons below you have what. I am looking into a house with an old oil burner and am considering replacing it one day with propane. But am in the air
  2. Mar 28, 2014 at 7:00 PM
    Joe D
    Joe D .
  3. Mar 29, 2014 at 4:55 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    I would install a condensing propane furnace with an air source heat pump. The heat pump will be able to heat the house when the outside temperature is above 35 or 40 degrees. When it's colder than that the furnace will run instead of the heat pump. Also, if you loose power you can run the furnace off a generator. For example a tri-fuel Honda EU2000i portable generator or a whole house auxiliary generator running off the same propane tank supplying the furnace.
    I would replace it sooner rather than later. Old oil burners are horribly inefficient. Even new ones NEED annual maintenance and you have to remember the existing oil tank is probably at least as old as the furnace. Removing a leaking tank and the contaminated soil is a nightmare.
  4. Mar 29, 2014 at 5:00 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Where I live oil is not an option and Natural Gas has not made it this far out yet. So I have Propane but I don't use it to heat with. When I purchased my home I installed a Pellet Stove and It Was The Best Thing I could Have Done!!!!!!!!!!!!!!!!!!!!
  5. Mar 30, 2014 at 7:12 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    This. I see oil tanks/burners fail on a daily basis. Trust me you dont want to have to deal with contaminated soils around and under your house. Very expensive and time consuming to have a cleanup done.
  6. Mar 30, 2014 at 7:14 AM
    Glocker23
    CT
    2012 DCSB Sport
    Plus side is old in ground tank was removed with no leak or contamination already. New one as of last year is in garage
  7. Mar 30, 2014 at 7:18 AM
    CoastalComa
    CoastalComa Well-Known Member
    Mendocino
    '08 6spd sr5 Sport
    kerosene in a diesel stove. cheap and efficient. the stove is expensive unless you can find someone getting rid of one.
  8. Mar 30, 2014 at 7:20 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Pellets.
  9. Mar 30, 2014 at 7:56 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I have oil right now, but I'll be switching over to natural gas this summer.
    Around here, propane is now 4x more $ than what it was a few years ago... not sure about your area's prices.
    I do all my own maintenance on my oil burner/chamber because I have an oil burner technician certificate that I've earned many years ago (now has long expiered :eek:).
    Gas/propane is so much cleaner and virtually maintenance free compared to oil, but a properly maintained/tuned oil burner is just as good.
  10. Mar 30, 2014 at 7:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    My heat and hot water are oil but I have propane for the stove top and dryer. I like the propane for the stove in the event we lose power, I can still cook even without hooking up the generator. I bought a small generator that'll power the boiler and the fridge. My heat is forced hot water baseboard heat and I have one zone that has 1 cast iron radiators in a back room. I like oil heat, it does well for our house but I would prefer to have a cast iron stove or a firebox with a blower.
