Poll "Spacer lift vs. Suspension Lift"
Discussion in 'Suspension' started by JoeyTacoma, Mar 24, 2011.
Spacer or Suspension
Poll closed Mar 23, 2012.
  1. Spacer lift and I love it!
    45 vote(s)
    13.9%
  2. Had a spacer lift but then replaced it with some type of suspension lift.
    71 vote(s)
    21.9%
  3. Did it right the first time!
    203 vote(s)
    62.7%
  4. Why are you guys lifting your trucks I'm trying to slam mine!
    5 vote(s)
    1.5%
  1. Apr 13, 2011 at 9:04 AM
    North Star
    North Star I keep planets in orbit
    Cali
    07' Double Cab 4x4
    N-fab side steps, Extang hard tonneau cover, Terra Grappelers
    I'm thinking of doing a Pro Comp lift as well. Looks like you got the 3"? How is it for mild off-roading abliity?
  2. Apr 13, 2011 at 9:14 AM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    ya, I had a spacer lift on my 2008 pee runner, switched that truck out for my current one, got a spacerlift for that one too (i know, when the f*ck was I gonna learn?) then I found tacoma world, then I got a real suspension lift, which is in my sig. :D
  3. Apr 13, 2011 at 9:27 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Buy a real lift.
  4. Apr 13, 2011 at 9:30 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I went the "cheap" way and started out with the spacer lift so I could get new rims/tires to fit. In the long run, I would have only had to spend $300 more and I could have gotten a much better upgrade. Just dropped my spacers this past weekend and put on LR UCAs, 5100's and OME 885 springs. The ride is incredible and the flex is greatly improved over the spacers.
    Save the money and avoid the spacers, folks!
  5. Apr 13, 2011 at 9:32 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    ^"No, have you?"
    "Right on Vasquez. You just too bad."
  6. Apr 13, 2011 at 12:07 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    went from 3" spacers to fox coils.
    spacers ride super rough.
  7. Apr 13, 2011 at 12:17 PM
    icefox
    icefox Well-Known Member
    Fridfinnur
    Iceland
    Toyota Hilux
    38" tires,3"lift,diff lock fornt and rear
    x2
  8. Apr 19, 2011 at 6:08 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Be more specific, Top plate spacer or in coil spacer. Quit misinforming people.
  9. Apr 19, 2011 at 7:09 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Coil spacers ride rough but so can top plate spacers if they are large enough that they are maxing out the play in your uca's when you go over bumps.
  10. Apr 19, 2011 at 7:14 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
  11. Apr 19, 2011 at 7:21 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    no misinformation from my part. a 3" lift from an in coil or top plate will be rough...:rolleyes:
    I would never do more than a 1/2" top plate spacer, just to avoid maxing out your shocks.
    this, thanks KPT.
  12. Apr 19, 2011 at 7:23 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    A 3" top plate will not be rough...
  13. Apr 19, 2011 at 7:26 AM
    TexasTacoma37
    Never been in a truck with one...but it WILL damage your ball joints, that's for sure.....
  14. Apr 19, 2011 at 7:44 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    may not but its still a disaster waiting to happen.
  15. Apr 19, 2011 at 9:38 AM
    #35
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Ok so then dont say the ride will be rough. Thats all Im saying.
    I run a 2" top spacer and have no issues with a rough ride. They aren't for everyone but after a ton of research I chose spacers.
  16. Apr 19, 2011 at 9:55 AM
    #36
    malander
    max
    01 limited trd 4x4
    If it's big enough than yes. But so can a good c/o set up if you don't upgrade ucas
  17. Apr 19, 2011 at 10:48 AM
    #37
    TexasTacoma37
    Coilovers won't damage the ball joints because the down travel is still limited by the shock topping out. So the suspension's position at full droop has not changed, it just takes less downward movement to get it there than before.
    With a top plate spacer, all you have done is force the whole assembly down 3", allowing the suspension to droop 3" below the point that it was designed to, hence the ball joint damage.
  18. Apr 19, 2011 at 11:00 AM
    #38
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Bought mine with a spacer and AAL.
    Looked like this:
    Then went with ToyTec's ULK, Dakar rear leaf pack, and LR UCA's. Then of course tires and bumper and winch.
    Now it looks like this:
    Better ride and handling in my opinion!:thumbsup:
  19. Apr 19, 2011 at 11:45 AM
    #39
    malander
    max
    01 limited trd 4x4
    Good point. I guess you'd just be a hell of a lot more likely to mess up your bj's with a spacer but don't read that wrong you can still mess em up with a decent set up
  20. Apr 19, 2011 at 12:17 PM
    #40
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Really good imo...
