POLL: OVTune Reviews (3rd gen)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bshammer0, Feb 25, 2018.
How would you rate OVTune? (1 lowest, 5 highest)
  1. 1 (MT) - meh
    21 vote(s)
    2.5%
  2. 2 (MT)
    6 vote(s)
    0.7%
  3. 3 (MT)
    13 vote(s)
    1.5%
  4. 4 (MT)
    36 vote(s)
    4.2%
  5. 5 (MT) - best mod, hands down
    70 vote(s)
    8.2%
  6. 1 (AT) - meh
    49 vote(s)
    5.8%
  7. 2 (AT)
    27 vote(s)
    3.2%
  8. 3 (AT)
    61 vote(s)
    7.2%
  9. 4 (AT)
    169 vote(s)
    19.8%
  10. 5 (AT) - best mod, hands down
    400 vote(s)
    46.9%
  1. Nov 24, 2019 at 9:50 AM
    #481
    DOC0362
    DOC0362 Member
    Dan
    Queen Creek, AZ
    2019 Tacoma TRD Pro
    Tyger rails/step
    Thanks for the reply and the link, I will give it a try. Would be good to give feedback to the OV Tune team. Are you running the 87 or 91?
  2. Nov 24, 2019 at 9:51 AM
    #482
    DOC0362
    DOC0362 Member
    Dan
    Queen Creek, AZ
    2019 Tacoma TRD Pro
    Tyger rails/step
    The power out of the 91 performance tune is exceptional, all I need them to do was clean up the jerky throttle hello RPMs between 1000 and 2000. If that is fixed then I am golden. We shall see
  3. Nov 24, 2019 at 9:52 AM
    #483
    DOC0362
    DOC0362 Member
    Dan
    Queen Creek, AZ
    2019 Tacoma TRD Pro
    Tyger rails/step
    Between 1000 and 2000. Damn talk to text, LOL
  4. Nov 24, 2019 at 12:13 PM
    #484
    nwflsr4x4
    nwflsr4x4 Well-Known Member
    Donny
    Pensacola Florida
    2019 White Tacoma SR
    The 2.0 tune is not specific for 87 or 91, it’s both. I’m running the 2.0 because it fixed the vibration/hesitation driveline issue. I’m digging it so far.
    tacomatyler and Chasespeed like this.
  5. Dec 9, 2019 at 5:05 PM
    #485
    aapstealth
    aapstealth New Member
    Al
    2018 Tacoma DC 4x4
    1.5" Front level, 265/70/17 tires, K&N Intake, MBRP Exhaust and OVtune
    Order #5423
    Bought 11/19/19
    Received 12/3/19
    Flashed 12/3/19
    Truck: 2018 3.5 Automatic Double Cab 4x4 275/70r17
    Overall rating: 5
    Total Miles on Tune 950+
    Current Tune 87 Performance 1.05
    History
    I've owned my truck for the better part of a year now. I started with the simple engine upgrades K&N intake system and MBRP Exhaust. The truck was louder maybe a hair more responsive (Probably Mental due to money spent). But the throttle still lagged and the truck felt like a 4cyl. You had to push the pedal 1/2-3/4 down to get the truck moving and I felt I only had power past 5000RPMS.
    Fast forward: 12/3 I loaded the Base 87 tune. Pedal felt much better shifts cleaned up and I picked up almost 1.5MPG. Daily driving the truck was more enjoyable. It held 6th gear didnt downshift to 4th and made commuting easier. Power seemed the same maybe a tad more but the pedal was more responsive. The truck felt like a finely tuned Stock truck. But still left more to be desired. I felt like I was driving a better tuned factory truck.
    12/5 After 400miles on the base tune I loaded the 87 performance tune. Wow huge difference pedal was very responsive almost a tad too much pulling into and out of the garage. Shifts now follow the pedal which allows you to drive stock sporty or all out. Daily driving is so much more enjoyable the truck feels to pick up power after 3000RPMS and holds it through the power band. Driving on long trips the transmission stays in 6th and will downshift to 5th to climb a small hill or make a easy pass. Move the throttle 1/2 or more and it kicks into 4th or 3rd to allow you the power needed to pass. Towing greatly improved as well I tow 2500lbs and feel I can safely catch a light or merge into traffic. During normal driving MPG gained maybe .4-.5 but the drive ability is worth it. I was so happy I actually made a youtube review to try and help potential buyers.
    https://www.youtube.com/watch?v=xa9oF2nTPDo&feature=youtu.be
    Overall: I've only tried the 87 tunes and am very happy. I now enjoy daily driving my truck. I feel like a have a strong V6 under the hood and the pedal matches the pressure applied.
    Cons: Can take some getting used to the sensitive throttle when coming from a stop maybe a hair less sensitivity (when coming from a stand still). Also once cruising at 65-70mph you need to use 1/2 throttle or more to really get the trans to drop multiple gears. (This doesnt bother me but I could see some people annoyed by it).
    Sort of those I cant really complain you make more power on regular 87 can get the same or better MPG if you drive kindly and get to enjoy your truck. So far a great experience and I haven't touched the 93 tunes yet.
  6. Dec 9, 2019 at 5:47 PM
    #486
    infinity
    infinity and beyond
    Alex
    Northeast
    2019 Tacoma SR V6 AT 4wd
    7’ Aluma Flatbed, firestone airbags
    • Order #5324
    • purchased 11/15/19, installed about a week and a half later (though I received the kit and registration very quickly, I think only 3 business days total, the truck was getting some fab work done at that time, delaying my install)
    • Running 1.05 base 93 tune on the truck described in my info above
    • Rated it 5 stars, but I think I would actually give it 4.5 at this point. 2.0 sounds like it might earn a full 5 stars from me.
    • No mods to speak of. I am carrying a good bit of weight and drag from my work equipment and flatbed. Haven’t weighed it yet.
    • Overall feedback of:
    • Shifting: improved about 80%. Still seems pretty quick to upshift, but it’s slower to downshift, and powers up small inclines in a higher gear than it could on the stock tune.
    • Throttle: also improved 80-90%. Response is more linear and predictable. Not yet perfect
    • Power: definitely improved in the low end, and the power progression is smoother. No sudden jolt at ~4k rpm
    I tried out the performance tune first, and while I liked the power improvement, the throttle was just a little too touchy for my taste. I would really love to get all of the benefits of the performance tune, but with a similar throttle profile as the base tune. I’m very, very tempted to install the 2.0 beta right now
    bshammer0[OP] likes this.
  7. Dec 11, 2019 at 8:34 AM
    #487
    Razor24
    Razor24 OV Tuned,4" lift/w 33"TRD cold air intake
    Springfield ,Mo
    2017 Silver Tacoma TRD Sport ( OVTuned)
    4” lift; 285/55/20’s; KDMax Tune, led bar; TRD cold air intake,Diamondback cover,AMP Research step bars, BedRug, clear auto bra,window tint, Kicker speaker upgrade, Katzkin leather
    Jump to 2.0 beta.... I went from 1.05 87 performance to the 2.0 , 91 ..... smooths out the tip in, but overall the beta is much more refined. Can’t wait for the final 2.0 at Christmas!!!
    infinity, PhogDog and Pablo8 like this.
  8. Dec 13, 2019 at 7:52 AM
    #488
    lsukevinc
    lsukevinc Well-Known Member
    Kevin
    2019 cement limited
    i installed the 87 performance last night on my 2019 and man did it change the throttle response, almost too much. I thought the truck shifted ok but in my opinion it shifts better now. I will drive it a few more days and maybe change it to the 1.05 base. i am curious to play around with the different tunes and looking forward to the 2.0 as well. I am really impressed so far,
  9. Dec 13, 2019 at 9:18 AM
    #489
    infinity
    infinity and beyond
    Alex
    Northeast
    I went ahead and installed the beta 91 shortly after you posted. From the few miles I was able to drive, I have to agree. Tip-in is much better. Performance is solid.
    Looking forward to the full release. I’m assuming that there will be a 2.0 93 tune available at some point. 91 is less common around here (So.VT) than 93, so I just fill up on 93.
  10. Dec 14, 2019 at 9:08 AM
    #490
    Chunkeymonkey
    Chunkeymonkey Well-Known Member
    2019 TRD Pro
    I'm looking forward to the 2.0 full release also. I love the difference between stock and this tune but I'm still getting a few strange shift patterns when running at mid to higher range revs, and I hope the final tune will have taken some of that away...
    As I say, still night and day from stock and well worth the investment IMHO
  11. Dec 16, 2019 at 8:42 AM
    #491
    Capt. John
    Capt. John New Member
    Capt. John
    2019 Tacoma TRD Sport
    3"X2" Lift. Bed cover, Roof Rack, Billet grill and Window drip shades.
    I am one of the ones that gave it a low review. I purchased mine in October 2019, Order #5267 for my 2019 Tacoma TRD Sport, 2 wheel drive. Manuel transmission with slightly larger tires as the only mod to possibly effect performance. My problem is the lack of customer support. I'm 68 and not the best on the computer. I purchased an HP laptop especially to download the program for my truck. When I ran into a problem downloading, I found that the only help available was to email OVTune and wait 3 to 5 days for a response. This went on for several weeks and I received several sarcastic emails from Mathew, (Which I will share if necessary) that I should read the instructions because it has all of the answers. A month later I was able to download the program. The performance was there but I have a problem with the idle pulsing. After several emails to OVTune, they sent me a link that would allow them to sign on to my computer and check what might be the problem, I did as the asked and to this day they have not responded. I still have the problem. Now, the program is probably good but you best be very computer literate and be able to figure everything out for yourself as there was no customer support for me. I read a lot of good experiences but mine is less than stellar and I still have the problem. I did the idle adjust for 15 minutes and everything else. So far for me, I waisted $700.00.
  12. Dec 16, 2019 at 8:47 AM
    #492
    OVTune
    OVTune Well-Known Member
    OVTune
    Please pm me what emails I said to you sarcastically, because I have no reason to send you or anyone sarcastic emails.
    Or pm me your ticket number.
    As far as connecting with anydesk, this is something we do for people who need help but it's not something that we allocate time for by default so I have to fit it in when possible.
    4x4spiegel likes this.
  13. Dec 17, 2019 at 1:26 PM
    #493
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    I know the sweet spot for most of our trucks is 4.88s (or 5.29) + OVT. Between this and the development thread I can't remember if I've seen anyone that's experienced both getting gears first and then adding OVT, as well as starting with OVT and then re-gearing. Of the two mods, which made the most difference?
    Obviously, it's unlikely this would be on the same truck. Maybe they've had 2 3rd gens. Maybe it's a friend's.
  14. Dec 17, 2019 at 1:58 PM
    #494
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    Did gears and 33s first, then the tune. My opinion, is if you do 33s and hwy driving you need the gears 4.88s. If you do 35s you need 5.29s. My truck drove fairy well with just the gears and the last TSB. I tow a RV and do a bit of off roading in the backwoods of Colorado and Utah so my truck is armoured, lifted, bumper and winch so I'm heavy. The tune solved all the transmission shifting problems while towing and hills. I was a mechanic for years when I was young and I will tell you one thing, you never be happy driving a incorrectly geared truck. You can never solve the other problems but gearing is a foundational problem that has to be solved before you add other things if you go larger tires if you stay stock I would go with the tune first. Good luck with what ever you choose to do first.
  15. Dec 18, 2019 at 6:19 AM
    #495
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Fully armored, heavy long bed on 35's here. I started with the SSP early on and it helped a bit. When 4.88 came out, I was an early adopter and that made a huge difference. I tried running both the SSP and tune together, but then the shift points were too high. Basically, the SSP wasn't needed after the regear. Then OV tune came out and I watched this thread for a while. Initial comments were positive, so I bought the tune and that made a world of a difference as well.
    TLDR: Regear is a must, but the combination of that and OVTune provides you with a truck that drives how it's supposed to.
    Kerbouchard![QUOTED] likes this.
  16. Dec 18, 2019 at 6:36 AM
    #496
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    This my conclusion as well. For many readers pretty sure I sound like a scratched LP record. :eek::taco::yes::yes:
  17. Dec 18, 2019 at 7:02 AM
    #497
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Anyone have feedback on OVT on the 2020's? Did I read it doesn't help while on cruise control? (I do a lot of highway driving)
  18. Dec 21, 2019 at 8:54 AM
    #498
    birdbrooks
    birdbrooks Well-Known Member
    Bill
    2025 Tacoma TRD Sport in Supersonic Red
    All-factory options at this point.
    I own a 2019 TRD Sport w AT, and am trying to determine how much the factory transmission setup has changed since this thread began. Is the need for OVTune the same as it was 3 model years ago?
    Yes, I have noticed the newer released versions of the OV Tune in this thread, but I'm not experiencing the same issues I see described here, especially when I run in ECT. What performance results are you 2019 owners out there with OVTune seeing that I might be missing?
  19. Dec 23, 2019 at 9:30 AM
    #499
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Transmission gearing hasn't changed, but the stock tune on the 2019s may have some updates that were done through the Toyota TSBs.
    birdbrooks[QUOTED] likes this.
  20. Dec 25, 2019 at 5:30 PM
    #500
    birdbrooks
    Bill
    Thanks-
